40,614 Members 1,518,185 Posts
What colour?
This is a discussion on What colour? within the Fabia I forums, part of the Skoda Model Discussion Area category; Im going to paint my Strut Brace, and what-not, and im after a colour similar to the Calipers on my ...
Old 31-10-2007, 13:57   #1
is chilled out!
youngsyd's Avatar
Members Car: Fabia vRS Black Magic
What colour?
Im going to paint my Strut Brace, and what-not, and im after a colour similar to the Calipers on my Vrs....
Has anyone bought some before, if so what was it?
Cheers
Blood runs through our veins, thats where all similarities end....
youngsyd is offline
Old 31-10-2007, 18:51   #2
TDi Vrs's Avatar
Members Car: SKODA FABIA vRS
Re: What colour?
hammerite smooth green
07 Fabia vRS,/// Cruise Control, De-Bump striped, Seat LCR Splitter, Seat Sport Front Strut Brace, PD160 Air Intake and Green Cotton Air Filter, Cage mod, Uprated indicator Bulbs and Headlight Bulbs, LED sidelights, Ipod Interface, Jabba Sport ARB, Turbo back, and SportCat Milltek Exhaust, JABBA Sport Custom Remap! 312mm Brakes, Eibach Pro-Kit Springs Privacy tints all round, X5 rear indicators bulbs, and Anthracite Octy 17" Spiders and sticky Toyo Proxes T1R rubber! To come Leather retrim!
TDi Vrs is offline
Old 31-10-2007, 19:24   #3
is chilled out!
youngsyd's Avatar
Re: What colour?
Good stuff ta.
I know the proper colour name is Minz Green, but thats a non obtainable anyway.!
youngsyd is offline
Old 03-11-2007, 19:03   #4
is chilled out!
youngsyd's Avatar
Re: What colour?
UPDATE!
I went to the Paint Factors after work, and asked to match uo a colour with my calipers, and mentioned on ETKA, it says Minz Green...
And they list it as a colour!
Great stuff, so that means i can get my strut brace done, and my NSR caliper repainted!
youngsyd is offline
Old 03-11-2007, 19:09   #5
Partner
Lummox's Avatar
Images: 2
Re: What colour?
Hammerite Smooth green (spray can)
www.unit18.co.uk
Lummox is offline
Old 03-11-2007, 19:10   #6
is chilled out!
youngsyd's Avatar
Re: What colour?
Close...but when they do the proper colour, i aint even trying hammerite.
youngsyd is offline
Old 03-11-2007, 19:17   #7
Hardcore
Basil's Avatar
Re: What colour?
Hammerite is pretty durable stuff - hope the proper colour is as tough - it gets hot around the caliper area and there are a lot of chances for dings.
Hammerite green has been used a lot and some people swear by it. My calipers were painted expertly by Stu and they're doing great under all sorts of stress......
If you do go with the proper colour - do let us know how it holds up on the calipers..
Good luck
Bas
Fab vRS - Black Magic - PD160 intake - Forge FMIC - colour coded front grille -SLC Splitter - K&N Airfilter -SEAT Strutbrace - Jabba ARB - IC Waterspray (need to wire it in!) - 312mm TT brakes - Eibach Springs - Skoda Reversing sensors - Devonutopia Tuning (tm) Custom Exhaust (2 1/4" straight pipe) - Short shifter mod- 5 brake light mod - Helix Steel SMF + Organic Clutch + pressure plate - Peloquin LSD - TD stage 2 Hybrid - Washbrook remapped ECU - Uprated injectors - Cupra bushes -Poly-filled dogbone - Allard racepipe - Pirelli Dragons - Forge Rear Strutbrace - DIY SS upper boostpipe delete -Koni FSD's - elephant pipe CCV mod
Basil is offline
Old 03-11-2007, 19:22   #8
Partner
Lummox's Avatar
Images: 2
Re: What colour?
Exactly a 'propper' colour from a bodyshop will be water based paint, good luck with that on a brake caliper.
Close?
Tell me the difference
www.unit18.co.uk
Lummox is offline
The Following User Says Thank You to Lummox For This Useful Post:
youngsyd (03-11-2007)
Old 03-11-2007, 19:23   #9
is chilled out!
youngsyd's Avatar
Re: What colour?
Why do you think im trying it Lummox?
Because no one else has maybe?
Then i might sway towards the beloved hammerite...
Yeah you cant tell the difference, so what?
youngsyd is offline
Old 03-11-2007, 19:37   #10
Partner
Lummox's Avatar
Images: 2
Re: What colour?
That one above is the same caliper as painted by the way.
Not having a go bud, I tried painted a load of engine bits a while back, plastic covers etc and the water based paint didnt last very long.
www.unit18.co.uk
Lummox is offline
Old 03-11-2007, 19:46   #11
is chilled out!
youngsyd's Avatar
Re: What colour?
OK, thought you were having a pop at me!
I read into things wrong sometimes!
Ill see what this stuff is like first, ill try it on something not too obvious and take it from there!
Cheers!
youngsyd is offline
Old 03-11-2007, 19:52   #12
Partner
Lummox's Avatar
Images: 2
Re: What colour?
I should imagine it will be fine on your strut brace, not so sure on the caliper thats all.
www.unit18.co.uk
Lummox is offline
Old 03-11-2007, 20:17   #13
KTP
eeeeeeeeevil.
KTP's Avatar
Members Car:
Re: What colour?
it doesnt really matter what green you go for, the hammerite is probably your better option.
the last of the fabia vrs' all have red calipers anyway.
KTP is offline
The Following User Says Thank You to KTP For This Useful Post:
Old 03-11-2007, 20:55   #14
is chilled out!
youngsyd's Avatar
Re: What colour?
I know they did?!....
Yeah ill see what it goes like Lummox...and let you know how long it takes to peel off!!
I must admit though after a nice long run, that strut brace holds some heat...obviously not the same as brakes, but still a bit tingly when touched!
youngsyd is offline
Similar Threads
Help please, re colour botham Octavia II 14 09-05-2007 19:12
What colour is it? shytot RWD Skodas and others 12 25-04-2007 18:39
What colour... PEMBO Off Topic and Chit Chat 6 17-04-2007 21:04
Ok so what colour for the new RS :) ColinD General Car Chat 15 24-11-2006 18:00
Well, what colour is it going to be then? devonutopia General Car Chat 16 30-11-2005 11:31
