suspension, shocks, bushes ???????
This is a discussion on suspension, shocks, bushes ??????? within the Fabia I forums, part of the Skoda Model Discussion Area category; hi. i think my suspension is goin on my car. any tips on how to know for sure. also what ...
Old 02-02-2007, 19:48   #1
hi. i think my suspension is goin on my car. any tips on how to know for sure. also what kind of things will need changing. the car makes a noise while going over speed humps which doesn't sound healthy. its not hitting underside of car. thanks
fabia145re-map is offline
Old 02-02-2007, 19:52   #2
Briskodiodion
TeflonTom's Avatar
Re: suspension, shocks, bushes ???????
first thing to check is the anti roll bar drop links.... these can make a terrible noise when the joints get worn or loose
TeflonTom is offline
Old 05-02-2007, 12:40   #3
Anders's Avatar
Unhappy more suspension...
My suspension might be bust too....
Damaged Arb brushes sure gives of a loud bang when going over speedbumps and on other rough surfaces. But as I myself have had the arb replaced replaced a year ago, I dont think that is my problem.
Could it be down to other brushes in the suspension setup, or is it more likely a damper/spring problem?
Its also not only the front messing up, but the rear as well...
Anders is offline
Old 05-02-2007, 14:33   #4
rider of sharks
sharkrider's Avatar
control arm bushes is my guess... I'm having mine replaced at the next service on wednesday common problem apparently.
Fiat Grande Punto Sporting (158 bhp 314 lbs/ft) in Red....
Furby vRS , black magic,passenger airbag de-activation switch, (now gone, but not forgotten!)
sharkrider is offline
Old 05-02-2007, 14:36   #5
Briskodiodion
TeflonTom's Avatar
not finshed yet but most of it is there
changing suspesion bushes
Old 05-02-2007, 14:44   #6
rider of sharks
sharkrider's Avatar
nice guide there If I had any tools and a garage I'd give it a go myself! lol...
Old 05-02-2007, 16:13   #7
Are the drop links different to the bushes?
If so is there a how to guide? And where you can order these drop links and how much they are?
Cheers
Joey122mac is offline
Old 05-02-2007, 18:26   #8
Briskodiodion
TeflonTom's Avatar
the drop link is a straight metal bar with a ball joint at each end
dont try to undo the nuts with the weight of the car still on the suspension... you will need an allen key(5mm i think??) and a spanner (16mm)
hth
Old 05-02-2007, 19:02   #9
Yeah - That makes sense - What would cause the drop links to need to be replaced and how are the inspected? If it is just a metal rod then where along the rod will they fail?
Am I missing something crucial here ?
Also how much would you expect a pair to be ? And finally how long would you expect them to take to install.
Cheers guys!
Old 05-02-2007, 21:36   #10
Om nom nom nom
Neo_VR's Avatar
The drop-links are a common problem, definately warranty... or even goodwill if the car is out of warranty.. other than that its a simple cheap job to do
ColGod the UberMod
,___,
[O.o]
/)__)
-"--"- ORLY??
Neo_VR is offline
Old 05-02-2007, 21:40   #11
Cupra Bush King
Lummox's Avatar
Images: 2
They have been modified.
As mentioned above they arent just a metal rod, its the ball joints at either end that give the grief.
Lummox is offline
Old 05-02-2007, 21:50   #12
Cheers guys
Any ideas where to pick them up from - Would I need to buy a new rod or is it just the ball joints.
Euro Car Parts didnt have them
Old 05-02-2007, 23:07   #13
Briskodiodion
TeflonTom's Avatar
no the ball joints cannot be seperated from the rod.... i paid £25 squids for a pair from my local motor factors.... iirc they are £17 each from skoda
