This is a discussion on where is the engine number ? within the Fabia I forums, part of the Skoda Model Discussion Area category; Before I start searching inside the engine bay, can anyone tell me where I will find the engine number stamp ...
| Briskodian | where is the engine number ? Before I start searching inside the engine bay, can anyone tell me where I will find the engine number stamp on my Fabia VRS (55 reg), please. So I can it check against the log book. Jules |
| is chilled out! Join Date: Aug 2007 Location: Scunthorpe, Nth Lincs
Members Car: Fabia vRS Black Magic Thanks: 68
| Re: where is the engine number ? Email me your chassis and ill tell you it. PM me if you want me email address!
__________________ Blood runs through our veins, thats where all similarities end.... |
| Briskodian | Re: where is the engine number ? That wont help me as its had a new engine (after water ingestion !) and I want to know the new engines number. So where do I look for it ? Jules. |
| Partner Join Date: Sep 2003 Location: Newport Pagnell
Members Car: Mk2 Golf GTi 16v and building a 20VT MK2. Images: 2 Thanks: 29
| Re: where is the engine number ? Its stamped on the edge of the block near the gearbox iirc, trouble is you can't read it with the gearbox fitted. |
| Moderator | Re: where is the engine number ? IIRC its on the front of the bottom end just under the join with the cylinder head on a small machined area. EDIT: lummox got there first ![]()
__________________ ![]() Last edited by Bigw2069; 13-09-2007 at 18:23. Reason: too late |
Members Car: silver Fabia VRS Thanks: 31
| Re: where is the engine number ? would a new engine actually come with a number stamped on it ? a lot of the Ford engines don't , we should stamp them but don't due to lack of the correct toolage
__________________ very bored and liable to do something stupid |
| Briskodian | Re: where is the engine number ? If that was the case I would think that you have just seen a reconditioned engine - remember VAG engine plants don't always know where (which model/marque) a specific engine is going to be fitted into at the initial engine build stage - ie before anciliaries and mountings are fitted. So ALL brand new engines will be allocated a s/n during the assembly process. In later life this ability to pin down the engines age or build state might well affect what spare parts are suitable for it. |
