This is a discussion on Pollen filter/demister within the Fabia I forums, part of the Skoda Model Discussion Area category; See a few post where poeple are mentioning the heater is slow to clear the windscreen, and to change to ...
| Briskodian Join Date: Mar 2007
| Pollen filter/demister See a few post where poeple are mentioning the heater is slow to clear the windscreen, and to change to pollen filter. Where's the pollen filter and is it easy to change? cheers |
| SMOGUS MAXIMUS Join Date: Jan 2005 Location: Essex
| Re: Pollen filter/demister Is this for an Octy vRS or a Fabia??? If its a Octy vRS then its under the scuttle panel on the passengers side, you have to do it from the engine bay, and just make sure you locate it properly or water will flood in the passenger side footwell. |
| Briskodian Join Date: Dec 2007
| Re: Pollen filter/demister What if it is a Fabia guys? Where is the pollen filter then? Mine takes ages to demist, even with the a/c running |
| | #4 | |
| Briskodian Join Date: Jul 2005 Location: Bromyard
| Re: Pollen filter/demister Quote:
__________________ George | |
| Re: Pollen filter/demister I forgot to say, you may get a face full of leaves !!!
| The Following User Says Thank You to George For This Useful Post: | JohnAA (11-12-2007) |
| Re: Pollen filter/demister Thanks George, I'll have a go in the weekend with daylight. |
| Briskodian Join Date: Oct 2007 Location: Kilkenny, Ireland
| Re: Pollen filter/demister And from experience, make a note of the orientation of the plastic filter bracket. The VAG filter and the bracket have arrows and "air flow" stamped on them, line these up. Silly me didn't notice these at first and had a heck of a job putting it all back together until I had a brief moment of clarity. Might save you a bit of frustration if you haven't done the job before, and I hadn't! ![]() |
| 2.0 FSI Sport. Join Date: May 2007 Location: oxon
| Re: Pollen filter/demister that reminds me, i need to give it a quick air and remove any leaves and also give it a quick vac around the filter and that!! |
| Briskodian Join Date: Apr 2004
| Re: Pollen filter/demister One reason for the pollen filter becoming a problem is if it gets very wet. The drains for the scuttle area below the windscreen are either side. If these block you can end up with the whole being full of water - when there is enough water it goes into the fan opening. The fan opening is protected by a curved plastic piece which is held by two screws. The n/s drain is easy to clean, but the o/s is difficult to reach as the wiper motor is in the way. If it won't clear with a bent piece of wire, you may have to take the wipers and plastic grill off (easy). I spotted the carpet wet under the pollen filter and worked back to find the drains were blocked - with RICE! After a bit of thought we realised that the rice put out for birds on the bird table was being carried to the edge of the garage roof. When the birds dropped the grains they went into the scuttle slots. Once at the ends, they swelled up and held other rubbish to make a watertight seal. No RSPB Christmas cards this year. V |
| | #10 |
| Re: Pollen filter/demister might have been rodents, had some mice who got into the heater fan housing and made a nest in there a couple of years ago. couldnt figure out what the grindingnoise was till i opened it up to find a rodent nest (minus its residents) in it. |
| | #11 |
| Re: Pollen filter/demister OO. The little scamps. Thanks smstext - I'll have a look round for activity. |
| | #12 |
| Re: Pollen filter/demister no probs, if you have had them in there then be prepared to disinfect the air ducting as their urine has a habit of getting around the air system and takes forever to remove. |
| | #13 |
| Re: Pollen filter/demister cheers it's for the fabia, weather permiting I'll look at this at the weekend. had a look and nearly got a face full of leaves! Cleaned and vacumed the filter and much better, is a new filter expensive?? Last edited by john1804; 19-12-2007 at 15:57. |
| | #14 |
| Re: Pollen filter/demister Did a quick cleanup last week in the area, the drain holes were still open for business. Changed the pollen filter with a new one, and most of the misting has gone now. I don't think it had ever been changed before - so much for full service history eh |
| | #15 |
| Re: Pollen filter/demister Glad you sorted it ![]()
| | #16 |
| Briskodian Join Date: Apr 2006 Location: Berwick upon Tweed , Northumberland , The Northernmost Town in England , home of the mighty 'Dream Team' , Berwick Rangers FC! Also home of 'The Barrels Alehouse' purveyor of Staropramen Czech Beer , I wouldnt give a xxxx for anything else!! ;)
| Re: Pollen filter/demister At what interval is the pollen filter renewed? I dont think mine has had one in the last 2 services , looking back at the invoices I havent been charged for one!
