This is a discussion on What's the key "coded" to do? within the Fabia I forums, part of the Skoda Model Discussion Area category; I'm a bit of a nugget when it comes to this soooo, I just wanted some yay/nay answers, maybe with ...
Members Car: Skoda Fabia Mongrel Images: 5 Thanks: 79
| I'm a bit of a nugget when it comes to this soooo, I just wanted some yay/nay answers, maybe with quick solutions? Thanks
![]() Still struggling with VAG com though - put a shout out on SCN for help now.
__________________ Jason - Only a Skoda. Custom Fabia Bonnet Lifter Kits - £45! Click Me. BRISKODA CLUBSTAND @ Castle Combe! 25/04/09! Track session too! Click me! See the mongrel's 260bhp Dyno Video! |
| Briskodian Join Date: Jun 2003 Location: On the back of an AA truck with a failed turbo
Members Car: Octavia II 2.0 TDi Elegance Thanks: 34
| There is a (4?) digit code that skoda supply to the dealers to allow them to code new keys to the car , but I'm pretty sure that the data that the chip in the key sends to the immobiliser is longer than 4 digits. This along with the physical bit of the key and barrel allows the car to be started With just the physical key I doubt the immobiliser will even allow the car to start. The "remote" bit of the key also needs to be coded to the car (or at least mine did when I got a new key - it came as two halves each of which needed to be programmed) and it's not a fixed code that it sends , but a rolling one that changes each time
__________________ Alex "I laugh in the face of danger, then I hide until it goes away" www.drzoidberg.co.uk Last edited by Dr Zoidberg; 14-06-2005 at 21:30. |
| I should say my RCL is a BigK aftermarket jobbie, with separate module and separate lock/unlock buttons on a separate fob. Just for info. ![]()
| Partner Join Date: Sep 2003 Location: Newport Pagnell
Members Car: Mk2 Golf GTi 16v and building a 20VT MK2. Images: 2 Thanks: 29
| The key has a transponder chip in it, this can be programmed. There is no physical ident to the chip. Any key can be programmed to start any car as long as there is a mechanical key in the lock to activate the ignition. So to sum up you can throw them keys you have with the donor engine in the bin, you dont need em. You can code your keys to the dash which will signal the immobilizer to start. |
| | #5 | |
| Quote:
__________________ Alex "I laugh in the face of danger, then I hide until it goes away" www.drzoidberg.co.uk | |
Members Car: Ford Escort 1.6LX + Fab Estate Thanks: 48
| I seem to remember the sticker with the letters/numbers in the boot and the service handbook allow the dealer to recode it - but luckily I've not had to find out if my theory holds ![]() Can't wait to say Jason's car when it's done though, should be interesting ![]()
__________________ WW --->> Project Journal (pic links in first post there)Lummox'/Ross thread on Unit18 Automotive progress on my car: here |
| | #7 | |
| Quote:
I have the four digit code, is that what it uses, or is it another one of the magic numbers off the dashpod the key needs reprogramming to? having never used VAG com in any sense, I don't know the true ins & outs of its mechanics.I don't really want to keep the flick key/barrel the car came with anyway - Its got the RCL bit integrated in it, that I don't require, plus its a little bulky too. Would rather keep my current TWO keys and have a spare, AS LONG as they both still open the two front doors, via the key/lock Would hate to lock myself out the car, if the RCL battery should pack up. ![]()
__________________ Jason - Only a Skoda. Custom Fabia Bonnet Lifter Kits - £45! Click Me. BRISKODA CLUBSTAND @ Castle Combe! 25/04/09! Track session too! Click me! See the mongrel's 260bhp Dyno Video! | |
| We seem to be going around in circles here. The four digit code is an access code do enable a signal sent from the immobilizer which codes the key. YOU WILL NOT NEED THE NEW KEYS OR REMOTES AND YOU CAR WILL WORK IN EXACTLY THE SAME WAY IT ALLWAYS DID. |
| | #9 | |
| Quote:
I never realised it went THAT way around. Thought they key had to be programmed by vag com, not vag com used to access and then the car codes the key itself. sorry. ![]() God damn it, I'm gonna have to get this program working and learn it myself. ![]()
| | #10 |
| Briskodian | You code ECU to the key not key to the ECU |
| | #11 | |
| Quote:
Its 23 hours into this day in particular, and I've now learned that "new thing" Just feel sheepish about what it takes to drum it into me... Repeat after me... Ecu codes key, ECU CODES KEY! ECU CODES KEY!
| | #12 |
| Briskodian | Page 58 of the handbook, If the electronic chip in the handle of the key is damaged, the engine switches off by itself after 3 seconds. It is possidle to select an emergency code and in this way to deactivate the immobiliser. The 4-digit code you have is that code |
| | #13 |
| Cool ![]()
| | #14 |
| The four digit code doesnt de activate the immoblizer, is an access code to recode the key. So then the immobilizer works as normal. |
| | #15 |
| Don't talk, drive! Join Date: Feb 2003 Location: The B roads of Britain
Members Car: 1983 Porsche 928S / 1972 MGB GT Thanks: 20
| Now my curiosity is aroused - what 4 digit code? Does this apply to Mk 1 Octavias also? Ta |
| | #16 |
| Applys to all VAG vehilces with immobilizer 1 onwards, inc the octavia 1. The code has since been superceeded by a seven pin number which includes a date code so can only be used on the day supplied, but Skoda havent changed over to this system yet, but its on the way. The four pin code can be obtained one of two ways, by your dealer emailing Skoda or it behind the scratch of panel on the long plastic tag supplied with your keys. The code is required if you want to, Add or recode new keys Change the dash insert Change the engine ECU |
| | #17 | |
| Quote:
Another dumbass Q then, if you're changing both 2) and 3) from your list at the same time, which are matching, then no further action is required, as they match. ![]()
| Key Fobbed Off - one press or two?!! | FunkySi | Fabia I | 32 | 24-05-2005 20:13 |
| New Key needed | cyberskidz | General Car Chat | 3 | 18-03-2005 14:45 |
| Key organisation | robmawer | Off Topic and Chit Chat | 8 | 28-02-2005 18:45 |
| Missing Key | stuart33 | Fabia I | 2 | 27-11-2004 11:47 |
| Remote Key Re-coding | greg2302 | Maintenance & Performance | 0 | 03-08-2004 09:51 |
