40,598 Members 1,517,627 Posts
First Fault.
This is a discussion on First Fault. within the Fabia II forums, part of the Skoda Model Discussion Area category; Accelerator pedal sensor is showing an intermittent fault, causing the engine to go into 'safe mode' It's only happened a ...
Go Back   BRISKODA - The Skoda Forums > Skoda Model Discussion Area > Fabia II
Old 16-05-2008, 14:10   #1
JSJ
Members Car:
First Fault.
Accelerator pedal sensor is showing an intermittent fault, causing the engine to go into 'safe mode' It's only happened a few times and restarting the engine cures it, but it's booked in for next week. They can take a look at the minor rattle behind the instruments as well.
JSJ is offline
Old 16-05-2008, 14:31   #2
ASZ Eternal
ap0gee's Avatar
Members Car: Black Magic Fabia vRS
Re: First Fault.
Bad luck! Sadly, kit does somes fail early on, but at least it's under warranty. And if you get your squeak sorted, then so much the better! Hope it's fixed soon!
ap0gee is offline
Old 16-05-2008, 14:35   #3
JSJ
Members Car:
Re: First Fault.
Cheers, I'm quite relaxed about it, and they are treating me well.
JSJ is offline
Old 16-05-2008, 15:08   #4
is chilled out!
youngsyd's Avatar
Members Car: Fabia vRS Black Magic
Re: First Fault.
Its not uncommon for the Accelerator pedal on the new fabia...
Blood runs through our veins, thats where all similarities end....
youngsyd is offline
Old 16-05-2008, 16:53   #5
JonA's Avatar
Re: First Fault.
Skoda must have done something different on the right hand drive cars, because I haven't seen or heard of a single new left hand drive Fabia with accelerator pedal sensor problems so far..
Overall this sensor usually is incredibly sturdy, and faults are extremely rare. I started trying to repair VAG cars in 1992, and to this date, i have replaced only one or two sensors.
i hope your dealer sorts out both the rattle and replaces your throttle pedal sensor quick, so you can get back to drive and enjoy your new car
Enjoy!
JonA
JonA is offline
Old 25-05-2008, 18:12   #6
Zebra's Avatar
Members Car: Skoda Fabia 3
Re: First Fault.
My Fabia has a rattle coming from the passenger airbag cover as it moves from side to side in the dashboard.
Does anyone know how the dealers would fix this?
Thanks
Zebra is offline
Old 29-05-2008, 15:50   #7
JSJ
Members Car:
Re: First Fault.
Well the car is in having the sensor replaced and the rattle looke at.
The receptionist told me that the sensor issue is now an official recall.
JSJ is offline
Old 01-06-2008, 13:07   #8
Members Car: Furby 2 1.9TDI Red
Re: First Fault.
Does anybody know if this issue affects the petrol or diesel cars, or both?
Thanks.
V.
virgo17 is offline
Old 02-06-2008, 17:51   #9
Zebra's Avatar
Re: First Fault.
Took mine in because it has got a rattle.
I thought it was comming from the passenger airbag cover, which was loose and slid from side to side a bit. The Fabia's pass airbag cover in the showroom was solid in comparison.
Took car in at 0800 hrs and received a call this morning to say it wasnt the pass airbag cover.
A further call about an hour ago said they would have to remove the dashboard to try and trace the rattle.
Good service and communication received so far from dealer. Just hope car goes back together without anything on it being damaged.
Prob going to take about two days they say.
Other than being in several bits set in their bay, the car is spot on.
Zebra is offline
Similar Threads
Major Fault - Engine Destruction - Possibly Manufacturing/Part Fault - Please Read djgritt Octavia II 107 13-09-2008 09:29
First Fault skodayouth Fabia II 1 28-04-2008 01:31
It's mostly your fault ovev INTRODUCE YOURSELF! First time visitors, say hello here. 13 03-03-2008 17:47
Power steering fault - fault code 01288 - is this the normal plastic sensor fault? mgskoda Diagnostics & VAG-COM 6 05-11-2007 19:31
Is this a Fault? Theman7 Octavia I 9 06-04-2005 18:22
