This is a discussion on Water problems! within the Fabia I forums, part of the Skoda Model Discussion Area category; Has anyone experienced a problem with their Fabia VRS, using / losing excessive amounts of water. My 54 plate Fabia ...
| Briskodian | Water problems! Has anyone experienced a problem with their Fabia VRS, using / losing excessive amounts of water. My 54 plate Fabia VRS, uses between 05 to 1 litre of water every 1-2 days. The dealer has had it in and cannot find a problem when they have pressure tested it. The expansion tank cap has been replaced as well. I'm worried it may be something serious with the engine (i.e. Head Gasket) HELP!!! Thanks Tim. |
| | #3 | |
| rider of sharks Join Date: Apr 2005 Location: Cumbria
Members Car: Fabia vRS Thanks: 247
| Re: Water problems! Quote:
__________________ Fiat Grande Punto Sporting (158 bhp 314 lbs/ft) in Red.... ![]() Furby vRS , black magic,passenger airbag de-activation switch, (now gone, but not forgotten!) | |
| Briskodian | Re: Water problems! I used to have a fabia 1,9 sdi, with the same prob..2 1/2 years old..took it to the dealers and they discovered it was a fault with the radiator..fixed it under warranty..they could easily have said it was a stone chip etc, so well done to them :-)) |
| | #5 | |
| Briskodian Join Date: Sep 2006
Members Car: VRS Fabia, Remap, leather the ish Thanks: 0
Had that problem, and was fixed by dealer under warrenty. Its a common problem and I believe its the thermostat or temp sensor leaks and requires a new gasket. Its not that big a job so dont worry too much ![]() | |
| | #6 | |
| Briskodian | Re: Water problems! Quote:
I would be worried about my dealers ability if they couldnt find a leak when it is losing up to a litre in 2 days ![]()
__________________ Run out of CASH | |
| Briskodian | Re: Water problems! Thanks, for the replies, the car was in for service Thurs and has done about 220miles since that evening. Had to top it up this morning as there was 1/4 inch of water left in the expansion bottle!! The dealer put some UV dye in the coolant system, as they can't find the problem, so in goes that car again to see if they can trace the leak!! More news tommorow hopefully. Tim. |
| Briskodian | Re: Water problems! Try some Radweld?
__________________ |
| Briskodian | Re: Water problems! Dealer has booked it in for a Head gasket. Not looking forward to having it done, but if it cures the problem....... Has anyone else had a head gasket changed???? |
| water inside car problems | wooflad | Superb | 20 | 06-06-2008 09:57 |
| Water Water Everywhere !!! | BoilingPoint | Fabia I | 6 | 04-09-2007 16:50 |
| Gear Linkage problems / gear box problems | blinkinink | Favorit, Felicia, Fun and Forman | 1 | 15-08-2006 14:27 |
| Other water companies begin water saving measures. | Goochie | Off Topic and Chit Chat | 2 | 02-03-2006 12:12 |
| Water ingress and rear washer problems | clv101 | Fabia I | 5 | 30-11-2005 11:30 |
