This is a discussion on whats happened? within the Fabia I forums, part of the Skoda Model Discussion Area category; i was giving the car some beans on the motorway when all of a sudden i lost all boost! no ...
| Briskodian Join Date: Nov 2005 Location: Co. Durham
Members Car: skoda fabia vrs Thanks: 0
| i was giving the car some beans on the motorway when all of a sudden i lost all boost! no warning lights came on the dash so i pulled off the motorway and turned the engine off. i waited for a couple of seconds and turned it back on. now its ok . ive just recently put a pd160 intake on and i cut the restrictive bit out today. could this have something to do with it?daz ![]()
__________________ skoda- loved by the intelligent....hated by the plonkers!! ![]() |
| Partner Join Date: Sep 2003 Location: Newport Pagnell
Members Car: Mk2 Golf GTi 16v and building a 20VT MK2. Images: 2 Thanks: 29
| Re: whats happened? Have a search for over boost |
Members Car: silver Fabia VRS Thanks: 31
| Re: whats happened? not had a problem with my VRS after fitting intake pipe and cutting away restriction flap , and it definetely got a good thrashing on the C+F run today
__________________ very bored and liable to do something stupid |
| Briskodian Join Date: Dec 2005 Location: scotland
Members Car: Fabia 16v Thanks: 4
| Re: whats happened? how close to the redline were you? My Audi did this with the power box turned right up was told it was the fuel pump cut off. wasn't a PD just an old skool TDi |
| | #5 | |
| Re: whats happened? Quote:
__________________ skoda- loved by the intelligent....hated by the plonkers!! ![]() | |
| Re: whats happened? been reading up on other faults that sound the same as mine and it sounds like its gone into limp mode!
| Re: whats happened? Its an over boost fault, it happens from time to time, especially when crusing on light throttle. It has been covered at great length by both myself and Neo_VR hence me sugesting a search. Never actually got to the bottom of it, happens on std and remapped cars. |
| Om nom nom nom Join Date: Feb 2003 Location: Manchester
Members Car: A White Car Thanks: 85
| Re: whats happened? 4000rpm in 6th.... hmm thats almost double the national speed limit... ![]() |
| | #10 |
| Briskodian Join Date: Nov 2003 Location: Warrington
Members Car: Fabia Jabba TDi & Citroen C4 Thanks: 0
| Re: whats happened? Yep overboost, you must have been caneing it! Sometimes you can get it back by just coming off the throttle, wait a few seconds and thn back on. Other times needs a full reset and restart of the engine. In mine I know when I get close because can feel the engine power "fluttering" just before it goes into overboost and shuts off. But I know that this in general is way in excess of the national limit and usually only in the winter when its colder, and can generate more boost than usual. Have fun...... Andy
__________________ Fabia TDI PD100 "Q" and driving school car. ![]() Citroen C4 Coupe 1.6hDi+EGS with disability adaptations. |
| | #11 | |
daz
| | #12 |
| Briskodian Join Date: Apr 2004 Location: Kent
Members Car: Fabia vRS Thanks: 0
| Re: whats happened? You can switch the ignition off then on again on the fly but make sure the road is straight (I accept no responsibility for what may happen!!!!)
__________________ You've been Skoda'taken! |
| | #13 | |
Members Car: '97R BMW 328i Saloon Thanks: 728
__________________ 97/R BMW 328i in Boston Green. ![]() | |
| | #14 | |
| Briskodian | Re: whats happened? Quote:
Yikes, then you'd have no power assisted steering , and no servo assisted brakes , if it was dark you would have no headlights , and incredible brown trousers Not overly keen on this idea ![]()
__________________ I'm the only Skoda driver in the village! 4 Wheeler: Black Magic Fabia vRS, MSD Grill, SEAT Strut Brace, ESP, Side Airbags, Cruise Control, 3rd Rear Headrest. 2 Wheeler: Triumph Thunderbird Sport | |
| | #15 |
Members Car: Ford Escort 1.6LX + Fab Estate Thanks: 48
| Re: whats happened? no PAS is not a big deal at the implied speed ![]() Brakes wise you should have plenty of braking assistance left as you should be able to do an emergency stop on the reserve pressure, it doesn't instantly 'go'. Headlights would be a big problem though as the Xenons would be off ![]() I've not had this problem but if it happened I'd put on the blinkers and pull of the road asap to restart safely. Unless you're trying to outrun the law I'd go for that ![]()
__________________ WW --->> Project Journal (pic links in first post there)Lummox'/Ross thread on Unit18 Automotive progress on my car: here |
| | #16 | |
