40,615 Members 1,518,202 Posts
What is under the fabia boot floor?
This is a discussion on What is under the fabia boot floor? within the Fabia I forums, part of the Skoda Model Discussion Area category; Thinking in particular of the left hand side of the boot, to the left of the spare wheel. I know ...
Old 03-02-2007, 12:42   #1
Mongreller
devonutopia's Avatar
Members Car: Skoda Fabia Mongrel
Images: 5
Thinking in particular of the left hand side of the boot, to the left of the spare wheel. I know the rear left wheel arch/suspension mounting must be close to that area.
It's just I'm thinking it would be quite cool if I could somehow make a recess big enough for a battery?
devonutopia is offline
Old 03-02-2007, 12:47   #2
Briskodiodion
TeflonTom's Avatar
Members Car: Fabia 2.0/Felicia
Re: What is under the fabia boot floor?
i doubt if there's enough space in there for a battery mate.... spare wheel recess is the best bet i'd say
TeflonTom is offline
Old 03-02-2007, 13:00   #3
Mongreller
Images: 5
I can this heading toward a false floor build now....
Old 03-02-2007, 13:10   #4
Briskodiodion
TeflonTom's Avatar
you dont necessarily haveto use 'car' batteries.... you could go for an array of smaller batteries in parallel..... and these would be much easier to hide
Old 03-02-2007, 13:37   #5
Mongreller
Images: 5
Well, to be honest, hiding is not an issue. It's just the practicality of having parts of my engine bay in the boot, along with the propane/NOS, and still trying to use it as a boot (as much as is possible....)
Old 03-02-2007, 19:51   #6
Partner
Lummox's Avatar
Images: 2
Err the exhaust.
Lummox is offline
Old 03-02-2007, 20:05   #7
Mongreller
Images: 5
[thinking a bit]
Ooops.
Old 03-02-2007, 20:09   #8
Briskodaholic
Tom_vRS's Avatar
Members Car: '97R BMW 328i Saloon
Do you really want a battery so close to NOS and LPG?
97/R BMW 328i in Boston Green.
Tom_vRS is offline
Old 03-02-2007, 20:13   #9
Mongreller
Images: 5
lpg is irrelevant, as it's a really solid tank (you can jump on it, hit it with a hammer - will not budge) NOS might be a different issue but I believe a battery, inside a sealed battery box will not cause electrical/fire risks to anything in its proximity.
Old 03-02-2007, 20:20   #10
Partner
Lummox's Avatar
Images: 2
Nos isnt dangerous, its nitrogen and oxygen.
Lummox is offline
Old 03-02-2007, 20:24   #11
Briskodaholic
Tom_vRS's Avatar
But mixed with LPG thats a VERY different kettle of fish.
Tom_vRS is offline
Old 03-02-2007, 20:30   #12
Nuts
anonymouse's Avatar
Members Car: Fabia vRS
Perhaps Jason's a budding terrorist.
anonymouse is offline
Old 03-02-2007, 20:32   #13
Partner
Lummox's Avatar
Images: 2
But like he said the LPG is in a very secure tank.
Lummox is offline
Old 03-02-2007, 21:26   #14
Insecure
ag.morley's Avatar
mmmmmmmmmmmmmm.............Wonder how many triple 'A's you'd need..
I now own a Volvo 2.4T Automatic V70 XC 4 wheel drive, Estate, running on LPG......In a Lovely shade of Gold
"BRISKOLVO ".......THE UK'S ONLY MEMBER......." IT'S THE WAY FORWARD "
ag.morley is offline
Old 03-02-2007, 21:43   #15
Mongreller
Images: 5
LPG is in a secure tank as Mr M-03 says, and even if the valve in the tank started to leak, there is a cap on top of it which seals the tank from the inside of the car and the lpg would merely vent through the hole in the boot floor and to atmos.
There's no risk of me creating a mongrel TNT ok.
Old 03-02-2007, 23:15   #16
maxcars1's Avatar
Members Car: Seat Ibiza TDI MK4
Well, to be honest, hiding is not an issue. It's just the practicality and still trying to use it as a boot (as much as is possible....)
