This is a discussion on Pembos poor fabia...oil consumption within the Fabia I forums, part of the Skoda Model Discussion Area category; Now then all, long time no see! I have a slight issue with my car, started 2 or 3 weeks ...
| Briskodian Join Date: Jun 2006 Location: Middlesbrough, home of legends :P (not the worst place in the UK at all...honest guv)
| Now then all, long time no see! I have a slight issue with my car, started 2 or 3 weeks ago. I drove to work (about 35 miles) with oil filled up to just below max. And when I was coming out of car park to come home it was showing the EPC and Engine light. I stopped the car, checked the engine and found the oil was low (at min), so filled it up and restarted car - EPC light went out and engine one stayed on. Drove home and checked it there, no oil usage and when I restarted the car all the lights were off. Drove the car then for 2 weeks doing daft little journeys and kept checking it, and its all ok. Then... drove to work yesterday ... fine... Went to drive out car park, same lights + oil situation. Refilled oil, and EPC off, engine one still on. Car drives fine, with no smoke + no excessive water / fuel consumption. Ive been told that it may be that the airfilter is cloged and its drawing oil up thru the carb due to back pressure + a filter change and oil change should sort it? Anywho, Ive filled it back up to 3/4 and setting off to work so hopefully it will get me there. In the mean time any advice on what it could be? |
| Briskodian Join Date: Jun 2006 Location: Glasgow
| I have no idea, but fabias dont have carbs ![]()
__________________ |
| Doh, I mean the flappy thing where the air filter goes to lol |
| Get out the way Join Date: Oct 2007 Location: Bournemouth
| Throttle body/chamber?
__________________ Car now: 56 Octavia MK2 1.9TDi Ambiente-Debadged Previous: 06 Octavia Mk1 1.9TDi Classic with + pack Sadly missed: 97 Nissan Primera 2.0TDi SLX ![]() |
| | #5 | |
| Quote:
I'd get the oil breather hose and filter cleaned/replaced and pop a new air filter in. If you're doing and oil and oil filter change it's worth doing that too and I'd also use a forte flushing agent in it to clean out the passage ways. I'd then keep an eye on it at regular intervals to see if it's loseing a bit here and there or just a single big gulp. The only question is where on earth is the oil going, and you do have to find that out.
__________________ Cars make CO2 and trees absorb CO2. By driving your car you're feeding a tree and helping the environment. | |
| I'd start by checking that the cam cover bolts are all properly secure! DAMHIKT!! |
| Hmm, I have had it to a garage and the bloke had it on the ramp and couldnt see anything - I also keep checking under the car but again cant see any pools. I did once see a "splatter" of what I presume to be oil on the floor under my car but it might have been from the car that was previously there as I havnt seen any again after that. |
| Hairy Yeti Join Date: Sep 2003 Location: Newport Pagnell
| You bought a Fabia II now or is this in the wrong section???
__________________ Unit 18 now open Servicing, repairs, modifications you name it we do it. Cupra console bushes at special price, PM for a very competitive quote. |
| I wish! Nah, wrong section - I was sure I clicked Fabia I but ended up in here. Feel free to move it |
| | #10 |
| Now moved.
| | #11 |
| If I had the power I would have done.
| | #12 |
| Shows how long its been since Ive been here, Im sure you used to have the power? Ahh the good ole' days |
| | #13 |
| Briskodian Join Date: Apr 2006 Location: North East
| As I believe your car is a 1.4 16v (like mine), I would start by cleaning the breather in the air filter. Mine seems to run better and use less oil since I did this.
__________________ My other car is a Porsche.... |
| | #14 | |
| Quote:
| | #15 |
