39,433 Members 1,488,594 Posts
Still No Power Steering
This is a discussion on Still No Power Steering within the Fabia I forums, part of the Skoda Model Discussion Area category; A while back I posted the problems I was having with power steering ever since my window got smashed. I ...
Old 10-03-2007, 11:51   #1
Members Car:
I got a second hand PAS pump and got someone to replace it but there is still no PAS.
The orange light has been on the dashbord for a good six months.
Can driving like this cause problems for the steering rack? I am generally quite soft with the car.
Also - What will I need to do to get PAS back - I ve replaced the PAS pump without joy.
Joey122mac is offline
Old 10-03-2007, 13:06   #2
I parked up 1st
ric04vrs's Avatar
Members Car: silver Fabia VRS
Re: Still No Power Steering
instead of messing about spending money on parts that don't fix the job , take the car to a good dealer (if there is one) and let them sort it out , there must be fault codes in there somewhere ,
you've got VAGCOM haven't you , why don't go to the dealer with the list of faults , someone must be able to fix it
has Lummox got any thoughts on this ?
not so bored now
ric04vrs is offline
Old 10-03-2007, 13:08   #3
Cupra Bush King
Lummox's Avatar
Images: 2
Its needs diagnosis stlll then.
Simple enough to do.
Is there a live at the pump? Is there an earth at the pump? Is there an ignition live at the pump? If all of these are good then providing there isnt a CAN communication fault (easy enough to see in MBV) the pump should work with the diagnostics. This will give you a fault code to work on if its a sensor related fault.
The system is really simple, as long as it has a power supply and it knows you are turning the steering wheel it will work.
www.unit18.co.uk
Lummox is offline
Old 10-03-2007, 13:46   #4
Members Car:
Thanks guys
Whats MBV?
Old 10-03-2007, 13:58   #5
Cupra Bush King
Lummox's Avatar
Images: 2
Measured Block Values
www.unit18.co.uk
Lummox is offline
Old 10-03-2007, 14:42   #6
Members Car:
Just a though but if the car has logged the window smash as a crash it turns off PAS. Had this myself on my cupra just reset it using VAGCOM
yellowcupra is offline
Old 10-03-2007, 15:30   #7
Cupra Bush King
Lummox's Avatar
Images: 2
The crash sensors are mounted on the floor and in the airbag ECU, not sure if smashing a window would set them off (hazzards should also flash etc).
But a diagnostic test would point that out.
www.unit18.co.uk
Lummox is offline
Old 10-03-2007, 15:33   #8
Cupra Bush King
Lummox's Avatar
Images: 2
Just checked and indeed Fault code 01656 is crash signal and is sent via the airbag ECU.
www.unit18.co.uk
Lummox is offline
