Discussing Changing fuel filter on 1.4TDI within the Fabia II forums, part of the Skoda Model Discussion Area category; Hi, Do the three black plastic clips on the top of the filter can have to be pushed away from ...
| Login | ||||||
46,769 Members 3 Posts | Register | FAQ | Members List | Calendar | Mark Forums Read |
| Notices |
Register to reduce ads, enable search and join our community.
| | LinkBack | Thread Tools | Display Modes |
| Briskodian | Changing fuel filter on 1.4TDI Hi, Do the three black plastic clips on the top of the filter can have to be pushed away from the can,or is it the two oval buttons which stick through the filter can holder that have to be pressed in over to release the filter from its holder.the oval buttons are about 100mm from the top of the holder and 180deg apart. I have tried gently easing the clips and buttons but to no avail. The Fabia is a 2004 Comfort that I purchased three months ago. Cheers, Tony. |
| Briskodian | Re: Changing fuel filter on 1.4TDI Tony If the fuel filter is anything like mine on my 1.9 tdi, the three clips have to be pushed outwards to release the filter from the housing. It then just lifts out with a bit of careful jiggery pokery, even with pipes attached. |
| The Following User Says Thank You to Zebra For This Useful Post: | a.r.miller (20-08-2008)
| Briskodian | Re: Changing fuel filter on 1.4TDI Thanks Zebra, I will press on with the filter change. Cheers,Tony. |
| Bookmarks |
| Priming fuel system on Fabia SDI after fuel filter change.... | Shadowphax | Fabia I | 7 | 09-01-2009 19:56 |
| Changing the fuel filter | Gizmo68 | Superb | 15 | 08-08-2008 16:30 |
| Changing Fuel Filter Quick help needed | RichB86 | Octavia I | 9 | 01-06-2008 20:09 |
| Changing Fuel Filter on Felicia 1.9 GLi? | Muckypaws | Favorit, Felicia, Fun and Forman | 1 | 26-11-2005 23:07 |
| Changing Fabia tdi fuel filter Year2001 | Graham1 | INTRODUCE YOURSELF! First time visitors, say hello here. | 2 | 18-12-2004 21:08 |
BRISKODA.net is operated by Summit 360 Ltd. Site Design and vBulletin Theme by Alex Pinner (apinner)
Problem viewing this site? Upgrade to the latest version of your web browser of choice:
Opera | Firefox | Safari | Internet Explorer
