Wheel arch intercooler vent how too
This is a discussion on Wheel arch intercooler vent how too within the Fabia I forums, part of the Skoda Model Discussion Area category; Hey all Made the wheel arch intercooler vent this afternoon, only took an hour - heres how... Jack up and ...
Old 07-05-2005, 18:53   #1
Hey all
Jack up and take off the wheel, the wheel arch is formable plastic so draw a box and measure equal spaces, I used 6" square and then use a stanley knife to cut out 3 vents in this space. The trick is to heat up the plastic and bend it to create flaps which keep out the water from the tyre, when it cools its stays in the shape you create as you can see in the pic
Just ensure the flaps dont stick out too much as it rubs on full lock, I bent them back in slightly from this photo and it was fine.
Hope this helps Big thanks to my mate Andy Naylor for the help
Phill JK is offline
Old 07-05-2005, 19:02   #2
Mongreller
devonutopia's Avatar
Images: 5
I spy with my little eye, something beginning with "I" through those gaps.
Doesn't look quite as neat as having the Audi TT vent in its place, but then you've saved yourself some money, created the same overall effect, and hell, who can actually SEE the work done when the wheels are fitted?
Jason - Mongrel owner! WOOOOF! Grrrrr
Custom Fabia Bonnet Lifter Kits - £45! Click Me.
Cheesy bonnet lifter video to "raise me up" http://www.youtube.com/watch?v=hMnGECEi5Oc
See the mongrel's 260bhp Dyno Video!
devonutopia is offline
Old 07-05-2005, 19:04   #3
HellFire's Avatar
Ummm wont all the dirt/grip/mud/dust from the tyres go straight onto the back of your intercooler in effect blocking it and actually increasing the heat
When I did mine I spent a lot of time following the guides, and got the proper Audi TT Arch Liner, atleast I know the intercooler will be clean and it'll dissapate the air properly.
Metro Blue '06' 5 Door Astra 1.8 SRi
HellFire is offline
Old 07-05-2005, 19:05   #4
HellFire's Avatar
http://www.briskoda.net/forums/showt...ght=arch+liner
This is how me and devonutopia did ours
HellFire is offline
Old 07-05-2005, 19:06   #5
Mongreller
Images: 5
That shot is a very "upward facing" shot, so from the level, or above, the slats are facing the right way to block all the crap getting in, as the wheel comes down and around from the top. Does that make sense? The only way mega amounts of crap will get through those slats is he does 30mph in reverse around a muddy field.
I agree though that IF stuff were to get through, more would manage to in the above example, rather than the "narrower, but more of them, slats" on the TT vent.
Old 07-05-2005, 19:08   #6
HellFire's Avatar
I checked my I/C yesterday since installing the Arch Liner and guess what! not a spot of muck
HellFire is offline
Old 07-05-2005, 19:22   #7
beeftech's Avatar
whjats thats sposed to do then???????
'05 Corrida Red Fabia vRS: Revo'd to 185Bhp
'90 Nugget Yellow Corrado 1.8T: KO4S and 265bhp
beeftech is offline
Old 07-05-2005, 19:30   #8
HellFire's Avatar
Cool the intercooler down, the Fabia vRS has a SMIC not a FMIC, Audi's, Seat's, even VW's (the tourag's one is vast!) have them fitted as standard onto the arch liner but since the Fabia is the cheap VAG brand it misses a few tweaky bits, hence the need to retro fit it. Unfortunately an arch liner from another car doesnt bolt straight on (or we havent found one which does), which means you have to get an Audi TT arch liner for example (the S3 has a very large one I hear, ahum...no pun intended ) and cut the vent out, and fettle with your own arch liner until it's a perfect fit ( well if your a perfectionist like me that is ).
HellFire is offline
Old 07-05-2005, 19:44   #9
Fabian
bryand's Avatar
Mine's had a piece of B&Q alloy speaker grille in it since October and the back of the intercooler is spotless.
bryand is offline
Old 07-05-2005, 19:50   #10
This pic was taken while in progress just to show how the holes look and from a low angle, the flaps are more closed now and should keep out any excess dirt, any water or muck will hit the top of them and roll off.
Phill JK is offline
Old 08-05-2005, 11:57   #11
VT5
Has anyone tried the S4/S3 liner?
I would imagine they are pricey though due to lower numbers of manufacture compared to Audi TTs.
Was: 2003 Allard Tuned Fabia vRS VT5 Turbo Conversion
Now: 2008 Audi A3 Sportback TDI
FabiaTDi is offline
Old 08-05-2005, 12:00   #12
HellFire's Avatar
Apparently the cost is the same but tbh I cant imagine it makes much difference, the TT vent is perfectly matched in size terms as the SMIC and im sure it disappates enough heat already with the TT vent so cant really see the need IMO for anything larger.
HellFire is offline
Old 08-05-2005, 12:06   #13
I,ve the S3 one, it also fits well. I'm in the middle of a TT225 mod, twin I/C's. At £50 I thought I'd give it a go.
Glider is offline
Old 08-05-2005, 12:21   #14
HellFire's Avatar
One on either side right? I was contemplating this myself, how much is the I/C and is the pipework there or is that the awkward bit?
HellFire is offline
Old 08-05-2005, 12:31   #15
VT5
Hmmm its about time a gave this a go then..
FabiaTDi is offline
Old 08-05-2005, 12:32   #16
VT5
Cheers,
dual ics eh? sounds interesting. Remember someone doing this to an Octy vrs a while back - think it was fitted by amd.
FabiaTDi is offline
Old 08-05-2005, 12:38   #17
Om nom nom nom
Neo_VR's Avatar
I didnt think this was possible... the washer bottle takes up all the space on the passenger side. not sure if it would ever work out: the golf pd150 cars have a fmic as opposed to dual smic.. whilst petrols have the two. im sure theres a very good reason for it.
i still think a whopping FMIC is the way forward
ColGod the UberMod
,___,
[O.o]
/)__)
-"--"- ORLY??
Neo_VR is offline
Old 08-05-2005, 13:10   #18
200 laps.......
the Jabbasport FMIC is awesome,
expensive but well worth it!!!!
Alex
Skoda Octavia vRS-Awaiting Mike at Impossible to sort out STILL
RenaultSport Megane R26 Ultra Blue Number 21
Honda CBR600Fi
WrightyRS is offline
Old 08-05-2005, 22:39   #19
Got mine and 90% of the pipework for £50 second hand. Yes it fits with minor mods,
Glider is offline
Old 08-05-2005, 22:57   #20
Don't talk, drive!
ncarring's Avatar
The vent, any vent, has got to be the cheapest mod for anybody's money, and you can't argue with the physics. My old Octy went around with a very fine mesh grille in the wheel arch for over 2 years, and the intercooler never looked dirty, neither did the feeble ally mesh take any dents or knocks from stones etc.
Must get around to doing the new one some day. One thing at a time ....
Nick
North Wiltshire RoADAR
ncarring is offline
Old 09-05-2005, 12:55   #21
HellFire's Avatar
What pipework is needed etc and could you create a "how to" on this as it would be excellent for all those considering a FMIC upgrade as you might not need to.
HellFire is offline
Similar Threads
Introduction to the NEW Octavia ColinD Octavia II 2 22-02-2007 20:09
Gunk build up behind Wheel arch liner... fivepint@work General Car Chat 0 04-04-2005 12:38
Wheel balance advice needed.. rossm Maintenance & Performance 11 01-03-2005 01:52
Changing steering wheel? William Maintenance & Performance 9 10-02-2004 14:32
Intercooler Vent delcac Maintenance & Performance 16 17-06-2003 12:05
