This is a discussion on what setting is best for your dragon? within the Fabia I forums, part of the Skoda Model Discussion Area category; just fitted a digital dragon tuning box to my fabia vrs. must say it was very easy to fit, took ...
| Briskodian Join Date: Feb 2005 Location: east yorkshire
Members Car: Fabia Vrs Thanks: 0
| just fitted a digital dragon tuning box to my fabia vrs. must say it was very easy to fit, took me approx 30 minutes with placing the box and wires in a safe posistion etc nice and tidy. would like to ask all those out there with dragon boxes what setting do you have yours at? test drove it on the standard setting (11) abit more power more noticible mid range and a slight increase in smoke on heavy acceleration, so i increased the setting to 13. much better pull all gears very noticible tourqe increase and lots more smoke under heavy acceleration especially in the higher gears 5th and 6th. not sure if ill increase it any further? just thought i'd gage what you guys and girls are running yours at. |
| Old Git Join Date: Oct 2004 Location: Wiltshire
Members Car: Octavia Elegance combi 1.9tdi Images: 1 Thanks: 192
| 16 is a bit silly and frantic but some people like it .....put mine back on 11 and it worked just fine ...dont forget the car will get quicker when it gets used to what is happening....over 3 or 4 weeks
__________________ |
| | #3 | |
| Briskodian Join Date: Apr 2004 Location: Kent
Members Car: Fabia vRS Thanks: 0
| Quote:
__________________ You've been Skoda'taken! | |
| I am pretty certain the black box "learns" as it goes along so when the car all of sudden starts giving it new or different info it uses it and gradually adjusts to it normally over a period of 3 to 4 weeks. Apparently if you disonnect the battery it will start the learning process from scratch.
__________________ Last edited by Octygone; 06-09-2005 at 22:39. |
Members Car: Fiat Panda Thanks: 16
| The ECU has a map stored in it, which is a list of parameters and maximum values. There is then a bit of memory which overlays these values with some fine adjustments which are calculated by the ECU "learning". Disconnecting the battery removes these fine adjustments and next time you drive the car it has to learn from scratch. If the car is anything like my Ford, then disconnecting the battery for an hour will clear these fine adjustment settings and over the next 5 miles of driving the ECU will recreate them. Haynes recommends after an ECU reset, allowing the car to idle until it reaches operating temperature, then holding the revs at 1200rpm for 2 mins before going for a 5 mile drive, taking in a variety of driving conditions..... Chris
| Briskodian Join Date: Nov 2004 Location: wigan
| i have mine on 16! no smoke and its great!!
__________________ 179BHP AND 340 TORQUE!!! |
| | #7 | |
| Briskodian Join Date: Sep 2004 Location: Leicestershire
Members Car: Smart Roadster Coupe Brabus Thanks: 4
| Quote:
__________________ Engined bike. Engined car. Neither a Skoda - been there, done that | |
| | #10 |
| just cleaned my green filter and wow. apart from the obvious better reving of the engine, the dragons performance is stagering, and has severley reduced the smoking. got to recomend you check your filters and give em a clean. mine had done around 7000 miles and a whole load of crap came out of it. |
| | #11 |
| I cleaned mine at the weekend (loadsa crap in it!), also had my EGR adjusted by my dealer but still smokes a lot. Might get it adjusted again as I wonder if being adjusted before the filter was clean has made a difference.
| Dragon tunning box arrived. | smartshark | Fabia I | 19 | 22-08-2005 12:15 |
| Dragon Performance | mattstimpson | Octavia I | 5 | 28-05-2005 11:41 |
| Nick the Dragon Slayer.... | ScoobyChris | Off Topic and Chit Chat | 8 | 14-04-2005 11:25 |
