This is a discussion on Steering vibration within the Fabia I forums, part of the Skoda Model Discussion Area category; deleted...
| Briskodian Join Date: Feb 2006
| Steering vibration deleted Last edited by fatbob; 17-02-2008 at 16:36. Reason: spelling error |
| Briskodian Join Date: Sep 2006
| Re: Steering vibration I have had problems like this on other cars. I found that although I had the wheels balanced, the problem was still there because they were not balanced properly. I got them done again somewhere else and it worked. Also if you have gone to lower profile tyres its more noticable. |
| Briskodian Join Date: Oct 2006 Location: I am going to do what everyone else has done and type as much as I can so I can have a big big big box.I live in a little village in the middle of nowhere and hopefully you will not be able to find it as I would have to offer you a sweetie not good.
| Re: Steering vibration Agree with the above , you could also try swapping tyres from front to back , see if that works |
| | #4 | |
| Re: Steering vibration Quote:
Chris
| Briskodian Join Date: May 2006
| Re: Steering vibration |
| Briskodian Join Date: May 2006 Location: Medellin, Colombia
| Re: Steering vibration This might have been what Chris was stating (?), but I'll state it in case it wasn't. The only wheel balancing jobs that are really worth it are the ones where they place the weights at different depths and/or multiple locations (if necessary) inside the rim itself - where they are not linearly placed. The balance technique where the weight is on the outside of the rim (or placed in only one location inside the rim) is nearly useless. For me, rim and tire balance is important and I would pay extra to go somewhere where the technicians know what they are doing. |
| Re: Steering vibration deleted Last edited by fatbob; 17-02-2008 at 17:41. |
