This is a discussion on Squeeging/ Scraping the inside of the Windscreen within the Fabia I forums, part of the Skoda Model Discussion Area category; Grrr. Anyone else in this cold weather having to scrape the inside of the window??? As i scrape off the ...
| Briskodian Join Date: Feb 2005 Location: Mid Beds
| Grrr. Anyone else in this cold weather having to scrape the inside of the window??? As i scrape off the ice on the outside i realise that there's a nice frosty layer on the inside! And when i leave from work the outside of the car is dry but i have heavy condensation on all windows. I'm not sure the air-con unit was designed as a de-humidifier! Bloody rear doors! Does anyone know of part numbers for the trim posts that seem to break when pulling the trim off as i can see i'm going to attack them again.
__________________ Fabia vRS forunner to the Bentley Continental GT Briskoda - Skoda's illegitimate family Mods: Superchip, K&N filter, Eibach springs, FSD dampers, black front grille, |
| | #2 | |
| Hiya Vic!!! Join Date: Feb 2006 Location: Sheffield, South Yorkshire
| Quote:
Sounds like you may have a leak...... Have you checked the carpets etc....... Also try and remember to change the blowers to point away from the widscreen before you finish using the car as this can also stop windscreen probs. I can't say i have any worse probs than other cars i've owned with our fabias. The best one we had for clearing the windscreen was the IS200..... That'd clear in a couple of mins max!!! Cheers Dave. | |
