This is a discussion on washer jets seem out of line..... within the Fabia I forums, part of the Skoda Model Discussion Area category; Although I know they are static and cannot be moved...... I have recently had the windscreen replaced and now I ...
| Briskodian | washer jets seem out of line..... Although I know they are static and cannot be moved...... I have recently had the windscreen replaced and now I have just realised when I spray the winscreen washers they shoot mainly onto the screen but quite a bit of water sprays each side and ove the roof! Very annoying if you have washed it a day or so before. I did notice that the plastic shelf that the jets are attached to is not held down as the guys at the windscreen place ripped the plastic clips off and glued them back on to make it look like they had fitted them back on. It does look flush and I doubt this would help the issue..... So any ideas? (I don't think the nozzles are blocked either as the spray seems fine)
__________________ Fabia Vrs Blackmagic! Xenons, Cruise Control, Heated Seats and ESP Wednesday 12th may 2006 was my VRS day |
| Partner Join Date: Sep 2003 Location: Newport Pagnell
Members Car: Mk2 Golf GTi 16v and building a 20VT MK2. Images: 2 Thanks: 29
| Re: washer jets seem out of line..... That scuttle trims needs to be secure. |
| 2.0 FSI Sport. Join Date: May 2007 Location: oxon
Members Car: Octavia Mk2 FSI Sport Thanks: 13
| Re: washer jets seem out of line..... i can move my windscreen washers up and down to change the aim. |
| Briskodian | Re: washer jets seem out of line..... ok Lummox. need to pickup some clips from my dealer. I can't believe the window company thought it would be ok to just glue the caps on and make me believe they were actually holding the damn thing on. Can't adjust fabia ones. they are fixed. you Pay for it in the nose too when they break
| Briskodian | Re: washer jets seem out of line..... fitted the scuttle panel back in position. washer jets still are squirting at the window but when I get out of the car you can see the water is going all the way past the back of the car! I did notice that there are metal clips that the scuttle panel is fixed to. do you think these can be bent to allow for adjustment. only slightly....
| Briskodian Join Date: Feb 2005 Location: Mid Beds
Members Car: fab vRS Thanks: 0
| Re: washer jets seem out of line..... On mine ive noticed the scuttle panel is not fixed near where the washers are theres a couple of fixings but spaced in between the washer jets. So should be able to adjust the aim by trying to wedge the panel up/down locally to them.
__________________ Fabia vRS forunner to the Bentley Continental GT Briskoda - Skoda's illegitimate family Mods: Superchip, K&N filter, Eibach springs, FSD dampers, black front grille, |
| | #7 | |
| Briskodian Join Date: Jun 2006 Location: Middlesbrough, home of legends :P (not the worst place in the UK at all...honest guv)
Members Car: 1.4 16V Fabia Comfort Thanks: 176
| Re: washer jets seem out of line..... Quote:
| Briskodian | Re: washer jets seem out of line..... always good 2 find a positive out of it!
