40,596 Members 1,517,533 Posts
Turbo Problem
This is a discussion on Turbo Problem within the Fabia I forums, part of the Skoda Model Discussion Area category; morning all well here goes travelling home this morning 4am my car seemed to go flat in power and loads ...
Old 20-04-2008, 11:09   #1
DIESELTORQUE's Avatar
Members Car:
Turbo Problem
travelling home this morning 4am my car seemed to go flat in power and loads of black smoke out of the exhaust
the only time this as done this before is a burst intercooler pipe but checked this and also when i split my intercooler on the weld with presure
now the car goes in to limp and engine light comes on when i plug my dignostic machine in it says low boost presure, i can reset this then the car turbo kicks in for 5 sec then back to limp
DIESELTORQUE is offline
Old 20-04-2008, 11:11   #2
rider of sharks
sharkrider's Avatar
Members Car: Fabia vRS
Re: Turbo Problem
still sounds like a hole in the system somewhere rather than a turbo failure...... it boosts agains for a short while then back to limp....
could have missed a split in a pipe somewhere perhaps?
I read that samco are developing the hard pipes for the fabia vRS, maybe worth giving them a call?
Fiat Grande Punto Sporting (158 bhp 314 lbs/ft) in Red....
Furby vRS , black magic,passenger airbag de-activation switch, (now gone, but not forgotten!)
sharkrider is offline
Old 20-04-2008, 11:14   #3
Members Car:
Re: Turbo Problem
checked everything but when it boost up still not its was like before the problem its like its holding back
well the samco hose hard pipe may be a good idea for me but i need my car ok first
Old 20-04-2008, 11:36   #4
Members Car:
Re: Turbo Problem
all hoses ok but still no power then about 3000rph loads of black smoke still boost from turbo
any other ideas were to go from here
Old 20-04-2008, 11:40   #5
Members Car:
Re: Turbo Problem
I hate to say it dude but I think it is the turbo. My car did exactly the same when the turbo failed.
If your sure there is no leak then its likely the turbo is producing less boost then the ECU is requesting so its going into Limp Mode. The seals on the turbo could be on the way out or the VNT is not moving correctly - or too slowly.
2007 Fabia vRS - Cruise Control, Metallic Paint
Offerman is offline
The Following User Says Thank You to Offerman For This Useful Post:
DIESELTORQUE (20-04-2008)
Old 20-04-2008, 12:01   #6
Members Car:
Re: Turbo Problem
was thinking this my self
big money then, not re what has been done to the turbo as its jabba sports old car
Old 20-04-2008, 12:29   #7
Members Car:
Re: Turbo Problem
There is really only one thing you can do and thats take it straight back to Jabba for them to assess the situation.
Offerman is offline
Old 20-04-2008, 13:14   #8
Members Car:
Re: Turbo Problem
would do but im over 160 miles away from them neat liverpool will not make it there lol
all pipes checked
intercooler no splits ps dont get a pro alloy 1 split mine 2 times on weld
when for a run in car still no power but turbo works can here it and feel it a little then around 3500rpm loads of black smoke , like its getting 2 much air
Old 20-04-2008, 13:55   #9
lewisgraham's Avatar
Members Car: Yellow Fabia VRS
Re: Turbo Problem
Give jabba a ring in the morning and tell them whats the problem then see what the say......proberly the best bet as its there ex car
Skoda Fabia VRS in yellow, Stage two hybrid turbo/FMIC/miltek turbo back exhaust/sachs uprated clutch/brembo 4 pots/CDA air intake/KW coilover suspension/Audi S3 wheels
lewisgraham is offline
Old 20-04-2008, 13:56   #10
Members Car:
Re: Turbo Problem
UP DATE
after driving for 20 min still no ecu lights on ,but still same problem , so is this defo my turbo and were around liverpool can i get this tested
2nd run ecu light came on falt code reads turbo charger underboost,
same falt code as when i had a split pipe ,
also were my turbo used to kick in around 2000rpm now it seems to be more like 2500- 3000rpm before i can feel it working
any ideas would help
Old 20-04-2008, 16:45   #11
Mossman's Avatar
Re: Turbo Problem
Hmmmm... I can but offer similar advice.... I am sure Jabba will try and help out, ring them tomorrow and go from there.
