This is a discussion on Water Ingress Advice within the Fabia I forums, part of the Skoda Model Discussion Area category; I have a fabia vars which has the water ingress that has been talked about at great length on previous ...
| Briskodian | I have a fabia vars which has the water ingress that has been talked about at great length on previous threads.The water is wetting the bottom of the door cards on both rear doors and is sitting on the bottom door seals.It is due to go in this week for repair but the have said that all that is needed is for the inner door skin to be re-sealed with silicone sealant,as that is what they have done in the past and that has always cured the problem.I have read the previous Post and what the other people have had done and i am a little concerned that i am not going to get a satisfactory result from just having the door skins re-sealed. All advice would be greatly appreciated as always. |
Members Car: Fiat Panda Thanks: 16
| Re: Water Ingress Advice Talk to another dealer and get their take on it? As it's warranty work, you can get it fixed by whoever you think has the best solution ![]() Chris
| Partner Join Date: Sep 2003 Location: Newport Pagnell
Members Car: Mk2 Golf GTi 16v and building a 20VT MK2. Images: 2 Thanks: 29
| Re: Water Ingress Advice The solution comes from a Skoda bulletin. As long as the latest bulletin is adheared to then the repair will be sucessfull. If the repair isnt carried out as mentioned in the bulletin then it may well leak again. |
| Off we go Mo Join Date: Dec 2003 Location: Sussex Coast
Members Car: 06 Fabia vRS Thanks: 5
| Re: Water Ingress Advice As one of those suffering this in the other thread(s), I have just had mine cured on the forth attempt. The original 'replace seal' fix didn't work on the driver's side (did on the passenger) and so the dealer has now replaced the inner panel entirely this week. Tried it out with bucket of water today, no leak So it's possible to cure it. Make sure, however, that the technicans cover or remove the back seats as they left mine filthy where they had been clambering about inside. Also check they replace the door card properly and any clips that hold it on should they get broken taking it off. Last edited by maffwilson; 15-01-2006 at 15:16. |
| Briskodian | Re: Water Ingress Advice Maffwilson, when you say that they replaced the inner panel do you mean the membrain ie the plastic skin or the door card.Lummox is there anyway i can check if they are going off the latest info from skoda ie report numbers or information to give them,as i dont want to have to keep going back and forth,been there done that(vauxhall). Regards Tweeks |
| Briskodian Join Date: Oct 2003 Location: oldham
Members Car: black fabia vrs with many toys Thanks: 0
| Re: Water Ingress Advice mines going in again 2nd time for this on thursday as thry made it worse when trying to fix it also having rear brakes done some modified part or something
__________________ live fast die young leave a good looking corpse!!! |
| | #7 | |
| Re: Water Ingress Advice Quote:
| Re: Water Ingress Advice They dont have a membrane, its an aluminium panel. Dont ask them if they are using the latest info it wil **** em off, also dont say i told you to either, that ****es me off when Skoda get the hump with me..lol |
| Briskodian | Thanks for the advice, what happens in vegas stays in vegas as they say.i will update on friday once the car has been abused- sorry fixed by the jd power poll top 3 tech's ![]() |
| Water ingress and rear washer problems | clv101 | Fabia I | 5 | 30-11-2005 11:30 |
| Water ingress...... | benvrs | Octavia I | 6 | 31-10-2005 08:59 |
| Water ingress thro' hatch | bingyp | Fabia I | 7 | 03-10-2005 21:08 |
| hot water cylinder question | tfboy | The Roadside Hotel | 33 | 10-06-2004 18:26 |
| Water ingress - passenger footwell | robmawer | Maintenance & Performance | 4 | 13-01-2003 16:43 |
