This is a discussion on VRs Whistling Noise under Acceleration within the Fabia I forums, part of the Skoda Model Discussion Area category; 06/06 Fabia VRs (52k miles)... I am getting a metallic whistling noise under acceleration around 2100revs which is worse when ...
| Briskodian | VRs Whistling Noise under Acceleration 06/06 Fabia VRs (52k miles)... I am getting a metallic whistling noise under acceleration around 2100revs which is worse when I use a higher gear. By way of example, if I accelerate hard in 6th it occurs on every occasion, but in lower gears it is less obvious. It doesn't sound like a turbo whine but I'm no expert. The car is not modified in any way and I want to make sure I get rid of the noise before the car runs out of warranty at 60k. Grateful for any suggestions as to the likely cause Thanks |
| Briskodian Join Date: Mar 2008 Location: South East
Members Car: Skoda Fabia vRS Thanks: 2
| Re: VRs Whistling Noise under Acceleration I am guessing it's the DMF if the car vibrates as well? Mine also whistles under hard acceleration but I put it down to the turbo.
__________________ '05 Silver Fabia vRS ~ Xenons ~ Cruise ~ Sunroof ~ Dension Ice Link ~ Aero Wipers ~ Proxes T1-R ~ vRS Steering Wheel Badge & Centre Caps ~ Briskoda Sticker |
| Briskodian | Re: VRs Whistling Noise under Acceleration Have you run a diagnostics on it just in case it's thrown up a fault code. Last edited by djswivel; 14-08-2008 at 17:59. Reason: I'm stupid. |
| Briskodian Join Date: Jan 2007 Location: South Wales
Members Car: Fabia vRS Diamond Silver Thanks: 1
| Re: VRs Whistling Noise under Acceleration If you try the search you will find that this is perfectly normal.
__________________ Mods to date - Angel Remap, Green Cotton filter, Jabba ARB, 9mm EGR Gasket |
| The Following User Says Thank You to markyvrs For This Useful Post: | BATS (14-08-2008) |
| Briskodian Join Date: Dec 2007 Location: Chippenham
Members Car: 53 Fabia vRS Thanks: 25
| Re: VRs Whistling Noise under Acceleration Mine whissles, but its just the turbo spooling up. Its worth having it checked. But before you take it anywhere, just make sure all the boost pipes are well connected, incase its leaking boost. HTH, Dave
__________________ '53 Fabia vRS. Pro Race 2's, PD160 intake, Green Cotton Filter, Pikey Intercooler Mod x2, 312mm Brakes. Debaged Rear End. Fixed The Rear Door Leak! Soon for sale?? |
| Briskodian | Re: VRs Whistling Noise under Acceleration Thanks All I'll get the dealers to have a look at it for me; they've been really helpful at Winchester ! B |
| VRS smoking and whistling. | ns_sullivan | Fabia I | 35 | 12-08-2008 12:32 |
| Strange noise on acceleration oct 2.0 | OCTAVIA2008 | Octavia I | 7 | 09-05-2008 12:31 |
| Acceleration Noise | robxlvideo | Octavia II | 16 | 31-03-2008 13:17 |
| Whistling Noise | vegasking | Octavia II | 15 | 22-01-2008 19:51 |
| hissing noise from vRS under acceleration | rpm | Octavia I | 15 | 22-02-2007 15:50 |
