This is a discussion on Wheel spacers within the Fabia I forums, part of the Skoda Model Discussion Area category; Anyone used the eibach wheel spacers yet and if so what size? and whats the positive effect of using them?...
| Briskodian Join Date: Nov 2003 Location: Warrington
| Wheel spacers Anyone used the eibach wheel spacers yet and if so what size? and whats the positive effect of using them?
__________________ Fabia TDI PD100 "Q" and driving school car. ![]() Citroen C4 Coupe 1.6hDi+EGS with disability adaptations. |
| Briskoda Staff Join Date: Dec 2004 Location: Hampshire
| Rears to widen the track I believe Andy. Try German Ebay - about 15mm from what i've read.
__________________ Stu Stu's Websites - http://www.fabia-vrs.com & http://www.octavia-vrs.com Stu's Car - 2008 Audi S3 - Ibis White, Black Optics Pack, Privacy Glass, Auto Bi Xenon Headlights, Rain Sensing Wipers, Bose Sound System, Ipod Prep, GSM Phone Prep, Flat Bottom Multi Function Steering Wheel, Electric Folding Mirrors, Acoustic Parking, Cruise Control, Interior Light Pack, Non Smokers Pack. SWMBO's Car - 2008 Seat LEON TDi Stylance, Black Magic, Sports Pack, Rear Parking Sensors. Something for Weekend - A Patio |
| | #3 | |
| Ding, dong Join Date: Sep 2003 Location: in the doghouse
| the uses for them is if you have wheels that rub when turning from being too wide, and from making the arches look fuller by making the wheel stick out a bit more.
__________________ Jeff: Ambitious, but rubbish Quote:
Jeremy Kyle, helping normal people feel superior since 2005 | |
| I understand it can cause problems with premature wheel bearing failure though? Just a thought...
| | #5 | |
| VT5 Join Date: Dec 2002 Location: Warwickshire
| Quote:
15mm I have and recommended max if you are planning on lowering. 20mm can be fitted otherwise. positive effects are more settled feeling under braking and cornering. The extra track width is not actually that obvious. common mod on ibizas etc.. ![]()
__________________ Was: 2003 Allard Tuned Fabia vRS VT5 Turbo Conversion Now: 2008 Audi A3 Sportback TDI | |
| Briskodian Join Date: Jan 2005 Location: United Arab Emirates
| Yes but Matt, if you fit spacers to the rear, does it cause premature wheel-bearing problems or not? I'd like to do that, but I don't want future problems wth wheel bearings. Can you get your bearings checked?
__________________ Milton Kyvernitis Private Government |
| | #7 | |
| BRISKODA Staff Join Date: Oct 2002 Location: darkest Hampshire
| Quote:
__________________ Adrian. Last edited by SkodiRS; 16-07-2005 at 09:07. | |
| I know that!! I was just asking if HE could get his wheels checked so that I would know somehow if it is okay to fit rear spacers..
| | #9 | |
| Quote:
These are the spacers that I have fitted to mine - we are not talking about the kind of spacers you find in Halfords for a tenner here. ![]() The thing is, it is not so much a styling mod - it is more to benefit the handling and stability (thats why rear fitment only) I fitted mine after reading a few posts on SEATcupra.net - people like Badger Bill have them fitted to Ibizas and I reckon he would know what he was talking about. I also ordered them form Badger5 so asked more questions then. Mike at Jabba also commented about benefits of fitting to Ibizas etc. Apparently more recent wheel spacers are able to handle the spacers, whereas it could be more of a problem on older cars such as Mk2s etc. If people are that worried about wheel bearing problems, then the answer is easy - dont fit them.. Personally after reading up on it I was quite happy to trial/fit them and I reckon the results are worthwhile. Isnt that what this car modding lark is all about? ![]() Have people with had problems with bearing failure then on Ibiza4s/fabias then? Starting to wonder now lol..Mine have been fitted for approx 8000 miles. Will have a look this weekend. EDITED: IMPORTANT NOTE YOU MUST FIT THE CORRECT LONGER WHEEL BOLTS WHEN FITTING WHEEL SPACERS.
__________________ Was: 2003 Allard Tuned Fabia vRS VT5 Turbo Conversion Now: 2008 Audi A3 Sportback TDI Last edited by FabiaTDi; 16-07-2005 at 09:05. | |
| | #10 |
| Briskodian Join Date: Jan 2005 Location: Central UK
| The Fabia`s never really did have a problem with the rear bearings. The front ones they did to start. You dont just fit the bearing on the fronts it is the hub and bearing Ł50 ish if I remember correctly. But the fronts have been superceeded a couple of times. But the rears I have heard nothing. With fitting bigger wheels or tyres you can put extra stress on the bearings. But if you are covered under warranty and you hear a noise , dont you just remove the spacers before you take it to a dealer to get it checked out? |
| | #11 | |
| Om nom nom nom Join Date: Feb 2003 Location: Manchester
| Quote:
the rear bearings are sealed units.. i had one fail without spacers... dealer blamed the alloys... when it was more likey a manufacturing defect i think its a case of if they are going to fail they will fail sooner with the extra lateral loads put on it... but doesnt mean it causes premature wear... if that makes sense ![]() | |
| | #12 |
| Cool. I want them to improve handling. If rear spacers will do that I think I'll place my order. Thanks a million.
| | #13 |
| Again, is it reeeeeally okay to fit spacers just in the rear? I want to order them, but only upon knowing for sure that they're okay to use.
| | #14 |
| Okay.... just checked with my dealer. Rear spacers are okay to use. ![]() However, I was going to ask for 20mm but when the assistant service manager and I measured the gap between the wheel and the rear fender, it shows I can only fit upto 15mm 20mm and the tyres stick out a lot!!! So I've ordered 12mm H&R spacers with the required bolts. Setting me back about GBP50 for both of them. Will be fitted at the dealers.
| | #15 | ||
| Quote:
why? do they have to be welded on or something?
Jeremy Kyle, helping normal people feel superior since 2005 | ||
| | #16 |
| More like why not, if you're happy to pay for it, that is ![]()
__________________ WW --->> Project Journal (pic links in first post there)Lummox'/Ross thread on Unit18 Automotive progress on my car: here |
| | #17 | |
| Quote:
No, but at least when it's done there, if anything goes wrong, it's their problem. Always lookin' for security you know....
__________________ Milton Kyvernitis Private Government | |
| Introduction to the NEW Octavia | ColinD | Octavia II | 2 | 22-02-2007 20:09 |
| Wheel balance advice needed.. | rossm | Maintenance & Performance | 11 | 01-03-2005 01:52 |
| Which 17" wheels allow clearance for Brembo GT brake kit? | RallyInfo | Fabia I | 6 | 31-08-2004 13:12 |
| Changing steering wheel? | William | Maintenance & Performance | 9 | 10-02-2004 14:32 |
