This is a discussion on Vrs - Want to plug in Jukebox - How? within the Fabia I forums, part of the Skoda Model Discussion Area category; I have the standard radio/cd fitted in my Fabia. I have a Creative Jukebox 3 (20 gig) that I want ...
| Briskodian Join Date: Mar 2005 Location: Kent, UK
Members Car: Skoda Fabia Sport Thanks: 1
| Vrs - Want to plug in Jukebox - How? I have the standard radio/cd fitted in my Fabia. I have a Creative Jukebox 3 (20 gig) that I want to plug it into the spare auxillary point at the back of the radio, which I understand it must have because you can plug a CD changer in. I asked the Skoda Dealer where I bought the car (this useless idiot who couldn't give a **** because he has sold the car and now he doesn't care anymore), and he told me that Skoda's auxillary point is not standard, and that I should chat to a radio specialist. - Gee Great!!! Bluespot offer the following Blaupunkt auxiliary input, but I think this only fits on a Blaupunkt DAB radio. Is there such a cable for the Symphony in my car? and if so, where can I get it from? and How easy is it to remove the radio, fit the cable, put the radio back in place. Cheers, and I look forward to the replies. Mike Last edited by Mike_Vrs; 18-05-2005 at 11:12. |
| Briskodian Join Date: May 2004 Location: Basingstoke
Members Car: 2004 Fabia vRS Thanks: 0
| The aux inputs to the headunit are muted until the headunit see's a CD changer connected. You can buy an interface box which fools the headunit into thinking a CD changer is connected or for a cheaper DIY solution try this link (it works on my Symphony radio) http://www.k9spud.com/vwcdpic/
__________________ Matt Fabia V/RS Black Magic |
| | #3 | |
| Briskodian | Quote:
cheers ![]() PS. where did you find out your Symphony was made by Technisat? is it written on the top or something if I take it out? Last edited by looking_to_buy; 18-05-2005 at 20:28. | |
| Engerland-Maybe Join Date: Feb 2004 Location: High Wycombe...not the horrible built-up bit though. I'm out in Walter's Ash on the edge of the Chilterns. Beautiful countryside - f*%king expensive houses :(
Members Car: Yellow Octy vRS (to match my shoes) Thanks: 1
| I know you said the you are fed-up with the FM transmitter...but I have recently seen this review for a digital transmitter which (apparently) is easy to use and doesn't drift off.
__________________ Si The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go wrong goes wrong it usually turns out to be impossible to get at or repair - Douglas Adams |
| Briskodian Join Date: May 2005 Location: south west uk
Members Car: Fabia vRS (Silver) Thanks: 1
| I have an FM modualtor in my astra (soon to be Fabia vRs) and the wife has like wise in hers The are wired in and provide very good sound an awful lot better than the old plug in or battery modulators. When you turn it on it blocks radio signal on one of the 2 freqs you can choose. See below link any further questions just yell http://www.maplin.co.uk/Module.aspx?...4128&doy=18m5D |
| | #6 | |
| Where can I buy this device from? Hey Matt, And you have this device on your Fabia Vrs???? Did you buy it from that site you quoted below? Why I ask, on the site it actually says "New orders are no longer being accepted for this product as of July 11th, 2004."... so if this is the case, where did you buy this device from? Cheers for answering my questions, Mike Quote:
| | #7 | |
| Briskodian | Quote:
__________________ Rich. Skoda Octavia RS | |
| Briskodian | just took out my headunit on saturday there mate. used blunt hacksaw blade cut in half obv so i had 2 bits. read it in some other post. worked fine. just need to 'tempt' it out |
| | #9 | |
| Hi Steve, Do you have a symphony headunit? Does it have the auxillarys mentioned in the previous mail, and do you think the Blaupunkt auxillary connectors http://www.bluespot.co.uk/stock/auxin2.asp could connect to them? How many cables are at the back of the headunit? Cheers, Mike Quote:
| | #10 |
| Briskodian | dunno to be honest... it says 'These leads are only suitable for radios equipped to accept two auxiliary inputs. Single aux-input radios should use aux-input lead (1st).' on the back of the headunit, theres a circular connection port, similar to those on tvs, for the radio. irrelevant theres 3 outputs, but 2 are used by the stereo when just connected. the third output is slightly bigger tho. dunno |
| | #11 |
| Briskodian | so has anyone with a symphony braved these yet then? :s |
| National Briskoda Trackday | delcac | Shows | 410 | 12-03-2004 15:21 |
