This is a discussion on What is it? 3 beeps on startup within the Fabia I forums, part of the Skoda Model Discussion Area category; Hi Fabia VRS on the odd occasion just after start up I get 3 warning beeps from the car there ...
| Dieselslave Join Date: Dec 2006 Location: Aberdeenshire
Members Car: Fabia vrs, A3 130tdi Sport, Vauxhall Nova Sport Thanks: 1
| What is it? 3 beeps on startup Hi Fabia VRS on the odd occasion just after start up I get 3 warning beeps from the car there are no lights on the dash and there is no obvious running problems. Its the same noise that you get when your washers run out. I have checked the hand book but it dosnt help. What is it?? Cheers |
| Permanently banned Join Date: Mar 2006 Location: Buckingham Palace Car Park
Members Car: Honda Civic Type-R Thanks: 86
| Re: What is it? 3 beeps on startup When did it happen? I got it when the temperature dropped. |
| Briskodian Join Date: Sep 2004 Location: Bristol UK
Members Car: Skoda Fabia 2.0 Elegance 04/2005 Thanks: 0
| Re: What is it? 3 beeps on startup |
| Re: What is it? 3 beeps on startup Normally gives 3. |
| Partner Join Date: Sep 2003 Location: Newport Pagnell
Members Car: Mk2 Golf GTi 16v and building a 20VT MK2. Images: 2 Thanks: 29
| Re: What is it? 3 beeps on startup 3 beeps and 4 degrees flashes on the MFA |
| Re: What is it? 3 beeps on startup The temp idea is a good one but it dosnt do it every morning and I have been having to scrape ice from the windows every morning this week. and when driving and the temp drops I only get 1 beep and the 4oC flashing on the clock thingy -1oC by night 16-20oC during the day AAHHH Scotland you have to love it |
| Volkskodian Join Date: Dec 2005 Location: Edinburgh - "Bonnie Scotland"
Members Car: Fabia 1.9TDI Elegance Estate 140 BHP & Golf 1.9Tdi 180 BHP both remapped by Angel Tuning Thanks: 7
| Re: What is it? 3 beeps on startup Seat belt warning ? ![]()
__________________ Some say their glass is half empty, others say their glass is half full. I say, ...... are you going to drink that ? |
| | #8 | |
| Re: What is it? 3 beeps on startup Quote:
If it's already below 4oC when your driving the car, It won't happen I don't think. You have to be in the car when it's above, then once it drops, the beep's will happen. | |
| Briskodian Join Date: Sep 2006 Location: Belfast
Members Car: Fabia vrs Thanks: 2
| Re: What is it? 3 beeps on startup Did anyone ever find out what causes this? I have no fault codes, No lights on the dash and its 14c degrees so its not the low temperature warning. Does it with my handbrake off as well so its not the low brake fluid warning beep(light doesnt appear). Anyone? |
| | #10 |
| Briskodian Join Date: Feb 2006 Location: Leicester
Members Car: Fabia VRS, Elise S1 Thanks: 0
| Re: What is it? 3 beeps on startup Bump... anyone resolved the 3 beeps issue? My Fabia VRS has done it a couple of times just recently. Is not the usual low temperature, fuel level or washer fluid. |
| | #11 |
| Briskodian Join Date: Jun 2007 Location: Brecon/ Cardiff
Members Car: 04 Fabia vRS (180/300) Thanks: 28
| Re: What is it? 3 beeps on startup Pheasant in bumper warning?
__________________ '04 Fabia VRS - P-Torque STG1, 312mm Brakes, Whiteline RARB, SEAT Sport Strut Brace, Pipercross Panel Filter & PD160 Intake, Pioneer and Infinity ICE, Custom exhaust system w/ de-cat, CCV Bypass w/ Catch Can, Swoosh Gauges, Window Tints |
| | #12 |
| Silver Fab vRS Join Date: Apr 2005 Location: Stourbridge, West Midlands
Members Car: Silver Fabia vRS. Thanks: 96
| Re: What is it? 3 beeps on startup I was having 3 beeps when starting up a few months ago and it was because my engine coolant was low but it did show a light on the dash that flashes. ![]()
__________________ John http://s77.photobucket.com/albums/j79/vRS19TD/ www.petrolprices.com For Cheap Fuel Prices in Your Area. http://www.myspace.com/vrs19td This is me, if you're interested. Also on Facebook. |
| | #13 |
| Briskodian Join Date: Jan 2008 Location: lincoln
Members Car: Black Fabia VRS Thanks: 7
| Re: What is it? 3 beeps on startup is one of your lights out. just do a general check of your car levels ect ect. it maybe 1 of them but the bulb in the dash may not b working?? |
| | #14 |
| Proud new Dad Join Date: Feb 2007 Location: Carlisle, Cumbria
Members Car: Octavia vRS TDi Thanks: 167
| Re: What is it? 3 beeps on startup Could it be do do with the glow plugs warming. ie when it stops beeping they are hot enough for starting. My dads Octavia's have both done this.
__________________ Running on the fuel of Satan.... |
| | #15 |
| Re: What is it? 3 beeps on startup Hi forgot I satrted this thread. Solved the problem traded the car with offending beeping problem for a SE New one dosnt do it. Problem solved![]() Cheers
__________________ Mods: Rubber floor mats front and rear, Rubber boot liner Rear centre headrest....Sexy |
| | #16 |
| Re: What is it? 3 beeps on startup Oh well glad you've got that sorted. Happy motoring.
| | #17 |
| Briskodian Join Date: Aug 2004 Location: Essex
Members Car: fabia vrs Thanks: 1
| Re: What is it? 3 beeps on startup I think you'll find its a 'fault warning' for the abs system. Mine has done this on and off since new, and its been serviced/checked with no problems. Just a gremlin.
__________________ '54' Black Magic Fabia vRS Yo Adrien I DID IT!!! |
