40,614 Members 1,518,189 Posts
Why change oil yearly?
This is a discussion on Why change oil yearly? within the Fabia I forums, part of the Skoda Model Discussion Area category; Can someone please explain the idea behind having to change the oil on a yearly basis. I understand the importance ...
Old 18-12-2006, 23:15   #1
Members Car:
Smile Why change oil yearly?
I understand the importance of oil but I think it should be changed every ten K miles.
I currently only drive 2 K miles a year so what benefit is it to change new oil for new oil - Seems like quite a shame to me.
Answers much appreciated
Joey122mac is offline
Old 18-12-2006, 23:35   #2
yaktrebor's Avatar
Location: Bakewell, Derbyshire, where the puddings come from. (That's tarts to foreigners!)
Members Car:
Re: Why change oil yearly?
From what I understand...
Engine oil has an optimum operating temperature, designed around the engines normal running temperature.
So if you are running up and down the motorway all day, at optimum temp, then your oil will last a long time.
Just ask the variable servicing drivers, they get up to 20k miles out of their oil.
(A sensor in the engine checks the condition of the oil and tells you when to change it)
Anyway, if you are running very low mileage, a greater proportion of your yearly miles are driven with the engine/oil not at its optimum and therefore it will degrade faster.
I'm sure someone else will be along soon to add some additional gems of wisdom.
'No more beer!' (unless it's GF)
yaktrebor is offline
Old 19-12-2006, 00:13   #3
Not so Grumpy
Mr Grumpy's Avatar
Members Car: Super Skip
If you only drive 2K miles a year....
That equates to 40 miles a week roughly.
If you understand oil, and it seems a shame to use it..
You would be financially a lot better off using a taxi for your motoring needs, then you can blame the wastage of the worlds resources on someone else.
I'm not having a dig, but sell your car fella, and buy a pushbike
Ho feckin' Ho, S50 vRS has to go, for baby Jesus' sake, somebody buy it...
Lovely MX5 for sale as well.....go on, treat yourself.
Mr Grumpy is offline
Old 19-12-2006, 00:28   #4
yaktrebor's Avatar
Members Car:
My Father only does about 2k a year in his car.
He used to get a new car every three years via Motability, until I convinced him that at 2k a year, he could probably keep the same car for 20 years and it would still be OK.
He now has a Honda HR-V ! (stereotypes are there for a reason )
Therefore...... 1 car for 20 years = using less of the planets resources, as most of a cars carbon footprint is in the manufacture, not the running. (especially at 2k a year.)
Old 19-12-2006, 02:11   #5
Eye Eye
Decron's Avatar
Members Car: Vroomster
You can never change your oil enough.
An engine oil's job is primarily to stop all the metal surfaces in your engine from grinding together and tearing themselves apart from friction, and dissipating the heat generated from this process. It also transfers heat away from the combustion cycle and must be able to hold in suspension the nasty by-products of fuel combustion, such as silica (silicon oxide) and acids. It cleans the engine of such chemicals and buildups, and keeps the moving parts coated in oil. Doing this helps minimise exposure to oxygen and thus oxidation at higher temperatures. It does all of these things under tremendous heat and pressure. As well as with use, oil degrades with time, all the compounds and chemicals mentioned above can damage the engine if not removed. Condensation is also worse over time especially as the oil also absorbs moisture.
You don't have to change your oil but it is a proven fact that regular oil changes with good quaility oil will keep your motor running a lot sweeter and longer.
It's down to you at the end of the day.
Decron is offline
Old 19-12-2006, 03:25   #6
Chris GB's Avatar
Members Car: Mini Cooper D
Hi
Quite possibly has to do with corrosion. Engine oil absorbs moisture from combustion processes and has to keep it in suspension. Also there will be a proportion of unburnt fuel in the oil. Running regualrly at full running temperature will help evaporate these contaminants out of the oil. Lots of short runs will have the opposite effect.
Chris
Red Fabia vRS. Gone but not forgotten.
Chilli Red / white Mini Cooper Diesel with dual controls.
Silver 53 MR2. Mods: PPE 4>1 manifold | PPE Mangnaflow high flow cat | Blueflame catback exhaust | Pikey inlet mod | 3.0 Racing Chassis stiffening brace kit | BC Racing fully adjustable coilovers | TF loud.
Details here My MR2 Page
Chris GB is offline
Old 19-12-2006, 12:00   #7
Babs's Avatar
had a chat with the dealer the other day about variable servicing. apparently the 2.0 TDI in the Octy can go 26,000m/2years between services. that means that a 3 year old car would only have ONE serivce.
I wouldn't buy it!
my Lupo has it's oil changed every 5000, so 3 times in the past year!
- Andrew
In need of a new car, post your suggestions here!
Babs is offline
Old 19-12-2006, 12:10   #8
mluton's Avatar
I wouldn't buy it!
They wouldnt introduce a variable service if they thought it would do more damage to the car.
I only do low milage around 7K - 9K a year and my car is setup for variable servicing. It had its first service at 20,100 miles and its second at 37,500 miles.
I dont see the problem.
Red Skoda Octavia V//RS
mluton is offline
Old 19-12-2006, 12:27   #9
Eye Eye
Decron's Avatar
Different engine, different oil.
