40,614 Members 1,518,185 Posts
What Brakes/Pads/Fluid/Hoses for my vRS?
This is a discussion on What Brakes/Pads/Fluid/Hoses for my vRS? within the Fabia I forums, part of the Skoda Model Discussion Area category; I'm going for the 312mm brake upgrade on my Fabia vRS at the end of the month, what would you ...
Old 07-02-2005, 18:24   #1
HellFire's Avatar
Members Car: Skoda Fabia vRS
I'm going for the 312mm brake upgrade on my Fabia vRS at the end of the month, what would you recommend as the best brakes/pads to get? the standard Octavia vRS ones or some uprated ones such as EBC/Black Diamond?
Also, what fluid have people used on their cars and what gives the best results. I know they vary from DOT 4 to 5.1, but that's not all the story and would like to know peoples opinion on which one works best.
Also, as for braided hoses? are they a worthwhile upgrade and at what cost? It seems like there is no point in upgrading the brakes to this extent and leaving the poxy standard vRS ones on...
Thanks for peoples input .
Metro Blue '06' 5 Door Astra 1.8 SRi
HellFire is offline
Old 07-02-2005, 19:05   #2
Location: Monday: MK Tuesday: MK Wednesday: MK Thursday: MK Friday: MK/Home Saturday: Home Sunday: In bed ;o)
Members Car: BMW 120D M-Sport
EBC Turbogroove disks are very good, and make a lovely noise under heavy braking...
Having a little break, concentrate on the more important things in life, swmbo and my training.
See you soon folks, take care - James
walkie is offline
Old 07-02-2005, 20:06   #3
HellFire's Avatar
Lovely noise?
HellFire is offline
Old 07-02-2005, 22:01   #4
Originally Posted by HellFire
Lovely noise?
Like a WW2 jet or something
walkie is offline
Old 07-02-2005, 23:43   #5
HellFire's Avatar
You've got your signiture spot on, I just had to click it, boy you should be a sales rep.
HellFire is offline
Old 08-02-2005, 08:51   #6
I do hope that's not sarcasm...
...It's what every man needs
walkie is offline
Old 08-02-2005, 09:00   #7
Dinosaur
TaviaRS's Avatar
Members Car: Merc E class & SLK
Hellfire,
Black Diamond disks
Ferodo DS2500 pads
Super DOT 4 fluid, either Castrol or Silkolene Pro Race 2000 (if your pockets are deep). Why Super DOT4? Well, it is fully compatible with what you have now unlike DOT5, it has a dry boiling point only a couple of degrees below the DOT5 but the wet boiling point is higher. It will also allow you to stick to the usual Skoda recomended change interval of 40k miles. DOT 5 fluid needs to be changed more frequentsly, eg Castrol SRF needs to be changed every 6-10k miles and at £22 for 500ml it gets expensive.
A jolly sensible Mercedes E class saloon in a rather fetching bluey grey colour. No it isn't fast, no it isn't modded, and yes, it will still eat your Fabia for breakfast.
Official mobile chicane for Briskoda trackdays
TaviaRS is offline
Old 08-02-2005, 09:04   #8
Don't talk, drive!
ncarring's Avatar
The hoses mummy, tell them about the hoses mummy....
Nick
North Wiltshire RoADAR
ncarring is offline
Old 08-02-2005, 09:07   #9
Dinosaur
TaviaRS's Avatar
Hoses?
Don't bother changing them unless you are changing the callipers and need different connectors. The standard hoses are reinforced already (essentially brided hoses) with a rubber sheath on the outside. Save the £60 for a hose kit and get some DS2500 pads for the rear to improve your braking even further. So, final check list:
DS2500 pads all round
Super DOT 4 fluid (Castrol or Pro Race)
Black diamond discs.
HTH
TaviaRS is offline
Old 08-02-2005, 13:31   #10
Nigel26's Avatar
for the black diamonds... which type would you recommend the lad??
i used cross drilled ones once and they warped... (not on the vRS though)
Sea Grey Mondeo Titanium X
Nigel26 is offline
Old 08-02-2005, 13:45   #11
C+ à Paris!
tfboy's Avatar
Members Car: "Fake" Black Magic vRS
Well, if they're brided, why bother with the rubber sheath
On a serious note though, I'd second Jon even though he only drives an sdi octy taxi.
