This is a discussion on Warm up time for diesels within the Fabia I forums, part of the Skoda Model Discussion Area category; I have a 1.9 standard TDI and have done about 76k miles from new. From the start the heater took ...
| Briskodian | Warm up time for diesels I have a 1.9 standard TDI and have done about 76k miles from new. From the start the heater took a fairly long time to produce much hot air, and on complaining about this to the dealer, and asking if the thermostat could be changed, I was told that it was a characteristic of the PD engine. I have heard others comment on this also. My car is a 2001 model. I was wondering how quickly other members cars heaters warm up. I should mention that the temperature gauge takes about 10 minutes of normal running to come up to the straight up and down "normal" position and once there, it never varies however hard or lightly the car is driven. Also, once showing normal on the temperature gauge the heater output is good. Do the more modern models heat up more quickly than this? |
| The Following User Says Thank You to citroenzx For This Useful Post: | Quentin (01-11-2007) |
| Briskodian | Re: Warm up time for diesels My Furby vRS usually warms up on these cold mornings after being driven for around 5-10 mins depending on speed. Driving at 50mph, you should reach working oil temperature in 5 mins. Town driving, it might take about 10 mins, sometimes more if I'm idling a lot as the TDI doesn't warm up through idling.
__________________ Simon |
Members Car: Skoda Fabia Mongrel Images: 5 Thanks: 79
| Re: Warm up time for diesels I believe all the PD diesels take a fair time to warm up. The dealer is right. It just takes some time for the engine to warm up, perhaps because it's cast iron. I went from pd100 to pd130 in the same chassis and noticed no extra speed in warm up times between the old and new setup. ![]() You should find "some" heat starts coming out though before the needle hits vertical on the gauge. The gauge is useless as a measure though. I've fitted a water temp gauge whihc is only about 4" away from the oem sender, and I've seen temps from a constant 65 degC up to over 100 degC, and the gauge has been rock steady. I think it's a "lazy" gauge if that's the correct terminology?
__________________ Jason - Only a Skoda. Custom Fabia Bonnet Lifter Kits - £45! Click Me. BRISKODA CLUBSTAND @ Castle Combe! 25/04/09! Track session too! Click me! See the mongrel's 260bhp Dyno Video! |
| | #4 | |
| Nuts Join Date: Nov 2006 Location: Greater Manchester
Members Car: Fabia vRS Thanks: 151
| Re: Warm up time for diesels Quote:
This was highlighted for me on our old car (Cavalier 1.7TD) - gradual (unnoticed really) decline in heating performance until the icy weather hit and it was taking soooo long to get good heat (full teeth chattering job driving anywhere). Changed the thermostat and - ah, paradise
__________________ "Stupidity, if left untreated, is self-correcting." - Heinlein | |
| | #5 | |
| Briskodian Join Date: Sep 2005 Location: Fife
Members Car: Bright Yellow VRS Thanks: 3
![]() National | |
| Re: Warm up time for diesels The thermostat ![]() You pinching my lines now ![]()
| Briskodian Join Date: Oct 2007
Members Car: fabia 1.9TDi (100bhp) Thanks: 81
| Re: Warm up time for diesels The wife's 1.9TDi takes about 10 minutes to warm up (both cabin and engine), whereas my petrol 1.4 polo warms up in 3 minutes! Used to drive a golf TDi which also took a bit of time to warm up. IMHO it warms up faster with the Aircon on. There's 2 solutions to this - if you have an Elegance spec then whack the seat heaters on (although backseat passengers will need to keep their gloves on!). Otherwise, there are some companies out there that make pre-heaters which will warm up the car even if it hasn't been started (you even get remote control operation to start the pre-heater without leaving the house). More at: PreheatersI have a contact at that company and will ask for a bit more info on suitability for Fabia diesel. ![]() |
| Skoda Junkie! Join Date: Apr 2007 Location: East Lothian
Members Car: Skoda Fabia VRS 130 Images: 4 Thanks: 454
| Re: Warm up time for diesels Mine takes about 10 minutes to warm up from the time I leave my house to where I pick my girlfriend up, by that time the heater is roasting. David |
| Briskodian | Re: Warm up time for diesels Diesel engines take longer to warm up than petrol engines. 5-10 minutes to come up to full operating temerature is about right. As Jason pointed out, some heat will come through much sooner. |