I think you lost the practicality of your mongeral now Jason - all that hardware going into the boot mate might as well be a 2+2
100PD converted to 130 Spec Mods: To many too mention
maxcars1 is offline
Old 03-02-2007, 23:43   #17
Members Car:
What about the battery in a nice box where the SMIC should be, especially is you get one of those small racing type batterys, access through a flap in the wheel arch ?
Glider is offline
Old 04-02-2007, 00:04   #18
Mongreller
Images: 5
Well, the ultimate aim is weight re-distribution, not simply getting it out from where it is now. I could probably make the room needed by moving the battery through 90 degrees and leaving where it is, or pushing it further back toward the bulkhead - but it is boot bound.
Old 04-02-2007, 00:58   #19
Escorted Estate
No risk - that's pushing it a little hehehe
Alternative to false floor, you could do the split horizontally instead with the batteries say on the left hand side of the boot and the NOS bottle on top?
I should be asleep right now as getting up in 3 hours but something that looks roughly like two shoe-boxes on top of each other, like a square figure 8
Batteries in bottom, NOS on top, metal construction (perhaps you can do a simpler one and just have the bottom box with detachable plate.
That way you'd loose a little space on one side but more height, rather than loosing height throughout.
WW --->> Project Journal (pic links in first post there)
Lummox'/Ross thread on Unit18 Automotive progress on my car: here
WW_VRS is offline
Old 04-02-2007, 09:31   #20
Mongreller
Images: 5
I think you're on to something there Mr W. Although it would mean having to move the NOS out the way to access the battery terminals, unless I can raise it up above the battery box a bit? Food for thought.
Old 04-02-2007, 09:36   #21
Hardcore
Basil's Avatar
Um, with a front-wheel drive don't you want the weight to be over the drive wheels to help the LSD put the power down?
Or is it a case of 'too much of good thing' ?
Cheers
Bas
Fab vRS - Black Magic - PD160 intake - Forge FMIC - colour coded front grille -SLC Splitter - K&N Airfilter -SEAT Strutbrace - Jabba ARB - IC Waterspray (need to wire it in!) - 312mm TT brakes - Eibach Springs - Skoda Reversing sensors - Devonutopia Tuning (tm) Custom Exhaust (2 1/4" straight pipe) - Short shifter mod- 5 brake light mod - Helix Steel SMF + Organic Clutch + pressure plate - Peloquin LSD - TD stage 2 Hybrid - Washbrook remapped ECU - Uprated injectors - Cupra bushes -Poly-filled dogbone - Allard racepipe - Pirelli Dragons - Forge Rear Strutbrace - DIY SS upper boostpipe delete -Koni FSD's - elephant pipe CCV mod
Basil is offline
Old 04-02-2007, 10:08   #22
Mongreller
Images: 5
Yes - way too much. The weight of the engine is enough for the front end, so need a little over the back for general handling improvement. Especially as I tend to run with no backseats in....
Old 04-02-2007, 14:52   #23
Hardcore
Basil's Avatar
Talking Re: What is under the fabia boot floor?
If that's the case, then you've applied yourself with your usual intensity.
Move non-essentials out (rear seats)
Move relocatable back (Battery, NOS, LPG, girlfriend, etc)
Lighten anything that can be - Carbon Fibre bonnet
You could always lose the Aircon if you don't need it, but with global warming it's not advisable! If you do an internet search there's a US company that makes an aircon that runs on 12VDC for cars and works pretty good, in a light package. Put that in the back when the weather dictates.
How much does an aircon compressor, plumbing, etc etc weight?
Cheers
Bas
Basil is offline
Old 04-02-2007, 15:49   #24
Permanently banned
Snoopie's Avatar
Members Car: Honda Civic Type-R
Removing the air-con I always thought would be alot of hassle. Because of the belts that run it aswell etc. I think the air-con weighs about 25kg for the whole fitment.
Snoopie is offline
Old 04-02-2007, 17:10   #25
Mongreller
Images: 5
air con pump weighs a LOT. I sold one on Ebay recently and the price to post it was loads. Not sure on how it's driven. I assume it's belt driven, but I don't think it's cambelt driven. Unsure how it works to be honest.
I have no aircon now anyway, so don't really mind if it went. That is a lot of weight to get off the front end for sure.
