This is a discussion on Power Steering and Alternator within the Fabia I forums, part of the Skoda Model Discussion Area category; Has anyone else experienced this PAS problem and found this Alternator fault as its cause? Engine starts but PAS light ...
| Briskodian Join Date: Jul 2004
| Power Steering and Alternator Has anyone else experienced this PAS problem and found this Alternator fault as its cause? Engine starts but PAS light remains on and PAS does not work Leave engine running for anything between 10 seconds and 10 minutes then PAS light goes out and PAS works PAS remains ok for the rest of the journey Car used for daily commute of 50 miles return mainly motorways/rural dual carriageways at 70pmh in 5th gear One year old battery showing "low voltage" and replaced with factory spec battery but problem remains. Connection to alternator (near gearbox?) found to be broken and replaced. Problem now seems to be solved ( I hope) |
Images: 2 Thanks: 22
| Re: Power Steering and Alternator Yep, has been mentioned and covered a few times on here, alot recently. I did take some pictures of the problem connector sometime ago but I think they have been lost now. |
| Re: Power Steering and Alternator Hi Lummox I had seen your post on the broken connector causing a discharging battery which led me to ask my garage to check the connectors (so many thanks for that tip). I hadn't found any posts directly linking this broken connector to the specific PAS fault on my car, hence my post. Martyn |
| Re: Power Steering and Alternator I spoke too soon The problem has not gone way Took it back to the main dealer who told me the pump has gone and quoted nearly £600 to fix. I have decided not to spend that much repairing a Y reg SDI with 78,000 miles and will have to try to part ex, but sadly not against another Skoda Many thanks to all on the forum who have helped me on various issues either directly by replying to my posts and indirectly by means of the search facility Martyn |
| Volkskodian Join Date: Dec 2005 Location: Edinburgh - "Bonnie Scotland"
| Re: Power Steering and Alternator Before taking the dealers word for it that the pump has gone and going the trade in route, I'd be very tempted to get someone with Vagcom to check for any fault codes, it could be something as simple as the steering angle sensor which is another very common fault on the Fabia. ![]()
__________________ Some say their glass is half empty, others say their glass is half full. I say, ...... are you going to drink that ? |
| Re: Power Steering and Alternator already had a new sensor a year ago dealer ran vagcom twice thanks anyway |
