This is a discussion on Double-clutching within the Fabia II forums, part of the Skoda Model Discussion Area category; I recently heard about double-clutching. I'm not sure it is necessary in modern cars but I wonder if anyone here ...
| Briskodian | Double-clutching I recently heard about double-clutching. I'm not sure it is necessary in modern cars but I wonder if anyone here does this. |
| Briskodian Join Date: Feb 2008 Location: Herts
Members Car: Skoda Fabia 3 estate 1.4 16v Thanks: 24
| Re: Double-clutching Double-declutching was a method used to change gear before synchromesh gearboxes were standard issue. The gear was momentarily put into neutral while the engine revs were matched to the new gear before declutching a second time and engaging the new gear. The method was also taught by Police driving instructors as part of teaching police drivers the system of car control as advocated in Roadcraft, the Police Driver's Manual. It isn't necessary with modern gearboxes, though you should still match the engine revs to the new gear before re-engaging the clutch, ie. a blip on the accelerator when changing down. It will avoid clutch drag and with lengthen the life of the clutch and transmission.
__________________ Jo |
| Briskodian Join Date: Jul 2006 Location: Preston
Members Car: Vauxhall Corsa 1.2 16v Comfort Thanks: 221
| Re: Double-clutching I do it instinctively while driving now, and will use it where a car's electronics rule out heel & toe downshifting. Definitely helps smooth out downshifts, but takes a while to get used to it.
__________________ |
| James Rothwell Join Date: Feb 2008 Location: Epsom, Surrey
Members Car: Skoda Demos! Images: 21 Thanks: 32
| Re: Double-clutching I thought double-D clutching when what I was doing in Prague that night... I'll get my coat. |
| | #5 | |
Members Car: Skoda Fabia Mongrel Images: 5 Thanks: 79
| Re: Double-clutching Quote:
Unless it's a "special" place in Prague? ![]()
__________________ Jason - Only a Skoda. Custom Fabia Bonnet Lifter Kits - £45! Click Me. BRISKODA CLUBSTAND @ Castle Combe! 25/04/09! Track session too! Click me! See the mongrel's 260bhp Dyno Video! | |
| Re: Double-clutching Yeah there was an extra fee payable. |
| Briskodian Join Date: Jun 2008 Location: Sheffield
Members Car: Skoda Octavia Elegance Estate Thanks: 1
| Re: Double-clutching Double-de-clutching with a synchromesh gearbox will not help unless the synchro cones are knackered. If the technique is rushed or done in an undisciplined way, more strain and wear is placed on the synchromesh mechanism than if a `single clutch` techniue is used, (properly- not slashing through the gate). `Little Jo` suggests blipping the accelerator when changing down - fine, but a progressive pressure on the pedal will find the exact rev match before you let the clutch up on the down change which makes for such smoothness, you wont feel it, plus virtually no wear on the clutch plate. |
| Double DIN | shakey2k4 | ICE, Security and Insurance | 0 | 28-04-2008 15:29 |
| Seeing double | musky | General Car Chat | 8 | 01-04-2008 14:09 |
| Double de-clutching | ScoobyChris | Racing and Advanced Driving Techniques | 28 | 04-09-2007 12:54 |
| 6 Double Vodka's please | Moose | Off Topic and Chit Chat | 1 | 01-04-2005 13:16 |
| Double Trouble | lozgti | The Roadside Hotel | 11 | 17-03-2005 20:15 |