Had DS2500 pads on the front with super dot 4 on my ex furby and it was awesome. What I didn't do was change the rear pads or use diamond discs on the front - I just got some OEM 312mm discs. They didn't warp but I think Colin (neo_vr) has managed to get brake fade and warp them under severe abuse
If I were to do it again on my next furby (when I find one ), I'd think about changing the rear pads too to try and even out the braking a bit. The DS2500 bite so damn hard that it really tends to make the car nose heavy under hard braking
Xavier
tfboy is offline
Old 08-02-2005, 14:06   #12
HellFire's Avatar
Cool, thanks for the input, however I suppose even normal Octavia vRS 312mm discs & pads will be more than sufficient to slow me down
HellFire is offline
Old 08-02-2005, 14:12   #13
mcbunny's Avatar
Members Car: Brabus Roadster Coupe
tavia your getting confused between dot 5 and 5.1 i think
check to see if performance friction do some pads for the 312mm setup the pads are awsome and you get sparks when stamping on the brakes lol
First step to recovery is admitting you have a problem
Hi, my name is Mike and I own a Skoda and to top it all off it’s a diesel.
mcbunny is offline
Old 08-02-2005, 14:20   #14
Dinosaur
TaviaRS's Avatar
Trouble with the PF carbon metallics is that they knacker your wheels and can damage paintwork, unless you clean afetr pretty much each trip. Much like the DS3000s. Primarily a competition pad, hopeless when cold, noisey, dusty destroy disks etc etc Ran them on mine, awesome stopping power but the downsides far outweighed the upsides for fast road use.
Standard disks are fine, but do change the pads to the Ferrodos, or if skint the Pagid Blues.
Re the fluid, DOT5 and 5.1 are fairly similar. Both do offer better dry boiling points but go "wet" quicker and don't offer as good wet boiling points as the Super 4.1. Beside which, a decent 5 or 5.1 is damned expensive.
Go for the grooved BD disks.
TaviaRS is offline
Old 08-02-2005, 14:22   #15
C+ à Paris!
tfboy's Avatar
OEM 312mm discs are about £80 inc vat and delivery new. Ferodo DS2500 pads are about £100 for a front set. Don't know how much the rear ones are.
I'd seriously consider looking at the rear. The massive difference in braking performance between front and rear when you change the front only can lead to a slightly more "entertaining" drive when braking and turning at the same time
Xavier
tfboy is offline
Old 08-02-2005, 14:23   #16
faboka vrs's Avatar
Might look into this also.
John
His
Slow Black Diesel Powered Hatchback
Hers
Full Fat HotHatch with Cup suspension and spolier kit
faboka vrs is offline
Old 08-02-2005, 14:36   #17
mcbunny's Avatar
my mate doesnt seem to have had any problems with cold stopping really and not any problems with the sparks melting paintwork either as far as im aware
mcbunny is offline
Old 08-02-2005, 14:37   #18
faboka vrs's Avatar
John
His
Hers
Old 08-02-2005, 14:45   #19
mcbunny's Avatar
thats on groved disks tho aswell so wouldnt be as bad on standard discs
mcbunny is offline
Old 09-02-2005, 12:14   #20
HellFire's Avatar
Roflmao
HellFire is offline
Old 11-02-2005, 13:24   #21
Nigel26's Avatar
i can just see the look on plods face as you brake going passed him....
"excuse me sir but did you know your brakes are on fire??"
Nigel26 is offline
Old 11-02-2005, 13:34   #22
mcbunny's Avatar
lol but they dont half stop you
mcbunny is offline
Similar Threads
New shape Octavia - plans for Vrs model HARV INTRODUCE YOURSELF! First time visitors, say hello here. 36 16-04-2005 16:54
My Fabia vRS impessions following a hour long test drive.. ecklad General Car Chat 24 16-04-2005 11:04
Another Fabia Vrs Review flyingscot General Car Chat 4 15-08-2003 19:37
Evo Review Of Fabia Vrs SilveRS General Car Chat 7 30-07-2003 14:18
vRS Estate DGW General Car Chat 40 14-03-2003 22:45
