This is a discussion on Revs drop when fan kicks in.. within the Fabia I forums, part of the Skoda Model Discussion Area category; When stationary with the engine just ticking over and the radiator fan kicks in the rev's drop by about 100rpm ...
| Briskodian Join Date: Jan 2006 Location: Knutsford
| Revs drop when fan kicks in.. When stationary with the engine just ticking over and the radiator fan kicks in the rev's drop by about 100rpm with a small shudder, just for a split second. Is this normal for the vRS? In my last car you couldn't tell when the fan came on....
__________________ Black Magic MY07 Fabia v/RS with Cruise, Xennons, Heated Seats, Dension Ice-Link+, Aero wipers & Jabba RARB. |
| Briskodian Join Date: Jan 2004 Location: Up a tree.
| Re: Revs drop when fan kicks in.. It's putting load on the alternator and hence, the engine. Perfectly normal. |
| | #3 | |
| Re: Revs drop when fan kicks in.. Quote:
__________________ Black Magic MY07 Fabia v/RS with Cruise, Xennons, Heated Seats, Dension Ice-Link+, Aero wipers & Jabba RARB. | |
| Re: Revs drop when fan kicks in.. i would have said that it wouln't make much difference when the fan comes on! i would check the battery/alternator to check it is charging properly |
| | #5 | |
| Re: Revs drop when fan kicks in.. Try running with the Aircon on, that should switch the fans on permanently.
| | #7 | |
That won't make the fan for the coolant stay on though.... that'd be daft. ![]() Its probably fine, think i'm just a little paranoid cos its new.....
| | #8 | |
| | #9 | |
That doesn't make any sense?? I thought it'd just be the can for the AC....
| | #10 | |
| | #11 | |
I will, later.....
| | #12 | |
| Briskodian Join Date: Jan 2003 Location: Rochdale
Fun afternoon that was, I can tell you... ![]() Rob. | |
| | #13 |
| Re: Revs drop when fan kicks in.. the rad for the aircon is infront of the engine rad so how can they have different fans ![]() and don;'t worry about it every car i've had has done this ![]() press two electric window buttons at the same time, has the same effect ![]()
| | #14 | |
I have two fans side-by-side between the radiator and the engine...Rob. | |
| | #15 | |
| | #16 | |
Unless it's just a peculiarity of the engine I've got...or the car (not beyond the realms of possiblity )...Rob. | |
| | #17 | |
i know the the early golfs and corrado's that had twin fans also had onlt one motor to drive the fans ans there wasa little belt linking them together | |
| | #19 |
| Re: Revs drop when fan kicks in.. pfft, bovvard? i'm gonna go stick my nuts in the freezer to clear my head ![]()
| | #20 |
| Re: Revs drop when fan kicks in.. on the octavia vrs, both fans should run all the time with the a/c on. The fact that the air is also passed over the coolant rad to get to the condensor shouldnt be a problem if the thermostat is doing its job because no water will flow through the rad if cooling is not required. They are switched from the same source, so if only one is going then the chances are one of the motors has seized/ burnt out. This happened to Jon at the ring, and his car was fine until pressed hard then it overheated with just one fan working.
__________________ Manny 2005 Octavia 2.0TDi Elegance combi my skoda website http://www.octaviars.co.uk Join the briskoda.net folding team click Here for more info Last edited by mannyo; 07-09-2006 at 10:13. |
