This is a discussion on Fabia sidelights within the Fabia II forums, part of the Skoda Model Discussion Area category; HI everyone. One small question... how do you replace the sidelights in the new fabia? i knoe where the lights ...
| Briskodian | HI everyone. One small question... how do you replace the sidelights in the new fabia? i knoe where the lights are and wherem they are removed from but i cant seem to get the bulb out! has any 1 had this problem? ![]() |
| Briskodian Join Date: May 2008 Location: south wales
Members Car: octavia 140tdi fabia105tdi Thanks: 0
| Re: Fabia sidelights Hi Jon...the bulbs are located quite deep into the headlamp unit.youll need small hands and lots of patience.The passenger side on my 1.9tdi was quite straight fwd but the drivers side took a while due to the engine bay being rather full.If you can get ur hand behind the bulb it releases quite easily with enough cable travel to change bulb...good luck |
| Briskodian Join Date: Aug 2006 Location: Istanbul ,TR
Members Car: 2007 Roomi 1.4 85 BHP Thanks: 116
| Re: Fabia sidelights At the first time I couldn't managed take out too. But, I used my both index finger to grab and pull hard the sidelight bulbholder. Don't try to pull it from the wiring, feel the sidelight bulb holder with your finger tips. Now I've got LED bulbs ![]() ![]()
__________________ 2007 Roomster 1.4 16V - after 3 years with 2004 Fabia 1.2 12V http://www.skodaclubturkey.com |
| Briskodian | Re: Fabia sidelights Oh ok, i will try a bit harder then i dont have the biggest hands in the world cheers guys yeah that does look soo much better then the stantard yellowish bulbs, i have a pair of white LEDs to fit, any 1 else got any headlight upgrade pictures? |
| Re: Fabia sidelights I also upgraded my standart bulbs to Osram Night Breaker... Result is significantly positive. The Osram NightBreaker delivers a ground breaking 90% more light on the road for optimum visibility and safety, and has a light output that is 10% whiter and more natural for minimal glare and optimum comfort whilst driving. - Up to 90% more light. - 10% whiter light. - Silver cap design looks stylish when unlit. - Fully approved and road legal for road use in the UK and Europe. - UV coated bulbs, safe to use with plastic headlamps.
| Briskodian | Re: Fabia sidelights Cool, i think the std headlight bulbs are quite good? mayby point a little low though? |
| Briskodian | Re: Fabia sidelights Still having trouble replacing these sidelights! why are the sidelight bulbs in such a diffacult place! has any 1 got any other tips?? |
| | #8 | |
Members Car: Black Magic Fabia vRS Thanks: 385
| Re: Fabia sidelights Quote:
Just take car to grip the lamp holder and not the wiring... ![]()
__________________ | |
| Briskodian | Re: Fabia sidelights Use long nose pliers with 90 degree tips to grip the bulb holder and extract. Got this job to do on mine. My headlights were aiming too low as well. Asked an independent garage to see to this which they did for free as they'd not seen a Mk2 Furby before and were interested. |
| sidelights | fonzi's felicia | Fabia I | 6 | 01-04-2008 18:03 |
| sidelights | vrs-si | Styling and Car Care | 3 | 22-02-2008 18:41 |
| Sidelights goosed ? | Rally Stu | Maintenance & Performance | 2 | 14-12-2006 02:29 |
| Where have my sidelights gone? | yaktrebor | Octavia I | 2 | 14-11-2005 10:58 |
| Intermittent sidelights | simontreen | Maintenance & Performance | 3 | 30-04-2004 17:30 |
