40,614 Members 1,518,184 Posts
Water ingress mystery - can you solve it?
This is a discussion on Water ingress mystery - can you solve it? within the Fabia I forums, part of the Skoda Model Discussion Area category; Right I have a mystery on my hands. Sealed up both rear doors a week or so ago. Today, I ...
Old 21-01-2008, 15:23   #1
ultra_joel88's Avatar
Members Car: 04 Fabia vRS (180/300)
Today, I opened up the rear doors, the drivers side seems to failed, I think a rivet has popped out below the carrier and water is getting in through there and onto the seal once again, bottom of the door card is soaking.
HOWEVER, on the passenger side there is no water on top of the seal, the bottom of the door card is bone dry and so is the metal below it, normally there would be drips if it was leaking
But when I took the rear scuff plate trim off I found some water under it on the metal part. There is also a SMALL amount of water behind the seal. I lifted up the matt and the carpet in the footwell is soaked.
Now how the hell is the water getting into this side now if the door is sealed up?
Any ideas?
'04 Fabia VRS - P-Torque STG1, 312mm Brakes, Whiteline RARB, SEAT Sport Strut Brace, Pipercross Panel Filter & PD160 Intake, Pioneer and Infinity ICE, Custom exhaust system w/ de-cat, CCV Bypass w/ Catch Can, Swoosh Gauges, Window Tints
ultra_joel88 is offline
Old 21-01-2008, 15:39   #2
Members Car: Fabia Elegance Est 1.4
Re: Water ingress mystery - can you solve it?
Floor pan grommet popped out?
darrenw is offline
Old 21-01-2008, 15:42   #3
cheezemonkhai's Avatar
Members Car:
Front doors sealed ok?
The water will move backwards as the back of the car is lower than the front.
Failing that try giving the door seals a good clean and putting on some silicon grease to see if that helps reduce the problem. If so then the door seals are not doing their job for some reason. I take it you don't have a sun roof.
cheezemonkhai is offline
Old 21-01-2008, 16:06   #4
havnt sealed the fronts yet.
na no sun roof.
whers the floorpan grommit?
Old 21-01-2008, 17:07   #5
Members Car:
na no sun roof.
Wouldn't think there was a grommet in the rear and it would need to be one hell of a leak in a grommet to let the amount of water you are talking about in.
I'd do the front doors next and then dry it all out and see where you get.
Old 21-01-2008, 17:37   #6
Chrispy's Avatar
Members Car: 2004 Fabia vRS
Skoda seal up all 4 doors now as part of the technical update. Doing the rears alone will not be sufficient I'd have thought.
Silver '04 Fabia vRS. Jabba Custom Remap, Seat Surgeons Leather interior, Whiteline RARB, Cupra Console Bushes
Chrispy is offline
Old 21-01-2008, 18:16   #7
so once the water is in does it roll around the floorpan?
THe car was parked on an incline, with the leaky side at the top part of the slope, could explain it?
Old 21-01-2008, 18:22   #8
Members Car:
Well the water once in will move towards the rear on a flat surface so you will need to seal up the fronts.
Once you have done this you will need to get the carpet dry somehow too as otherwise it will stink.
If you have a garage then putting the car in with a hired dehumidier for the weekend would probably do the job.
Similar Threads
water ingress from underneath? sam1973 Fabia I 9 02-07-2007 10:12
Water ingress - VRS gorsey Octavia I 3 06-12-2006 16:08
water ingress shordruck Octavia I 2 04-04-2006 00:25
Water Ingress Advice Tweekster Fabia I 8 16-01-2006 09:16
Water ingress...... benvrs Octavia I 6 31-10-2005 08:59