__________________ Duncan - England's most Northerly Briskodian! 2000/V reg Fabia 1.4 Mpi Comfort-Dynamic Blue Ex Octavia vRS and Octavia Slxi 1.8T. |
| | #17 |
| Briskodian Join Date: Apr 2007
| Re: Pollen filter/demister I think that it really depends on what dust levels the filter has experienced, if very dusty change it every year, if not very dusty change it every 2 years. I'm tight and the cars never see really dusty conditions so I change the pollen filters after 30,000 miles or 4 years - but I check and hoover every year or so! Remember that these filters have sticky stuff on them so hoovering them will not really restore full performance. Try replacing it with one of these "double" filter things that have a second filter section that uses carbon to trap smells - there is someone in UK that makes them and you can buy them online - but it gets a bit pricy due to P&P. |
| | #18 |
| Ta moko! Join Date: Jun 2004 Location: Aotearoa - land of the long white cloud
| Re: Pollen filter/demister I just changed mine for the first time after 67000km. It looked like this after I bashed it to remove the feathers and leaves. Bearing in mind it started out white!! ![]()
__________________ Corrida Red 2004 Octavia vRS Estate - It's the bestest Skoda in New Zealand! Whaia te mātauranga, whaia te māramatanga - Pursue knowledge, pursue the wisdom of knowledge www.pimpmyskoda.co.uk www.clubley.org Facebook |
| | #19 |
| Re: Pollen filter/demister I got three from the local motor factors (similar to the one shown above) - so you can guess I tend to change them regularly. In greater London every six months the white filter gets black, and I'd like to breathe less of this stuff if I can. However, the non-OEM filters (same as Alfords etc) are not a patch on the original that I replaced. That one was stiffer, heavier and clearly better made. So it may be worth considering an overpriced original in this case. |
| | #20 |
| Briskodian Join Date: Jan 2004 Location: Hull
| Re: Pollen filter/demister I need to have a look at this! I bet ours is filthy!
__________________ Black Magic Fabia V/RS Xenons, Heated seats, Cruise, Cupra Front Splitter, new VRs badges, Koni FSDs, Eibachs, Jabba ARB, Jabba Remap, PD160 Intake and 312mm brakes + Detailed by Glyn O'Donnell ![]() Black Magic Fabia V/RS Xenons, Heated seats, Cruise, Ecutek Remap, PD160 Intake (Yes I have two! Photography Marketing T shirts flickr |
| | #21 |
| I said HOT DAMN Join Date: Sep 2006 Location: Normanton, West Yorks
| Re: Pollen filter/demister If you have the carbonised filter they don't start out white. The carbonised ones are there to reduce odours too and have a greyish tinge to them not far off that picture above. They're a little more pricey though than the standard one. Even with a new filter though the screen can take a while to clear so don't expect miracles. ![]()
__________________ Silver '04 Fabia vRS. Jabba Custom Remap, Seat Surgeons Leather interior, Whiteline RARB, Cupra Console Bushes |
| | #22 |
| Re: Pollen filter/demister cleaning helped but now replaced mine with a new one £12,86 from Skoda dealer, doubt there is a schedual for replacing the filter though |
| | #23 |
| Re: Pollen filter/demister My owner's manual states that it should be changed at the INSP service stages. Haynes forgets to mention it completely as a service step. Go figure. Last edited by JohnAA; 01-01-2008 at 19:06. |
| | #24 |
| Re: Pollen filter/demister Where is this located again? Looked in the paggengers footwell and theres no clips. Just the glove box. Its a fabia vrs btw |
| | #25 | |
| Pollen Filter | Joey122mac | Fabia I | 2 | 18-07-2007 08:02 |
| Pollen Filter? | KTea88 | Fabia I | 8 | 02-03-2007 22:46 |
| Pollen filter | aerodynamic18 | Octavia I | 6 | 25-03-2006 00:36 |
| pollen filter | mbames | Octavia I | 2 | 29-12-2005 12:06 |
