This is a discussion on Steamed up windows within the Fabia I forums, part of the Skoda Model Discussion Area category; Every morning whenever its cold I get into my car, start the engine, switch on the heating and I'm off, ...
| Briskodian Join Date: Oct 2006 Location: Suffolk
Members Car: Fabia vRS Thanks: 29
| Steamed up windows Every morning whenever its cold I get into my car, start the engine, switch on the heating and I'm off, well actually I'm not, because in the time its taken for me to plug the seatbelt in the windscreen is coating in mist / steam. I don't think its the usual water leak problem, the carpets and mats are dry, and the windows are clear before I switch the heating on. It seems that the air-con unit is saving the damp air to deposit it on my windscreen as soon as I switch the heating on. I do about 20 miles each way to work a day, with the aircon button pushed on (even through I know its disconnected below a certain temp.) Is it worth switching it off? (the pollen filter is about 13k old - so it should be okay) Thanks. ![]() |
Members Car: Black Magic Fabia vRS Thanks: 347
| Re: Steamed up windows A lot of it depends on the humidity of the air outside when you get in the car. When you get out of the car, the air inside it will be fairly dry due to the action of the air con. The car gets cold overnightm and then the cold and moist air gets inside the car when you get in the in the morning, and so the moisture condenses on the cold surface of the inside of the windscreen. Even the moisture in your breath can fog up the inside of the screen if it's particularly cold outside. Keeping the inside of the screen clean will make a big difference, as any dirt will make the condensation a lot worse... HTH
__________________ |
| Skoda Junkie! Join Date: Apr 2007 Location: East Lothian
Members Car: Skoda Fabia VRS 130 Thanks: 387
| Re: Steamed up windows I suffer the same problem in mine David |
| Briskodian Join Date: Oct 2007 Location: Kilkenny, Ireland
Members Car: Fabia vRS Thanks: 37
| Re: Steamed up windows Have you tried the recycle / recirculate switch on cold mornings? It may appear to worsen the condensation initially, but in my experience, unless there is a dreaded water leak somewhere, recycle will clear the windows and heat the cabin faster than a constant flow of cold "fresh" air. Knock off recycle once screen and windows clear. |
| Re: Steamed up windows sorry see this as well... http://www.briskoda.net/forums/octav...ornings/93721/ and http://www.briskoda.net/forums/new-o...misting/93941/ Last edited by mathepac; 16-11-2007 at 15:51. Reason: added second link |
| Briskodian Join Date: Jun 2006 Location: Glasgow
Members Car: Fabia Thanks: 1
| Re: Steamed up windows When you park up at night, make sure the fan position switch is pointing at your feet (or anything that isnt the screen) that helps
| Re: Steamed up windows Thanks for all of your responses! So I've gotta now clean the inside of my car as well as the outside Think I might try some of the anti-mist-liquid that motorcyclist use inside their visors.I've tried using the recirc air button, but I get bored easily and end up switching between the two which can't help matters. Maybe I should try leaving it on feet only until its blowing out hot air... THANKS! |
| Briskodian Join Date: Sep 2006 Location: Rotherham
Members Car: Fabia VRS Thanks: 1
| Re: Steamed up windows Dont know if ur aware, but especially at this time of year the air con systems can remain damp after use and build up bacteria on them, usually giving off fusty damp smell, so this may be contributing to the problem and also make sure you clean your windows inside atleast once a month - I use Carplan Wonder Windows, and its magic - no smear marks and it removes tough stuff! Just a different angle again........ Hope it helps, Danny
__________________ ![]() VRS, ALL TORQUE! |
| | #9 | |
| Briskadoodian Join Date: Jul 2007 Location: Sweden
Members Car: Felly Estate 1.6 LXi 1998 Thanks: 50
| Re: Steamed up windows Quote:
What's next? Legionella disease? I've often regretted not having a/c on hot summer days but having read this Iäm beginning to think that I'm better off without it... | |
| | #10 |
| Re: Steamed up windows But are you not ment to test the air con once every so often as not to prevent bactaria building up. Davy |
| | #11 | |
Dunno - I read it on a flyer in a Skoda store, says it typically needs cleanin anually, or whenever you can smell damp and find the air con is not as effective.
