40,614 Members 1,518,189 Posts
vRS Wheel Bolt Caps
This is a discussion on vRS Wheel Bolt Caps within the Fabia I forums, part of the Skoda Model Discussion Area category; Going through the process of taking the vRS wheels off to clean and polish them and thought the plastic caps ...
Old 24-07-2008, 22:49   #1
Members Car: Fabia vRS
vRS Wheel Bolt Caps
Going through the process of taking the vRS wheels off to clean and polish them and thought the plastic caps are a PITA to remove - I assume the bent bit of wire in the tool kit is used to hook them out? Its quite difficult to do without damaging the wheel. Wouldn't fancy doing it in the pouring rain at the side of the motorway!!
Is there a certain technique? Are there any alternatives - Golfs appear to have a cap with an allen type fixing?
Ian
Wrightpayne is offline
Old 25-07-2008, 00:02   #2
BJM
Re: vRS Wheel Bolt Caps
Nut cap removal pliers
KS Tools Part No. 150.2023
£15
BJM is offline
Old 25-07-2008, 00:20   #3
Moderator
Bigw2069's Avatar
Members Car: Noddy Car
Images: 2
there was a black plastic "U" shaped clip in my toolkit in the boot for removing them
Bigw2069 is offline
Old 25-07-2008, 00:32   #4
LG'S VRS's Avatar
Members Car: Fabia VRS
Same here. The clip has lugs either side which grips onto the wheel bolt cap. Also makes it easier to put them back on. I think the bit of wire is for removing the wheel trims IIRC.
Regards.
LG'S VRS is offline
Old 25-07-2008, 00:48   #5
Escorted Estate
Indeed - putting them back on is a piece of cake - just push them on
WW --->> Project Journal (pic links in first post there)
Lummox'/Ross thread on Unit18 Automotive progress on my car: here
WW_VRS is offline
Old 25-07-2008, 09:39   #6
dxg
Members Car:
It is for this reason I now have a pair of needle nose pliers in my toolkit. My kit had the wire hook (which is meant for alloy wheel centre caps) and a space for the plastic gripper tool - not very helpful.
It's not fun trying to get these things off when you've got a nail through the side wall and you need to get home.
Co-incidentally, I have VW's version of these caps on another car. They actually do come off with the wire hook that Skoda provide, but only because they have a hole in the centre of the caps to let you do this.
dxg is offline
Old 25-07-2008, 09:54   #7
fixer of things
jonnycatbiscuit's Avatar
I've got a little yellow plastic tool to remove them. It came out of my Peugeot 206 so cost nothing. has two clips that attach to the nut cover and pull it out. Simple.
Doctor Jonnycatbiscuit can fix all of your problems... Oh yes he can!
jonnycatbiscuit is offline
Similar Threads
Vrs wheel centre caps & steering wheel NOTHING LEFT - ALL GONE! MAS Group Buys and Promotions 64 02-10-2006 10:02
Fabia Wheel bolt caps bertJ Maintenance & Performance 8 02-03-2004 12:12
vRS Alloy Wheel Bolt Caps -How to Keep Them On? Steve vRS Maintenance & Performance 2 08-02-2004 22:17
