40,614 Members 1,518,183 Posts
What was my car trying to tell me?
This is a discussion on What was my car trying to tell me? within the Fabia I forums, part of the Skoda Model Discussion Area category; Ok, first time in weeks I have access to my car. I start it up and drive down the road. ...
Old 20-12-2006, 16:15   #1
Moose's Avatar
Location: I'm a monkey from outer space, woooooooo ahhhhhhhhh hehe hooohaa
Members Car: None
Ok, first time in weeks I have access to my car. I start it up and drive down the road. Park up next to side of road very close to postbox. Turn engine off. Leave key in ignition and open door. Warning buzzer sounds, like the lights on one. Get out and post letters. Notice that the passenger side sidelight is on. Check lights switch, its all off. Close door and start engine. Drive like normal, go to fill up, no warning buzzer now. Back at home I check all the lights are working and all are normal.
Sunlight Silver MX-5 1.8 Sport
Moose is offline
Old 20-12-2006, 16:23   #2
Volkskodian
Td-eye's Avatar
Re: What was my car trying to tell me?
You probably left the car's parking light on by leaving the indicator stalk in the left or right position after switching the ignition off and opening the door.
Some say their glass is half empty, others say their glass is half full.
I say, ...... are you going to drink that ?
Td-eye is offline
Old 20-12-2006, 16:28   #3
Moose's Avatar
Members Car: None
Wow, didn't know that. I probably did leave the indicator stalk as well. Thankyou.
Moose is offline
Old 20-12-2006, 16:31   #4
rider of sharks
sharkrider's Avatar
Members Car: Fabia vRS
yup... it's the parking lights, if you leave the stalk turned the two sidelights in the direction of your indicators will stay on
Fiat Grande Punto Sporting (158 bhp 314 lbs/ft) in Red....
Furby vRS , black magic,passenger airbag de-activation switch, (now gone, but not forgotten!)
sharkrider is offline
Old 20-12-2006, 16:43   #5
Hardcore
Basil's Avatar
Isn't it fun finding out all the neat little design details even after owning the car for quite a while?
Lotta thinking went into the design, respect to the engineers at VAG.
Fab vRS - Black Magic - PD160 intake - Forge FMIC - colour coded front grille -SLC Splitter - K&N Airfilter -SEAT Strutbrace - Jabba ARB - IC Waterspray (need to wire it in!) - 312mm TT brakes - Eibach Springs - Skoda Reversing sensors - Devonutopia Tuning (tm) Custom Exhaust (2 1/4" straight pipe) - Short shifter mod- 5 brake light mod - Helix Steel SMF + Organic Clutch + pressure plate - Peloquin LSD - TD stage 2 Hybrid - Washbrook remapped ECU - Uprated injectors - Cupra bushes -Poly-filled dogbone - Allard racepipe - Pirelli Dragons - Forge Rear Strutbrace - DIY SS upper boostpipe delete -Koni FSD's - elephant pipe CCV mod
Basil is offline
Old 20-12-2006, 17:18   #6
Moose's Avatar
Members Car: None
Yeah, I know what you mean Basil. I've owned the car about 2 years now and never noticed.
Moose is offline
Old 20-12-2006, 17:30   #7
P-A
Members Car: VRS
On the subject of parking lights. Any idea how long you can leave them on before you have a flat battery?
P-A is offline
Old 20-12-2006, 17:48   #8
Hardcore
Basil's Avatar
Someone will know - assume a half-charged battery, and the current draw from the two tiny bulbs and it's simple maths....
Basil is offline
Old 20-12-2006, 17:55   #9
Members Car:
If six (4 side lights+ 2 on number plate) 6 watt lamps are on when parked that takes 0.5 amp per lamp which equals 3 amps in total. I the battery is of 60 ampere hour capacity , new and fully charged then the lamps would light for 60 divided by 3 , giving 20 hour total time before the battery is fully discharged. This will never be reached ,because the battery is more likely to partially discharged from the last start ,and the small load being taken all the time for radio ,clocks etc . But my figures give you a guide as to what is happening when lights are left on without the engine running.
AndyPandy is offline
Old 20-12-2006, 18:32   #10
nathwarr's Avatar
Members Car:
twice as long as if you leave all the side lights on, funny as thats what the feature is for, battery life saving............
swing low sweet chariot
nathwarr is offline
Old 20-12-2006, 18:37   #11
Members Car:
Vauxhall cars have their parking lights using the indicators....reckon they pinched it off VAG or VAG pinched it off Vaux....
thirty3 is offline
Old 20-12-2006, 18:45   #12
Skonda Fabic
ChrisRs's Avatar
ALL these features are in the Manual
ChrisRs is offline
Old 20-12-2006, 19:03   #13
Broken :(
Wardy's Avatar
Members Car: Skoda Fabia vRS
VAG have had this feature for a long time. Remember my Mum's C-reg (1983??) Polo squareback doing this
Steve
Wardy's Fabia vRS
xenons : sunroof : cruise : OEM+
"Racing is life. Anything before or after is just waiting." - Steve McQueen
"If in doubt, flat out." - Colin McRae
Wardy is offline
Old 20-12-2006, 19:26   #14
Moose's Avatar
Members Car: None
How many blokes read the manual though? Seriously?
Moose is offline
Old 20-12-2006, 19:49   #15
Mongreller
devonutopia's Avatar
Members Car: Skoda Fabia Mongrel
Images: 5
I found that out after about 1 week.
devonutopia is offline
Old 20-12-2006, 20:12   #16
nathwarr's Avatar
Members Car:
I use my left or right parking lights all the time when I park outside my mums or my mates houses
nathwarr is offline
Old 20-12-2006, 21:02   #17
WeirdKerr's Avatar
my mk1 seat ibiza i had between '98 and winter '01 did this too
Výhodou prostřednictvím technickými
WeirdKerr is offline
Old 21-12-2006, 20:33   #18
Dmac1969's Avatar
Members Car: Fabia 1.4 MPi Comfort
Images: 1
My Dads old Mk1 Polo (1975-78 pre facelift) had this too , although without the warning buzzer!
Duncan - England's most Northerly Briskodian!
2000/V reg Fabia 1.4 Mpi Comfort-Dynamic Blue
Ex Octavia vRS and Octavia Slxi 1.8T.
Dmac1969 is offline
Old 22-12-2006, 20:23   #19
500 Power
lfc958's Avatar
Members Car: Fiat 500
My dads Audi 100 had these, back in the mid 70's, He was posted to Germany, and was advise by the police if he was parked just out of range of overhead lights, he was supposed to leave the offside parking light on. .
So VAG have had this function for yeeeeeeeeeeeaaaaaaaaaarrrrrrs.
Steve
Man-Bag ? Girlie Car ? - You Decide ( I have - it's neither )
lfc958 is offline
Old 24-12-2006, 20:20   #20
Jim_VRS's Avatar
It's well weird when it initially happens...then u find out whats going on, it's ace!! I use it all the time now just to show off lol
Jim_VRS is offline