__________________ ![]() VRS, ALL TORQUE! | |
| | #12 |
| Briskodian Join Date: Nov 2002 Location: Jammed up on her majesties highways
Members Car: Skoda Fabia TDi Hatchback Thanks: 0
| Re: Steamed up windows Been a problem with some Fabias for as long as I can remember. Try turning the vents to feet when you leave the car, improved mine...
__________________ Colin To come second is to be the first of the losers! |
| The Following User Says Thank You to flyingscot For This Useful Post: | gecko (20-11-2007) |
| | #13 |
| Briskodian | Re: Steamed up windows have you checked port and starboard plenum chamber drains? |
| | #14 |
| Re: Steamed up windows You wanna what with who now? ![]() The drainage holes beneath the windscreen, when drain into the engine bay? If so yes they're clear. I'm gonna try leaving it in the 'feet' position until its upto temp and then divert it to the screen. As it only seems to be the first few minutes where the vents deposit moist air into the car. |
| | #15 | |
Back on topic, the tip about changing the controls to point at your feet is good one, but if the temp is over 4c then just turn on the A/C and point straight at your screen and it will clear in seconds.
__________________ Manny 2005 Octavia 2.0TDi Elegance combi my skoda website http://www.octaviars.co.uk Join the briskoda.net folding team click Here for more info | |
| | #16 |
| Re: Steamed up windows But mine doesn't. Its clear when I get in, but turning on the AC on mists the windows up. Its as if the AC unit is storing moisture. |
| | #17 | |
| Briskodian Join Date: Feb 2006 Location: Exeter
Members Car: Red 06 Fabia vRS Thanks: 0
Worse thing you can do is use the aircon to get you out of the mess. Although it will quickly clear the screen that time, the next morning it will be terrible - water droplets on the screen above the vents. Best thing to do is avoid aircon and stick with it. Over a couple of days the car seems to dry its self out and should be okay. Before anyone asks I don't have any carpet issues etc! | |
| | #18 | |
| Briskodian | Re: Steamed up windows Quote:
If you decide to remove the plastic cover you have to remove wipers and pop the plastic studs out (they will prolly break) and then gently prise it off. | |
| | #19 |
| 2.0 FSI Sport. Join Date: May 2007 Location: oxon
Members Car: Octavia Mk2 FSI Sport Thanks: 11
| Re: Steamed up windows a strong jet hose can often sort out the leaf problem ![]() |
| | #20 |
| Briskodian Join Date: Feb 2005 Location: Mid Beds
Members Car: fab vRS Thanks: 0
| Re: Steamed up windows For me it takes a good 5 mins before i get any warmth out of the heater, therfore your just blowing cold air over the screen which then fogs over.
__________________ Fabia vRS forunner to the Bentley Continental GT Briskoda - Skoda's illegitimate family Mods: Superchip, K&N filter, Eibach springs, FSD dampers, black front grille, |
| | #21 |
| Briskodian Join Date: Apr 2006 Location: Berwick upon Tweed , Northumberland.
Members Car: Fabia 1.4 MPi Comfort Images: 1 Thanks: 19
| Re: Steamed up windows This problem seems to crop up every year on here at about this time , I dont think we are any nearer a solution that we were last year! In fact I can remember people talking about this when I had my vRS in 2001!
__________________ Duncan - England's most Northerly Briskodian! 2000/V reg Fabia 1.4 Mpi Comfort-Dynamic Blue Ex Octavia vRS and Octavia Slxi 1.8T. |
| | #22 |
| Briskodian | Re: Steamed up windows Regarding the AC filter, a friend of mine got tonsillitis twice within a month; the problem was traced to a bacteria-ridden AC filter that the dealers had failed to replace. They can get very filthy and it's important that they are kept clean. ![]()
__________________ Simon |
| Windows | smstext | Styling and Car Care | 12 | 27-05-2007 18:57 |
| electric windows?? | ANDREW MARK | General Car Chat | 2 | 06-12-2006 21:26 |
| Using Windows 98? | devonutopia | The Tech Shed | 17 | 11-01-2006 19:30 |
| Windows 98 SE CD | MrBump | The Tech Shed | 6 | 22-07-2005 23:23 |
| Windows 98SE & Windows XP - A call to techies | rich1068 | Off Topic and Chit Chat | 33 | 01-03-2003 12:56 |
