This is a discussion on is it worth doing a oil, oil filter change every 5k? within the Fabia I forums, part of the Skoda Model Discussion Area category; i do my regular 10k service's but is it worth doing a oil and oil filter change in between(5k). or ...
| Briskodian Join Date: Dec 2006
| i do my regular 10k service's but is it worth doing a oil and oil filter change in between(5k). or should i just keep to the normal 10k. can i get pro's and con's please. thanks. ive got a 100pd tdi elegance by the way. ![]() |
| Briskodian Join Date: Jul 2006
| With modern synthetic oils think it would be a waste of money if you had another oil/filter change in between assuming that you had the oil and filter done at 10k. If you were doing the job yourself then its your personal choice, personally I would keep to 10k Last edited by Reece_1; 14-03-2007 at 22:17. |
| Want a go? Join Date: Oct 2005 Location: Cwmbran - South Wales
| Not unless you give some serious beans on a day to day basis. |
| renewing the oil and filter more regularly than the service interval will not do any harm to the engine and may benefit it in the long run mine gets changed as often as every 2.5k , but then i get the oil for nowt
__________________ not so bored now |
| Nuts Join Date: Nov 2006 Location: Greater Manchester
| I'll be having mine done on vRS every 8k - bit extra, might just save mega expense. Air filter - supposed to be 40k, changed mine at 16k (just after purchase), will be doing every 20k. Similarly with all other service items will do them a bit earlier |
| Ho Hum Join Date: Jan 2006 Location: Not here
| All my diesel cars have had interim oil changes. For the sake of roughly £40 it gives me peace of mind, knowing that they all get ragged pretty frequently. If you look at it that it is less than the cost of a night out every 6 months, and the car always seems to appreciate it, it is well worth it imho.
__________________ I turned the light off............. |
| | #7 | |
| Quote:
Chris
| Briskodian Join Date: Jul 2006 Location: Nottingham
| I used to enjoy lying under my car getting filthed up with oil,thinking I was being a conscientious owner.Now at 43,I can't be arsed.Life is too short.If it ain't broke,don't fix it.Stick to the recommended intervals,use the best oil you can afford. |
| BEN BEN BEN Join Date: Feb 2007 Location: Ashford, Kent
| The oil change interval is there of a reason, thats why it states 10,000 miles. The oil would probably go on for another 5,000 miles beyond this before it gets ropey. The oils that are used are tested to their full limit to see what they can stand day after day. The most worrying part for me is the cam belt change not the oil interval, after Diesels can go on to well over 100,000 miles and still be in good nick. The oil that VAG use is good quality stuff, so really your wasting £40 doing it sooner, unless it's free of course. The design of newer engines is more advanced than years gone by, and the manufacturers will have tested the engines and oil combinations to the full extent. Look at the Diesel engines in the Octy and Audi's etc, they can go on for the best part of 30,000 miles on a singe fill of oil, if you treat it good. My mate has an audi and the oil change light doesn't come on until 20,000 miles. I know there is a slight difference in the makeup of the oils between the Fabia and the Octavia range, but circa 20,000 miles is good for an oil change today, especially a Diesel.
__________________ Ben, Benjamin or even Benjo at a push........BUT NOT BENNY - Note: I am not called Peter Griffin....I may look like him....... |
| | #10 |
| Briskodian Join Date: Oct 2006
| If you do loads of short journeys then I would change it if you are doing it yourself......oil degrades quicker with short journeys. |
| | #11 |
| Briskodian Join Date: Aug 2006 Location: Wrexham
| Having just done this on my PD100 I'd say yes, car seems to appreciate it (seems a bit smoother) and it's only £40ish quid plus an hour of your time. I also cleaned my air filter, which may be worth doing while you're changing oil... Saying that, my cars done 105k and gets driven hard quite a lot and I do loads of short journeys. |
| | #12 |
| Briskodian Join Date: Mar 2006 Location: Risca, Newport
| its a waste of money imho its an oil burner not a race car
__________________ Im not addicted to coke, i just like the smell of it. - Richard Pryor |
| | #13 |
| Briskodian Join Date: Sep 2006 Location: Walsall
| | #14 |
| Briskodian Join Date: Nov 2004 Location: dublin
| in most states in the US they change oil every few thousand miles!!....they have these wee shops that try to out do each other with who can do the fastest oil change!!...its like going to a maccy D drive thru!! k ![]() |
| | #15 |
| Dont forget that Diesel itself is a lubricant which is another reason Diesels last longer than petrol. Changing before the stated milage really is OTT. Ok if your planning on keeping the car for the next 10-15 years maybe it would give you some benefit however as most people change their cars between 3 & 5 years this hardly seems economical & it doesnt need it! |
| | #16 |
| Briskodian Join Date: Jul 2006 Location: Glasgow
| Oh you lucky fellows! poor wee Woodie needs a oil and Filter change every 5k or 3 months. then 10k per set of sparks and a tappet check/adjustment. New oil= GOOOD, cant get enough of it. and as stated before- £30-40 for peace of mind is nothing |
| | #17 |
| Briskodian Join Date: Feb 2007
| I'm planning on doing a change every 5k. Like others have said, it wont do any harm. In my current car the oil has to be changed every 3,000 :o |
| | #18 | ||
| Quote:
| | #19 |
| BMW gets the same, so does the 7 series preventative maintainance Last edited by WoodieGuthrie; 15-03-2007 at 19:51. |
| | #20 |
| Briskodian Join Date: Apr 2004
| isnt it true though that the car will be running without oil pressure for those few seconds when starting after an oil change so too frequent changes are a bad thing ??? |