Black Magic Fabia V/RS Xenons, Heated seats, Cruise, Cupra Front Splitter, new VRs badges, Koni FSDs, Eibachs, Jabba ARB, Jabba Remap, PD160 Intake and 312mm brakes + Detailed by Glyn O'Donnell
Black Magic Fabia V/RS Xenons, Heated seats, Cruise, Ecutek Remap, PD160 Intake (Yes I have two! )
Photography Marketing T shirts flickr
Mossman is offline
Old 20-04-2008, 21:32   #12
Members Car: Black Fab VRS
Re: Turbo Problem
hi
Have you had fuel pressure checked?? Not used to these engines + management but some vehicles when supplied with low pressure fuel cut the turbo pressure down thus inducing a low boost fault??!! because otherwise lack of fuel and high boost === burnt out valves pistons etc. only a thought
and are the turbo's on these variable vane if so maybe a sticking vane??
chris
chris888 is offline
Old 20-04-2008, 21:35   #13
Mongreller
devonutopia's Avatar
Members Car: Skoda Fabia Mongrel
Images: 5
Re: Turbo Problem
I would get the car vag-com'd first.
devonutopia is offline
The Following User Says Thank You to devonutopia For This Useful Post:
Old 20-04-2008, 21:51   #14
Members Car:
Re: Turbo Problem
were can i get this done around the liverpool area
Old 20-04-2008, 22:23   #15
Mongreller
Images: 5
Re: Turbo Problem
Familiar with the vag-com section on here? Looks like faboka_vrs is your nearest one.
http://briskoda.net/forums/diagnosti...ers-map/80992/
Old 21-04-2008, 11:04   #16
Members Car:
Re: Turbo Problem
just a thought could this not be my egr valve stuck open , carboned up making me less boost presure
Old 21-04-2008, 11:14   #17
skudmissile's Avatar
Members Car:
Re: Turbo Problem
take it to a garage mate, you dont have a clue as to whats causing the problem.
maybe if you joined freedom and posted in the ask a tech section you might get a better response
Run out of CASH
skudmissile is offline
Old 21-04-2008, 11:23   #18
Members Car:
Re: Turbo Problem
have tryed to join as i can sell my nitrous kit ect ect but no paypal acount
Old 21-04-2008, 11:32   #19
Members Car:
Re: Turbo Problem
Your green now, welcome aboard.
As you have said the engine runs with the intercooler pipe off so i dowt its a blockage of the egr valve.
The only thing up that end of the engine would be the anti shudder, but that wouldnt give a neg boost code and the car wouldnt run at all.
I think the only thing to do would be to check all the vac hoses for leaks, check the vac control distribution box (black box on drivers side wing top mount) and then its turbo time.........which is expensive.
EDIT Also the map sensors are not very good at handling high boost, mine went not long after and i think jason had problems with them. Might be worth a change to see if it makes a difference??
Run out of CASH
Old 21-04-2008, 11:39   #20
Members Car:
Re: Turbo Problem
i no lol hope its not checked the box mate no pipes off , and i was saving for a lsd as well but been made redundent 2 weeks ago grrr i all happens as one s
Old 21-04-2008, 11:44   #21
Members Car:
Re: Turbo Problem
do you have access to vag com then?
iirc you can test the turbo and actuator with it, runs a cycle through and you can hear the turbo spool up and watch the boost pressure on the measuring blocks
yup its gutting
Run out of CASH
Old 22-04-2008, 13:40   #22
Site Sponsor
Members Car: Audi A3 Quattro +
Re: Turbo Problem
The symptoms would suggest a boost leak rather than a turbo problem, a boost leak would cause excessive smoke and not permit the boost to meet its target, (triggering limp mode)
A turbo shaft failure would result in a huge amount of white smoke as the turbo oil feed pumps oil into the exhaust, if this was the case the sump would be emptied in around 4 mins.
The hybrids are far more durable than the standard units and not prone to shaft failure.
If you’re using the water methanol injection as a secondary injection and the car hasn’t been mapped for it this could cause the boost to spike (possibly blowing a pipe or seal)
Hope this helps you out,
If you get stuck give us a shout,
Luke.
412bhp of Audi Quattro power
SOLD; Red Fabia V/rs, 247 bhp 430lbft and still growing
www.eurocar-club.co.uk come join
jabba_luke is offline
Old 23-04-2008, 12:13   #23
Members Car:
Re: Turbo Problem
Luke.
HI ALL had on vag com today no prroblems there
they said my actuator is not moving like it should only just moving
i no this is linked to the turbo vains but no nothing else about this problem were do i go from here
Old 23-04-2008, 12:32   #24
Members Car:
Re: Turbo Problem
If the actuator is only just oving it means that either:
A) you have a vacumn leak on the pipe that goes from the vac distribution box to the actuator
B) the vac control box is faulty/leaking air
C) the actuator is leaking/ faulty
D) the VNT mechanism is stuck/ seized/ generally broken
So on that, id would be checking that you can move the actuator by hand, and check all the pipe work with regards to leaking vacumn
Good luck
Run out of CASH
The Following User Says Thank You to skudmissile For This Useful Post:
DIESELTORQUE (23-04-2008)
Old 23-04-2008, 16:28   #25
Members Car:
Re: Turbo Problem
could this just be carboned up as mt car dose smoke alot even when it was ok (black smoke that is )
« new rims | squeak »
