40,614 Members 1,518,189 Posts
Want to horribly de-gut my cat.....
This is a discussion on Want to horribly de-gut my cat..... within the Fabia I forums, part of the Skoda Model Discussion Area category; Sounds rather vicious eh? Thinking about taking off my downpipe/cat and taking an 8mm 2.5 foot long masonry drill to ...
Old 02-10-2006, 18:45   1 links from elsewhere to this Post. Click to view. #1
Hardcore
Basil's Avatar
Members Car: Fabia vRS
Talking Want to horribly de-gut my cat.....
Thinking about taking off my downpipe/cat and taking an 8mm 2.5 foot long masonry drill to the insides....
Is it a simple matter of undoing some bolts to get the cat out or is it a slash-and-cut job?
I read a post somewhere that after you do this, you get an initial blast of smoke as the increased airflow knocks out the carbon, but it shouldn't make the usual idling/cruising exhaust any smokier?
Advice/opinions/comments/lewd suggestions welcomed.....
Cheers
Bas
Fab vRS - Black Magic - PD160 intake - Forge FMIC - colour coded front grille -SLC Splitter - K&N Airfilter -SEAT Strutbrace - Jabba ARB - IC Waterspray (need to wire it in!) - 312mm TT brakes - Eibach Springs - Skoda Reversing sensors - Devonutopia Tuning (tm) Custom Exhaust (2 1/4" straight pipe) - Short shifter mod- 5 brake light mod - Helix Steel SMF + Organic Clutch + pressure plate - Peloquin LSD - TD stage 2 Hybrid - Washbrook remapped ECU - Uprated injectors - Cupra bushes -Poly-filled dogbone - Allard racepipe - Pirelli Dragons - Forge Rear Strutbrace - DIY SS upper boostpipe delete -Koni FSD's - elephant pipe CCV mod
Basil is offline
Old 02-10-2006, 19:12   #2
splash!!!!
bengie's Avatar
Members Car: 4x4 turbo estate
Re: Want to horribly de-gut my cat.....
surely you could easily get a straight bit of pipe to replace it?
owner of a skoda octavia 4xvrs3
bengie is offline
Old 02-10-2006, 19:14   #3
HellFire's Avatar
Members Car: Skoda Fabia vRS
whats the point though really?
might aswell just get a full turbo back exhaust system if you want any kind of performance gain.
Metro Blue '06' 5 Door Astra 1.8 SRi
HellFire is offline
Old 02-10-2006, 19:28   #4
Hardcore
Basil's Avatar
Agreed - but figure the cost of a turbo-back system with shipping out to the middle of nowhere, and you'll see the allure of a nice DIY jobbie......
It really is the slippery road to a straight pipe system (ala Jason) but in a logical (???) progression.
Is it difficult to unbolt the offending section of pipe?
Basil is offline
Old 02-10-2006, 19:55   #5
King Rat
vRSLen's Avatar
Members Car: MK11 Octavia vRS
Basil, do you actually need an exhaust sytem were you live? Could you not just
remove it from the turbo back?
Current car: Black MKII Octavia vRS Combi
Previous: Black MKI Octavia vRS Combi
Black Fabia Elegance 100 BHP
vRSLen is offline
Old 02-10-2006, 20:30   #6
Mongreller
devonutopia's Avatar
Members Car: Skoda Fabia Mongrel
Images: 5
IF you have to do it this way - get yourself some good bit of pipe with good clamps to go over the exhaust where you cut it. Chop it just below the cat, then undo the three bolts on the turbo / manifold, above the downpipe (tricky to get to IIRC - might be easier from underneath or from the top - not sure) Actually might not need to unbolt it here. You might be able to undo one of the exhaust hangers and bend it down enough.
Then, attack the honeycomb from the tailpipe side you chopped through, and run the engine a bit to blow it all out (it might sound nice and fruity ) Then put the clamp over the exhaust on the tailpipe side, slide right down, push the empty cat section back in line, and put the clamp over it 50:50 to rejoin. (or just weld it if you know someone, or can weld?)
Personally I would use a decat pipe similar to the one I had. Link to folder below.
Index of /jason/DECAT PIPE
devonutopia is offline
Old 02-10-2006, 21:01   #7
tonto kowalski's Avatar
What does removing/mutilating the cat do to the emissions?
Will the car pass the MOT?
tonto kowalski is offline
Old 02-10-2006, 21:13   #8
Partner
Lummox's Avatar
Images: 2
CAT is not required for MOT, as long as it still passes the opacity test your fine.
www.unit18.co.uk
Lummox is offline
Old 02-10-2006, 21:28   #9
Mongreller
Images: 5
What the wise one said. Mine's got through 2 MOTs with nothing more than basically a scaffold pole for an exhaust.
LinkBacks (?)
LinkBack to this Thread: http://briskoda.net/fabia-i/want-horribly-de-gut-my-cat/63330/
Posted By For Type Date
Fabia - BRISKODA - The Skoda Forum and Community This thread Refback 02-10-2006 20:58
