40,597 Members 1,517,574 Posts
urgent help needed!!! - strut brace problem
This is a discussion on urgent help needed!!! - strut brace problem within the Fabia I forums, part of the Skoda Model Discussion Area category; Hi currently in a spot of bother! bought myself a seat strut brace for me fabia vrs just been and ...
Old 22-05-2008, 14:29   #1
Members Car:
Hi currently in a spot of bother! bought myself a seat strut brace for me fabia vrs just been and bought myself a set of sockets and a torque wrentch to do the job. Lifted the solenoide thing out the way taken the suspension bolts out offered up the bar and the dam thing does not fit seems to be about seems to be around a 0.5-1cm short and twisted. car is parked on a mildly downward sloping drive at the moment.
Is it something I am doing wrong? Is the bar naff? Or more worring is it my car that is twisted?
Any ideas, thoughts would be greatly appreciated?
Thanks peeps.
hurricaine is offline
Old 22-05-2008, 14:33   #2
Jimb0's Avatar
Re: urgent help needed!!! - strut brace problem
Pics :-)
Wales' most Easterly Briskodian ;-)
Jimb0 is offline
Old 22-05-2008, 14:38   #3
Members Car:
Sorry no digi camera at the moment :-( I wonder if there are any chassis and/or bar measurements I could make to see if it is my car or the bar?
surely the chassis is not so floppy that trying to fit the bar on a mildly uneven drive on a gradual slope would cause a problem?
Old 22-05-2008, 14:39   #4
ASZ Eternal
ap0gee's Avatar
Members Car: Black Magic Fabia vRS
Should be a perfect fit AFAIK. Take a look down the long axis of the brace - that should tell you if it's twisted. Otherwise, put the car up on stands (on the jacking points) just in case it's something to do with the weight on the wheels??? Clutching at straws a bit there, though...
And, yeah:
ap0gee is online now
Old 22-05-2008, 14:49   #5
Left Briskoda
Members Car: Fabia vRS
Bolt it back together and get it somewhere flat just to rule that out.
Johnny50 is offline
Old 22-05-2008, 15:08   #6
Moderator
Bigw2069's Avatar
Members Car: Noddy Car
Images: 2
Mine wasnt quite a perfect fit, Solved it by undoing all the top mount bolts (2 on each) and drawing the bar down level. Almost a bit of brute force and ignorance to get ti on but it got there.
The arms that come off the main beam are not that rigid and could possibly be a little bent, persuade them otherwise
Bigw2069 is offline
Old 22-05-2008, 15:12   #7
ASZ Eternal
ap0gee's Avatar
If they're flimsy enough that a little leverage is all that's required to jig them, I don't rate their contribution to stiffening the chassis...
Old 22-05-2008, 15:13   #8
Left Briskoda
There's a thought.
Johnny50 is offline
Old 22-05-2008, 15:16   #9
Moderator
Bigw2069's Avatar
Images: 2
They have always been little more than a bit to tart up your engine bay IMHO, but where the rigidity comes in is when it is fixed at the four points, when its off the car then its a slightly different matter.
Not really the right thread but to sort the front of the car properly using strut bracing you also need the lower one done, otherwise you have a three sided 'square', and a 3 sided square has little strength until it becomes a triangle!, by that time your wheels wont be turning thats for sure
Bigw2069 is offline
Old 22-05-2008, 15:19   #10
Members Car:
Well parked the car on the flat and no difference still does not fit! It worries me the front bumper on my car has never been a perfect fit from the showroom could my car have been front ended intransit? Or am I being overly paranoid? Should I just get on with it and bend the bar?
Old 22-05-2008, 15:21   #11
ASZ Eternal
ap0gee's Avatar
If the suspension's that far out, I imagine there'd be a noticeable effect on the steering so you're probably OK. The bumpers are quite prone to sagging, being supported only along the back (and being extended on the vRS, of course...)
