This is a discussion on should my air con make a loud hissing noise within the Fabia I forums, part of the Skoda Model Discussion Area category; my car is a new 56 fabia vrs .the air con makes a constant hissing noise! has any one else ...
| Briskodian | my car is a new 56 fabia vrs .the air con makes a constant hissing noise! has any one else got a noisey aircon. i just want to know incase dealer says "they all do that" ? thanx ![]() |
| Briskodian Join Date: Oct 2004 Location: Waterloo, Liverpool
Members Car: Mazda MX5 MK2.5 Thanks: 7
| Re: should my air con make a loud hissing noise in short "no", is the air con working? |
| Briskodian | Re: should my air con make a loud hissing noise i dont think so |
Members Car: Fiat Panda Thanks: 15
| Re: should my air con make a loud hissing noise Whereabouts is the hissing coming from? I don't think it should hiss, but if the air con isn't chucking out cold air, something is definitely wrong ![]() Chris
| Briskodian | Re: should my air con make a loud hissing noise a title for a new hit movie...."snakes in a car" on a serious note...no I tend to think a hissing noise is never a good thing.
__________________ Fabia Vrs Blackmagic! Xenons, Cruise Control, Heated Seats and ESP Wednesday 12th may 2006 was my VRS day |
| Re: should my air con make a loud hissing noise When I had this problem , there was a hisisng noise and no chiiled air. The dealer investigated this and found a leak in the system. All fine now, but for to happen on a 56 plate seems strange to me, just take it back and let them sort it out. Tony |
| Briskodian | Re: should my air con make a loud hissing noise hissing coming from dash & vents when aircon turned on |
| Briskodian Join Date: May 2006 Location: Medellin, Colombia
Members Car: 2006 Fabia Combi Elegance 1.4 16v Thanks: 1
| Re: should my air con make a loud hissing noise I don't think it should sound like that either. My 06 Furby doesn't make that sound. I did have two Volvos and a Nissan that did somethign similar after awhile. They both had leaks and the Volvos both needed a new condensor (I think that's what it was) and a number of other things. All three made hissing sounds in the dash and it apparently was a sign of low R134a. Apparently, when the pressure lowers it starts to make that sound. In the Nissan it was constant, in the Volvos it was intermitant - like the gas was being pumped in and every second or so "spilling" into the condesor in the cabin of the car. The Volvos would still pump out cold air for some time like that. Nissan, hardly. NR |
