This is a discussion on timing belt and other belts within the Fabia I forums, part of the Skoda Model Discussion Area category; my mate at works has a 1.4 16v x reg fabia, last week the timing belt and tensioners had to ...
| Briskodian Join Date: Jun 2005 Location: bradford,w. yorkshire
| my mate at works has a 1.4 16v x reg fabia, last week the timing belt and tensioners had to be replaced at 55,000 miles i have the same model,engine and year. my car has done 48,000 miles so i'm a little worried.other then the timing belt are there others belts (fan belt,cam belt etc),so i could replace them at the same time ? it cost my mate about £200 from his dealer but i'll be going to an ex- skoda dealer so will be cheaper. thanks |
| the 16v has two cambelts both need to be changed. Have a look at the alternator belt, if its cracked replace it.
__________________ Unit 18 Automotive Services now open Servicing, repairs, modifications you name it we do it. Cupra console bushes at special price, PM for a very competitive quote. |
| 2 cambelts.blimey so 4 belts (timing,2 cams and alternator) thanks |
| Briskodian Join Date: Feb 2006
| timing belt and cam belt are the same thing
__________________ 2001 FANTASY GREEN SKODA FABIA F.T.M |
| | #5 | |
| Quote:
so 2 timing/cam belts and 1 alternator belt = 3 | |
| Briskodian Join Date: Jun 2004 Location: Bovingdon, Herts
| I'd get the waterpump replaced at the same time too. It's driven off the cambelt, if the bearings sieze in it, the cambelt could snap. Wise move to have the pump replaced whilst the belt is being done.
__________________ Furby 2.0 |
| Never had a 1.4 water pump go but why not if your feeling flush.
| | #8 | |
| Quote:
with and without the unbreakable water pump lol | |
| When I had a 16V Polo, same engine as Fabia I believe, it cost me about £400 a couple of years ago.
