This is a discussion on Squeaky Sound Starting from Cold within the Fabia I forums, part of the Skoda Model Discussion Area category; Hi there, New Skoda owner. Just bought the car last week. The car is fantasitc other than the problem. The ...
| Briskodian Join Date: Oct 2008
| Hi there, New Skoda owner. Just bought the car last week. The car is fantasitc other than the problem. The problem is that when starting the engine from cold, a sort of high pitched squeaky noise coming from the engine for 1 second. The car drives fine, no other noises when driving. Engine starts every time. It goes away after the car has warmed up. Friend of mine has a theory that the starter motor might need some oiling. Mine is a 1.4 petrol fabia comfort (AC) 100bhp 2000 87K on the clock. Anyone has any idea? Many thanks. Last edited by jiangleijay; 06-10-2008 at 10:49. |
| Woof! Join Date: Sep 2006 Location: From Leeds, Live in Swansea
| Re: Squeaky Sound Starting from Cold A belt slipping? |
| Re: Squeaky Sound Starting from Cold A new Cambelt has just been changed. |
| Briskodian Join Date: Jul 2008 Location: West Mids!
| Re: Squeaky Sound Starting from Cold |
| Re: Squeaky Sound Starting from Cold Which belt drives the A/C pump? |
| Briskodian Join Date: Dec 2004 Location: Hawkinge Kent
| Re: Squeaky Sound Starting from Cold My Octavia had a noisy starter motor bearing, could be that or the alternator belt? If its the starter then mine was like it (most of the time) for the 2 - 3 years i owned it, never got any worse. |
| Re: Squeaky Sound Starting from Cold Yeah friend of mine told me that as well. He says nothing wrong with the starter motor, if you change a new one it will do the same after a couple of months. In the long run, will it do any more damage to the engine? |
| Re: Squeaky Sound Starting from Cold As i say mine was like it for well over 2 years, whats the worse that can happen? bearing fails (but it would of got louder first as it was 'only' a noisy bearing) then the gear fails to mesh on the flywheel, so wont turn the engine over. IMO it was a 'risk' worth taking. |
| The Following User Says Thank You to Gizmo68 For This Useful Post: | jiangleijay (07-10-2008) |
| Briskodian Join Date: May 2006
| Re: Squeaky Sound Starting from Cold Had the exact same problem with mine, it is the starter motor. If your'e handy with a spanner theres a link to a brilliant step by step guide on vwvortex. It took me around 40 minutes and solved the problem. VWvortex Forums: DIY - Starter Motor Grind Fix and Starter Motor Replacement |
| The Following User Says Thank You to normanmatthew For This Useful Post: | jiangleijay (07-10-2008) |
| | #10 |
| Briskodian Join Date: Dec 2006
| Re: Squeaky Sound Starting from Cold Same here!.. it's like an "ERRRRRRRRE" buzzy squeal.. was my starter... had that car two years and it did it every so often.. Mechanic said it was fine and no need to change till it finally packed up.. it never did while I owned it and hopefully never will!
__________________ Current: Stock Black Magic Fabia vRS Previous: Stock Petrol Green Fabia Elegance (AUB 100bhp) |
| | #11 |
| old boiler Join Date: Feb 2007 Location: mids
| Re: Squeaky Sound Starting from Cold 87k - sounds like a drive belt slipping somewhere - they dont last for ever - i`d try the simple things first |
| | #12 |
| Re: Squeaky Sound Starting from Cold since when is a starter motor not simple? |
| | #13 |
| Re: Squeaky Sound Starting from Cold hi norman - listened to your link and yes - sounds like the starter motor - bendix drive is fkd - but if the chat means a really high pitched squeally noise i`d still go for a belt which is alot cheaper - |
| Cold Starting | tezza72uk | Octavia II | 7 | 15-01-2008 08:01 |
| bad starting when cold | explorer750 | Favorit, Felicia, Fun and Forman | 6 | 06-01-2008 14:25 |
| Poor cold starting... | iCraig | Octavia I | 5 | 27-12-2007 22:50 |
| VRS Cold Starting | rollerskate96 | Octavia II | 7 | 04-01-2007 21:51 |
| TDi Cold Starting!! | j44snk | Octavia I | 19 | 04-04-2006 10:41 |
