This is a discussion on Warm Weather & the PD 130 Engine within the Fabia I forums, part of the Skoda Model Discussion Area category; Is it just me or is the old 130bhp PD TDi not fond of the warm weather that we have ...
| Briskodian Join Date: Jun 2005 Location: South Lakes (Grange Over Sands)
Members Car: Octavia II VRS (2.0L PD TDI) Thanks: 70
| Warm Weather & the PD 130 Engine Is it just me or is the old 130bhp PD TDi not fond of the warm weather that we have experienced in the North West today . Drove to work this morning when it was cool and it was its usual fairly refined, smooth and powerful self ![]()
__________________ 2007: Octavia II VRS TDI in Black Last edited by Johnwg; 08-07-2005 at 19:46. |
| | #2 | |
| Briskodian | Quote:
![]() I'm a shandy-drinking southern fairy but I agree
__________________ Fabia has SOLD! Weekend car: Cooper Green TVR Chimaera Daily driver: Carmine Red Vauxhall Omega... 2.0 LS... Auto... Estate... with towbar & drinking problem | |
Members Car: Ford Escort 1.6LX + Fab Estate Thanks: 48
| It's why I will be signing up for the FMIC GB as soon as Neo_VR has finished help testing it ![]()
__________________ WW --->> Project Journal (pic links in first post there)Lummox'/Ross thread on Unit18 Automotive progress on my car: here |
Members Car: Fiat Panda Thanks: 16
| It's a result of heat soak. Either go for a FMIC or opt for a water-spray system to keep the existing intercooler ... er ... cooler ![]() Chris
| Briskodian Join Date: Jan 2005
Members Car: Vauxhall Astra VXR Thanks: 1
| Can you actually see soot in the rear view when you boot it because I dont notice any or a drop in performance ![]() |
| Briskodian | Notice mine is lacking somewhat in the heat, but not noticed any excess soot!!! |
| | #7 | |
| Quote:
__________________ 2007: Octavia II VRS TDI in Black | |
| Om nom nom nom Join Date: Feb 2003 Location: Manchester
Members Car: A White Car Thanks: 85
| Go on then... heres what ya need to cure it ![]() |
| | #9 | |
| Quote:
| | #10 | |
| Quote:
Sounds like some sort of new bath foam from Radox !!!
| | #11 |
| Its made out of alloy, so ill bet it weighs less than the original (small) sidemount item... it weighs about 2 or 3kg.. Its a front mounted intercooler. it cools the air that goes into the engine ![]() Heatsoak is when the engine is affected by the heat of the air going into it.. because hot air is less dense, so doesnt combust as strongly, the engine has to start lowering turbo boost levels and fuelling to keep optimal running.. which to the driver feels like the engine is being lethargic and down on power.. my front mount cools the air alot, so everyday is like a ice cold winter morning for me.. car is always running at its most efficant ![]() Last edited by Neo_VR; 08-07-2005 at 23:52. |
| | #12 | |
| Quote:
| | #13 |
| VT5 Join Date: Dec 2002 Location: Warwickshire
Members Car: Fabia vRS Thanks: 0
| Is that the 50mm depth version there Colin? - i see the mounting lugs seem to have been adjusted - looks better..
__________________ Was: 2003 Allard Tuned Fabia vRS VT5 Turbo Conversion Now: 2008 Audi A3 Sportback TDI |
| | #14 |
| Matt: yes it is the 50mm ver. mounting lugs are same, but the whole i/c is lower down.. leaves scope for adjustment ![]() Johnwg: no worries.. im not exactly up on the tecchy knowledge either.. it looks good and works well... this one is nearing 3x the capacity of the standard side mount.. Its not custom built, its the development model for Forge.. who will be running a briskoda group buy on them soon ![]() |
| | #15 | |
| Quote:
__________________ Was: 2003 Allard Tuned Fabia vRS VT5 Turbo Conversion Now: 2008 Audi A3 Sportback TDI | |
| | #16 | |
| Quote:
![]() We have to make sure its ready to unleash to the good briskodians.. its about getting a balance between cooling efficience without causing too much turbo lag.. it could swing either way at the moment. ![]() | |
| | #17 |
| Briskodian | Mmmm BFOFMIC!!! Me Want ![]() |
| | #18 |
| Broom Broom! Join Date: May 2005 Location: Derby, England
Members Car: Fabia vRS (red '03) Thanks: 9
| If possible, please keep testing until my bank account is healthy enough to have my name on the Group Buy. ![]()
__________________ Fabia v/RS, in Red. Green filter & Cupra Intake, TT brakes, Josh's Sumpguard, Jabba ARB, MOMO strut brace, Powdercoated alloys. KW v1's next... |
| | #19 |
| What kinda timescales are we talking about, roughly? One or two months tops ?
| | #20 | |
| Briskodian Join Date: Aug 2004 Location: Essex
Members Car: fabia vrs Thanks: 1
| Quote:
__________________ '54' Black Magic Fabia vRS Yo Adrien I DID IT!!! | |
| | #21 |
| Depends on how you drive it too - but even I noticed it smoking badly, and normally I hardly ever get that. The car is definitely slower / prone to heatsoak during warm days when you do a bit of accelerate/slow-cycling..
| | #22 |
| Yes it does depend how you drive it.. There is definately a performance drop in hot weather.. the engine seems "wooley" and sluggish.. it will smoke a bit more.. but just wait if you get intake or fuel temps up to the 90c trigger temp ![]() |
| | #23 | |
| Briskodian | Quote:
| | #24 |
| Briskodian | Mine is smokin badly above 4k in this warm weather but it's only in 4th and 5th, havn't tried it in 6th. Must be when the load / drag increased, it's enough to put other drivers off driving too close. ![]() |
| | #25 |
| Diesel not burning properly causes the smog screen stuff ![]() If you plant it at low revs in a high gear you'll see what I mean. Better to drop a cog, rev it up a bit more. @black magic - I'd hope you dont get up to 4k in those gears on a public road ![]()
