This is a discussion on Where's the filter?? within the Fabia I forums, part of the Skoda Model Discussion Area category; Maybe a daft question but where exactly is the Vrs oil filter? Is it a case of 'simply' removing the ...
| Briskodian | Where's the filter?? Maybe a daft question but where exactly is the Vrs oil filter? Is it a case of 'simply' removing the sump guard and hey presto there it is or is it a bit more complex than that? |
| Partner Join Date: Sep 2003 Location: Newport Pagnell
Members Car: Mk2 Golf GTi 16v and building a 20VT MK2. Images: 2 Thanks: 29
| Re: Where's the filter?? Your looking at the wrong end of the engine. |
| Briskodian Join Date: Nov 2005 Location: Macclesfield, Cheshire
Members Car: Nissan Primera GT Thanks: 37
| Re: Where's the filter?? Here on my PD100, I should imagine it's the same:
__________________ Rob Nissan Primera GT in Silver ![]() '56 Octy 2 2.0TDi Elegance . . . also gone but not forgotten 2002 Fabia 1.9TDi . . . . gone but not forgotten http://uk.youtube.com/yashicamatonline |
Members Car: silver Fabia VRS Thanks: 31
| Re: Where's the filter?? you'll need a big socket to undo the cap , the paper element will just lift out when cap removed
__________________ very bored and liable to do something stupid |
| | #5 | |
| Briskodian | Re: Where's the filter?? Quote:
http://www.briskoda.net/forums/fabia...ght=oil+filter
__________________ I'm the only Skoda driver in the village! 4 Wheeler: Black Magic Fabia vRS, MSD Grill, SEAT Strut Brace, ESP, Side Airbags, Cruise Control, 3rd Rear Headrest. 2 Wheeler: Triumph Thunderbird Sport | |
| Briskodian | Re: Where's the filter?? This reminds me of when I changed the air filter on SWIMBO's Polo 1.4 TDiPD...and after 1 hour and much cursing I it found behind the offside fog light Not exactly where I expected it to be really. |
| Briskodian | Re: Where's the filter?? Thanks for all your help guys, a job I can look forward to doing next week! |
| Re: Where's the filter?? undo the cap and lift the old filter out before you drain the oil , that way you should get most of the old oil out of the engine
| | #9 | |
__________________ Rob Nissan Primera GT in Silver ![]() '56 Octy 2 2.0TDi Elegance . . . also gone but not forgotten 2002 Fabia 1.9TDi . . . . gone but not forgotten http://uk.youtube.com/yashicamatonline | |
| | #10 |
| Re: Where's the filter?? Miles above it. You should remove the filter first as it drops another 1/4 litre of old oil baxck down into the sump. If you do that after draining the oil it sits in the sump. |
| | #11 |
| Re: Where's the filter?? Okey dokey, cheers. Got everything except the oil, but havn't got time tonight - weekend job methinks. ![]()
| | #12 |
| Briskodian Join Date: May 2006 Location: Chesterfield
Members Car: Fabia vRS Thanks: 0
| Re: Where's the filter?? Just make sure that you don't overtighten the cap when you fit the new filter. There's a torque setting that needs to be followed otherwise you end up with a broken o-ring seal and an engine bay, sump tray and chassis covered in oil (just like I did 5 days into owning my car!). |
| | #13 |
| Re: Where's the filter?? i've got a gallon of oil if you want it yashicamat , its in a FORD wrapper though
| | #14 |
| Briskodian Join Date: Feb 2005 Location: Mid Beds
Members Car: fab vRS Thanks: 0
| Re: Where's the filter?? Wow, you lean something new everyday! Thats the oil filter! I always wondered how your suppposed to get access under the engine? No need!
__________________ Fabia vRS forunner to the Bentley Continental GT Briskoda - Skoda's illegitimate family Mods: Superchip, K&N filter, Eibach springs, FSD dampers, black front grille, |
| | #15 | |
If you're a Plumber, you'll be used to crawling about in dark, filthy confined spaces ![]()