| | #10 |
| Re: Warm up time for diesels What I tend to do in my fabia is point the air to the windscreen first thing and then gradually wait till it warms up when I switch it to the cabin and then hit the recirculation button to pump more hot air into the cabin. Once I feel the cabin is warm enough I turn the heater down. David |
| | #11 |
| Briskodian | Re: Warm up time for diesels There is a VAG standard on the characteristics of the coolant temperature gauge. Done to ensure that the majority of the time its sits right in the middle. So take its reading with a pinch of salt unless it is indicating an extremity of the scale. |
| | #12 |
| Briskodian Join Date: Sep 2006 Location: Walsall
Members Car: Leon TDI DSG or Lupo 16v Sport Thanks: 115
| Re: Warm up time for diesels Diesels take a while to warm up, but the PD130 in the Fabia is *far* quicker than the VE-pumped 110 I had in an Audi A3. |
| | #13 |
| Briskodian | Re: Warm up time for diesels seem to remember you can get an engine pre-warm kit, I can find the link on google if you are interested. It's like a mini heater. |
| | #14 |
Members Car: '97R BMW 328i Saloon Thanks: 728
| Re: Warm up time for diesels There are all sorts of pre-heaters available, from ones you plug into a mains socket, to remote contolled diesel powered ones from the likes of Webasto. None are cheap though, and may be tricky to fit.
| | #15 |
| Briskodian | Re: Warm up time for diesels Thanks to all for your comments and experiences - it sounds as though my car might benefit from a thermostat change. The comments regarding pre-heaters bring to mind one of the major dissappointments I had when I first got the car. Before buying, I looked at a road test report in Diesel Car which mentioned a factory fitted (I thought standard) pre-heater. The article didn't go into details but merely commented that the car was very quick to produce hot air to demist or de-ice the windows on starting from cold. The car they tested had some sort of electric heater - again I am not sure whether it was an electric element in the demister vents or whether it was an electric element in the car heater heat exchanger. Suffice to say that my car wasn't fitted with this device and when I asked the Skoda dealer if it was available as an after-market add on, he said that it was only availble as a factory fitted option but only in cold countries - not GB. Has anyone got one of these - Skoda might have started fitting them on later up-market models. |
| | #16 | |
| Mmm Skodacious! Join Date: Jun 2007 Location: West Cumbria
__________________ If this post can be interpreted in two different ways, it was meant the good way! Fabia VRS 180 Angel Tuning re-map, Jabbasports rear ARB, PD160 air intake pipe and Green cotton air filter, Millers Diesel Power Sport 4 fuel additive, Briskoda sticker (front and rear windscreen), Navman F20, set of Rosary beads blessed by the pope! | |
| | #17 | |
| | #18 |
| | #19 |
| Briskodian | Re: Warm up time for diesels I agree about the 10 minutes to warm up, and not warming up at all if you are idling! 50mph plus and it is much quicker to warm up. I agree with this too, it is in the middle ALL the time, I think so unless there is something really wrong it will not go up I suppose not to worry you. Much different to my old Peugeot 306 where the gauge would exceed 90 if charging up a long hill on a hot day or stuck in traffic until the fans came in, and drop right down to about 70 if you are going down a long hill on overrun! I also knew immediately when there was a problem as the gauge didn't behave as normal and started rising and rising, and I was able to stop before any proper overheating damage was done (water pump failure). |
| | #20 |
| Volkskodian Join Date: Dec 2005 Location: Edinburgh - "Bonnie Scotland"
Members Car: Fabia 1.9TDI Elegance Estate 140 BHP & Golf 1.9Tdi 180 BHP both remapped by Angel Tuning Thanks: 7
__________________ Some say their glass is half empty, others say their glass is half full. I say, ...... are you going to drink that ? |
| How Do You Drive Diesels | Quetz VRS | General Car Chat | 30 | 09-03-2007 12:06 |
| Anyone know about Nissan Diesels? | nokiauk | General Car Chat | 2 | 01-05-2006 08:54 |
| 110TDi heater warm up time | mbames | Octavia I | 16 | 23-11-2005 17:07 |
| how do diesels work ? | mcbunny | Fabia I | 5 | 10-02-2005 10:45 |
| Fabia vRS warm up time | chris-P | Fabia I | 44 | 07-01-2005 15:43 |
