This is a discussion on Wet carpets!!!!! within the Fabia I forums, part of the Skoda Model Discussion Area category; Noticed at lunchtime that the carpets under the VRS mats in rear footwells is wet! On closer inspection it appears ...
| Briskodian | Wet carpets!!!!! Noticed at lunchtime that the carpets under the VRS mats in rear footwells is wet! On closer inspection it appears water is lying in the bottom of the seals, then running down the plastic trim onto the carpets. On the way home I will call at local dealer, but wanted to know if anyone else had had this before on Furby VRS. Cheers Whizzo |
| Briskodian Join Date: Jan 2004 Location: York
Members Car: Brabus Roadster Coupe Thanks: 0
| funny enough !!!! i just noticed thi son sunday i thought it was a bottle of water i had in the back leaking rear passenger mat was wet and it was damp under it too !!!! if you find anything else out let me know mine is in for a service tomorrow so i will ask then aswell
__________________ First step to recovery is admitting you have a problem Hi, my name is Mike and I own a Skoda and to top it all off it’s a diesel . |
| | #3 | |
| Briskodian Join Date: Mar 2005 Location: east midlands(wellingborough)
Members Car: Skoda Fabia 1.9 Tdi PD Vrs Thanks: 0
| Quote:
hope you get it sorted ![]() oh just found it thread by NHOJ1954 on the 27/03/2005
__________________ Furby ![]() Dave Last edited by davric; 19-04-2005 at 18:10. | |
| Briskodian Join Date: Jan 2005 Location: Manchester UK
Members Car: Octavia TDi (me),Fabia TDi (wife),Fabia VRS SE (son) Thanks: 3
| We had a rear door seal leaking and they had to replace some damaged trim ![]() |
| Briskodian | Just been to the dealers and he said it is a known fault on Fabia`s. The fault lies with a seal in some sort of filter breaking and needing replacing. Not sure what he meant or where this filter is ?. I still reckon it is the door seals are at fault as water is still lying at the base of the seal this morning, two days since it last rained! They are also going to rectify the noisy rear brakes and the recall for the fuel pump as well when it is serviced in a couple of weeks. Guess I will need the hairdryer on the carpet to dry it out tonight. Whizzo |
| i had mine done today and they replaced the door seal so thts ok if it fixes it
Members Car: Octavia II vRS Thanks: 31
| Something else to do a quick check if rear windscreen washer is not working. My cousins Polo suffered from a wet rear carpet, it turned out the a fitting for the rear windscreen washer had come apart around the rear somewhere and seeped onto the floor.
__________________ GAFF ![]() Briskoda Ireland Events, Meets & Pictures.....Race Blue Octavia MkII vRS.....Old Octavia MkI vRS |
| Briskodian Join Date: Mar 2004 Location: Gravesend, Kent
Members Car: I bought my Fabia vRS in October 2003. Previously I owned a "tacky" Ford Fiesta Zetec-S. Thanks: 0
| I have water leaking from the front driver side door sill. It is only slight, so will wait for the next service (only 1000 miles to go, then it's done 40k!! Not too sure where I've been!!) that is unless the back is soaking wet!! Haven't checked that!!
__________________ Matt (T31 vRS) |
| Wet carpet | jammietart | Maintenance & Performance | 10 | 24-11-2004 21:03 |
| New Carpets | greg2302 | Styling and Car Care | 4 | 27-03-2004 10:54 |
| Toyo Proxes T1-S in the wet | devonutopia | Maintenance & Performance | 31 | 23-01-2004 14:30 |
| Tyres: wet vs .dry | devonutopia | Maintenance & Performance | 7 | 25-04-2003 20:41 |
| Braking warning following a long wet drive - RS ? | stopan1j | General Car Chat | 16 | 09-04-2003 17:19 |