Old 22-05-2008, 15:22   #12
ultra_joel88's Avatar
Members Car: 04 Fabia vRS (180/300)
Mine didnt fit either, when I bolted it down on one side it was about 0.5cm too short to reach the bolts on the other side.
In the end what I did was remove all four bolts, bolt it down loosely on one side then I could pull it just about enough to cover the bolt holes on the other side and get the bolts in, they were at a slight angle though... but then as you tigthen the bolts the strut brace seems to "stretch" / "pull" over so the bolts go in straight
'04 Fabia VRS - P-Torque STG1, 312mm Brakes, Whiteline RARB, SEAT Sport Strut Brace, Pipercross Panel Filter & PD160 Intake, Pioneer and Infinity ICE, Custom exhaust system w/ de-cat, CCV Bypass w/ Catch Can, Swoosh Gauges, Window Tints
ultra_joel88 is offline
Old 22-05-2008, 15:28   #13
ASZ Eternal
ap0gee's Avatar
Sounds as though it needs to be under tension to work then, perhaps? Would explain how it could be capable of being bent, yet still improve the rigidity of the chassis...
Old 22-05-2008, 15:35   #14
I would say that when bolted in properly it is VERY rigid...
Old 22-05-2008, 15:44   #15
fletch555's Avatar
Members Car: '04 Red Fabia vRS
Mine also wasn't a perfect fit.....I tried everything, jacking the car up, pulling, pushing, squeezing, bending etc etc. In the end it went in but one of the nuts is on the wrong thread .
fletch555 is offline
Old 22-05-2008, 15:44   #16
Left Briskoda
Ah well, at least you're not alone with the problem.
Johnny50 is offline
Old 22-05-2008, 15:59   #17
Broom Broom!
Mort's Avatar
Members Car: Fabia vRS (red '03)
Hmmm, mine's adjustable, and when fitted I tightened it 'outwards' (ie pushing out) if these are all bent like this should I be tightening it 'inwards' to mimick this? Or should it not matter as it doesn't really do anything much anyway?
Fabia v/RS, in Red.
Green filter & Cupra Intake, TT brakes, Josh's Sumpguard, Jabba ARB, MOMO strut brace, Powdercoated alloys. KW v1's next...
Mort is offline
Old 22-05-2008, 20:42   #18
Members Car:
Hello just a little update!
I took the brace back to the seat garage where it came from and tried it on an ibiza which it was also miles out on. One of the mechanics had a go at putting on my car and came to the conclusion that this brace was so far out the amount of bending needed might cause the weld to crack. The garage has been very helpful and are going to order another one to see if it is any better.
It is a good 1cm plus too short i'm not impressed you'd think they'd make them all to a jig and then check the completed product! I reckon there is some guy who makes them in his shed in the back garden!!
Oh well such is life. Here's to hoping the next one fits! :-)
Old 22-05-2008, 21:30   #19
if not, get a forge
Old 22-05-2008, 22:35   #20
jasc1988's Avatar
Mines was also a tight fit. slacken them off and torque them up equally
Star Remap, BMC, Helix, 312's, Magnex, Vibratechniks mount, Allard Power Pipe,
VMaxx Coilies, CCV mod, Pikey Short Shifter, Stainless Boost pipes, Pikey arch mod, HID's, 17's, Heated Seats, Cruise
+ many more
jasc1988 is offline
Old 22-05-2008, 23:32   #21
VeeKar's Avatar
Members Car: black fabia vrs
I fitted one side (driver's side) and then pulled like mad at the other end while spinning the bolts in. Big difference felt straight away cant understand people who say it matters not?
VeeKar is offline
Similar Threads
strut brace ns_sullivan Fabia I 8 13-05-2008 10:34
strut brace nikos Fabia I 14 28-03-2008 13:34
Seat Strut brace vs. Forge brace jasc1988 Fabia I 13 25-02-2008 23:50
Strut brace RAJVK Fabia I 5 25-10-2006 17:30
