Where to get Hybrid Turbo and Milltek Exhaust
This is a discussion on Where to get Hybrid Turbo and Milltek Exhaust within the Fabia I forums, part of the Skoda Model Discussion Area category; Well its time for a bigger turbo and milltek exhaust but where do i get it?? There is no Milltek ...
Old 31-01-2006, 10:03   #1
There is no Milltek dealers in denmark and the VNT 20 turbo is kinda pricy.....
so where did u buy your parts from i guess i have to order from GB....
Torben Paw is offline
Old 31-01-2006, 10:56   #2
Re: Where to get Hybrid Turbo and Milltek Exhaust
Hi
It's just the same as the Golf PD engine, I'd buy your Turbo from Germany, seem cheaper there, also Milltek shoud be available, try Garrat website they have links to German agents, also join the Skoda german forum for more info.
Failing that you could mail order from JBS, Starperformance or Awesome.
ccvrs is offline
Old 31-01-2006, 12:13   #3
faboka vrs's Avatar
Also try Turbo dynamics or allard for a vnt17/20 hybrid.
Is the turbo your looking at a hybrid vnt17/20 or just a vnt20?
John
Take away the poor damping, inadequate bushes, heavy diesel lump and spongy brakes its not a bad warm hatch
faboka vrs is offline
Old 31-01-2006, 15:23   #4
RallyRed's Avatar
Most hybrids require an exchange turbo so go buy one from a breakers or ebay.de
then send whoever the turbo and some cash and they send you one theyve "breathed on".
or if you are brave and you can find the specs for the hybrid you can DIY it.
My Audiworl sig i too lazy to do a briskoda one
RallyRed is offline
Old 31-01-2006, 15:34   #5
Mongreller
devonutopia's Avatar
Images: 5
Allards Hybrid is around £800 on exchange, materials only - no labour.
Milltek I'm not too sure about really.
Jason - Mongrel owner! WOOOOF! Grrrrr
Custom Fabia Bonnet Lifter Kits - £45! Click Me.
Cheesy bonnet lifter video to "raise me up" http://www.youtube.com/watch?v=hMnGECEi5Oc
See the mongrel's 260bhp Dyno Video!
devonutopia is offline
Old 31-01-2006, 18:45   #6
Escorted Estate
Interesting that they will do an exchange - turbodynamics would not take the original Fab vRS turbo in exchange. As I was looking for an all-out new turbo anyway it didnt bother me but it's worth noting I suppose.
WW --->> Project Journal (pic links in first post there)
Lummox'/Ross thread on Unit18 Automotive progress on my car: here
WW_VRS is offline
Old 31-01-2006, 19:25   #7
Cupra Bush King
Lummox's Avatar
Images: 2
Originally Posted by ccvrs
Hi
The Golf TDi (PD) turbo isnt the same as the Fabia vRS, the compressor housing is spun through 90 degrees to clear the chassis leg.
Unit 18 Automotive Services
www.unit18.co.uk
Lummox is offline
Old 31-01-2006, 19:29   #8
Mongreller
Images: 5
I don't know if this is relevant, but a distinct memory of my turbo in its first stages of fitting, was it came with the outlet pointing straight up, and Allards told me it needed spinning through 180 degrees to match how the Fabia system works. Luckily this was something quite easy to do. Not sure if this spinning is something that can be applied generally, or whether you can only have outlets pointing in certain ways (like only up or down, or only left or right?)
When it came to matching up my intercooler pipework to my turbo, it was mildly amusing to wonder how the hell it connected to the turbo with the pipework running along the chassis leg, and the turbo outlet pointing to the sky.
Old 01-02-2006, 00:32   #9
RallyRed's Avatar
was that for a hybrid or for a larger turbo?.
RallyRed is offline
Old 01-02-2006, 08:28   #10
Escorted Estate
It was for a hybrid, it's probably the 17/20 thing being referred to. I specified it was for a Fabia vRS and the model they told/sold me was the MD345 - including VAT & delivery it was just a shade under GBP1100.
Thing is that to get the most out of it you'd want improved cooling too like the vented arches thing at a minimum, FMIC probably better, and a remap/tweak of existing map.
In my case everything is getting done before the remap, slowly but surely
I'll do a fitting 'report' this Sunday, must make sure to charge the camera AND bring it along
WW_VRS is offline
Old 01-02-2006, 11:29   #11
Micky 32's Avatar
I noticed for an extra £50 + vat Turbodynamics do a stage 2 turbo MD376. Its supposed to have a 2275 spec wheel with a 260bhp capabillity, any ideas what that compressor wheel is?
Micky 32 is offline
Old 01-02-2006, 12:03   #12
Escorted Estate
Not a clue but if you give them a call they are very helpful, should be able to send you a spec sheet for both variants.
I wasn't looking for extremely high boost capability as that would require even more work to the car/engine - such as injectors at a minimum - and I couldn't be bothered with that in all fairness based on cost etc.
Mine's 'just' a stage 1 upgrade, it should still give a notable improvement in being able to cope with higher sustained boost but be very driveable.
You considering a stage 2?
WW_VRS is offline
Old 01-02-2006, 14:41   #13
Micky 32's Avatar
For the sake of an extra £50 i probably would go for the stage 2, maybe not for seeking extra power but as its more capable of boost may mean its more durable.
Micky 32 is offline
Old 01-02-2006, 23:38   #14
thanks for all the answers ive been on a 30hour work shift so its nice to find a lot of answers when u get home...
Similar Threads
Milltek turbo exhaust system for Fabia vRS SkodiRS Fabia I 10 14-07-2005 13:10
Milltek turbo exhaust system for Fabia vRS SkodiRS Fabia I 2 07-07-2005 20:24
Milltek Exhaust and Sports Cat Q's HellFire Fabia I 14 28-02-2005 20:15
Milltek Exhaust PUGSYTHEBEAR Maintenance & Performance 10 27-11-2004 17:17