Technology is fantastic although if you thrash a VS car and then you may need it done every 6k
Decron is offline
Old 19-12-2006, 16:12   #10
P-A
Members Car: VRS
Don't forget that manufacturers also set service intervals that make their cars as attractive as possible to leasing companies. For leasing companies servicing is expensive (ie. loss of earnings while a car is being serviced, more administration costs, and you can't lease a car when it's in the garage!). Therefore a car that can apparently cover 20,000 miles or two years between services is very attractive. Leasing companies and manufacturers don't really care what happens to the engine after the 3 year warranty has expired.
P-A is offline
Old 19-12-2006, 16:15   #11
nottyash's Avatar
Garages would go out of business!!
Your right, oil technologies have come on a long way. Using a good long life oil in theory eliminates the need for a yearly change.
Its easy money
nottyash is offline
Old 19-12-2006, 16:29   #12
KentStu's Avatar
Members Car: Yellow Octy RS
Personally I disagree with that approach. VAG generally are not going to give a damn if your car blows up as along as its after the warranty period ... variable servicing or not they are long gone responsibility-wise. I am also a lowish mileage Octy RS driver at between 8 to 10k during the year with plenty of smallish runs and some spirited driving at times. Given the improtance of oil, the nature of my driving and the fact that I intend to keep the car for quite a while I always get the oil & some form of service done every year. Why not it doesn't cost much more?
Stu
Yellow Octy RS & '58 Morris Minor Tourer Owner .......... not a hairdresser
KentStu is offline
Old 21-12-2006, 14:15   #13
Dieseline's Avatar
Diesel engines produce quit an amount of sulphur dioxide as a by-product of combustion. The blow-by gasses that get past the piston rings transfer this sulphurous gas into the engine sump where it mixes with the oil and any condensation in the engine. I'm no chemist, but as I understand, the sulphur content of the oil leeches out as sulphuric acid which can destroy engine components, especially engine bearings.
Hence, keep stale oil in your diesel engine at your peril!
Dieseline is offline
Old 21-12-2006, 14:57   #14
Fabian
bryand's Avatar
Members Car: Volvo C30 2.0D
Not since the introduction of Ultra Low Sulphur Diesel they don't.
bryand is offline
Old 21-12-2006, 15:55   #15
Escorted Estate
How about soot
WW --->> Project Journal (pic links in first post there)
Lummox'/Ross thread on Unit18 Automotive progress on my car: here
WW_VRS is offline
Old 22-12-2006, 00:21   #16
Babs's Avatar
how many variable serviced cars last over 100,000 miles?
it just strikes me as odd that (for example) a VS car can cover 100,000 miles and only see the inside of a garage FOUR times, and in that same 100,000 miles, a car that I owned would have seen the inside of a garage at least TWENTY times.
- Andrew
Babs is offline
Old 22-12-2006, 00:33   #17
Dieseline's Avatar
error
Old 22-12-2006, 00:43   #18
Dieseline's Avatar
You can't say that bryand because "Ultra low sulphur" doesnt mean sulphur-free.
Old 22-12-2006, 01:01   #19
Briskodaholic
Tom_vRS's Avatar
Members Car: '97R BMW 328i Saloon
VAG are hardly going to introduce a servicing regime that results in engine failures, inside of warranty or not. If every engine on VS went bang at 100k VW wouldn't be in business for long
The number of sensors on a VS car is bewildering, constantly measuring oil temp, oil quality, oil pressure, revs, vehicle speed etc etc... VW know what they are doing, if the car says it doesn't want servicing til 27k miles, then dont get it services til 27k miles. Likewise if it comes on a 6k miles (or 8500 like my mates PD leon), then get it done then.
Quality of modern oils is amazing, I see little point in chucking away perfectly good oil after just 5k. My Focus is on annual / 12.5k intervals. I plan to change at 10k ( I do 20k a year), and using a premium oil, this regime far exceeds the service schedule that Ford specify.
97/R BMW 328i in Boston Green.
Tom_vRS is offline
Old 22-12-2006, 02:06   #20
Dieseline's Avatar
All motor manufacturers are out to outdo one another with regards to extended servicing. One manufacturer comes along as quotes 10k miles between oil changes so then the other manufactureres feel that they are gong to loose out on sales if they dont extend their service regimes similarly.... just as with claims for fuel economy. .....And yes they are pushing their luck with the servicable life of the oil even though oil technology is quit impressive now.
So, how do the manufacturers cover themselves against the likelyhood that the oil will loose its efficiency if used for too long?..... you guessed it.... they add more and more sensors to the engine so hopefully the damage to the engine will be minimised so long as you get it serviced the moment the warning appears. Trouble is that by the time a sensor registers oil degradation or overheating or low oil pressure, the damage is already done. Lets all hope those sensors alarm with a reasonable safety margin.
Old 22-12-2006, 18:04   #21
adamC's Avatar
just my two peneth worth i change my oil every six mths so its new oil in for the winter to prtect the engine during cold starts, then change it as weather gets warmer usually october and march not sure it if actually benefits the car but makes me feel better LOL
MINE: 08 Reg BMW 120d se Dynamic 177 hp 350 nm trqe.
Wife: Saab 9-3 120 tdi linear sport
Gone but not forgotten: 04 VRS black magic, octy 17 spiders, pd160 and K&N. Never did get the remap!
adamC is offline
Old 22-12-2006, 20:06   #22
WoodieGuthrie's Avatar
Members Car: Totally Stock:-)
My BMW gets new oil every 6 k, and the felicia gets it every 5k. small price to pay for a smooth running lump.
TBH the oil does get dirty in that time- petrol/diesel make a helluva mess.
I know boys running LPG in the same BMW lumps as me, and oil is still crystal clear after 10k....
WoodieGuthrie is offline
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 1
