This is a discussion on My First Problem within the Fabia II forums, part of the Skoda Model Discussion Area category; The rubber seal at the bottom of the "A" pillar on the outside joining to the front wing on the ...
| Briskodian | My First Problem The rubber seal at the bottom of the "A" pillar on the outside joining to the front wing on the passenger side has been torn off. I presume it was by the force of the wind as I have been travelling. Has anyone else had the same problem? Last edited by Fab Estate; 11-08-2008 at 18:45. |
| Briskodian Join Date: Aug 2006 Location: Istanbul ,TR
Members Car: 2007 Roomi 1.4 85 BHP Thanks: 116
| Re: My First Problem You can have a new pillar trim under warranty...
__________________ 2007 Roomster 1.4 16V - after 3 years with 2004 Fabia 1.2 12V http://www.skodaclubturkey.com |
| Briskodian | Re: My First Problem I presume this is the same problem. http://briskoda.net/fabia-ii/plastic...hanged/115551/ |
| Briskodian Join Date: Feb 2008
Members Car: Fabia New Elegance 1.6 MT (M2M2) Thanks: 0
| Re: My First Problem I had same problem (myFabia.com.ua). Russian dealers replace this under warranty. But our Ukrainian dealer is still silent in this case ![]() Anyway I got used to its look without that seal. Even if you replace it it may get ripped off during next wash or something. It's very gentle. |
| | #5 | |
| Briskodian | Re: My First Problem Quote:
I went to your site and saw the photo. It is exactly the same as my problem but unfortunately I could understand the writing. | |
| | #6 | |
Just description of the "problem" ![]() Small gap under the left pillar still remains but as I said - I got used to it and I don't think it is kind of important detail. So I think I may event forget about it in a few weeks ![]() But you should contact your dealer I guess. Maybe they just have several of thoose to replace. | |
| Briskodian | Re: My First Problem same problem for me. I was a little concerned about the seals all round, rightly so. Replaced under warranty though.
__________________ Just because you are paranoid it doesn't mean they're not after you! |
| Briskodian Join Date: Feb 2008 Location: Herts
Members Car: Skoda Fabia 3 estate 1.4 16v Thanks: 24
| Re: My First Problem Just so you know, I've had a phone call to say my A pillar trim bits have arrived. It looks like Skoda have got their alternative supplier sorted out. ![]() So those of you who are waiting for replacements shouldn't be waiting much longer.
__________________ Jo |
| Briskodian | Re: My First Problem Both of mine have now been torn off by the wind. Are they really worth replacing? What is their purpose? |
| | #10 |
| Re: My First Problem They just reduce wind resistance/noise and I suspect, the accumulation of grime in hard to reach places. Replacement is free (warranty repair) and only takes 20-30 mins to fit.
| | #11 |
| Briskodian Join Date: Jun 2008 Location: Essex
| Re: My First Problem I had my 'A' pillar seal replaced just a couple of weeks ago (missing from new!). Skoda dealers seem to be able to get them ok now. I've noticed it has reduced a slight wind noise at speeds above 60 miles per hour that I previously thought was coming from the drivers window.
__________________ I'm learning to be more RESPONSIBLE!...NOT!!!STARFLEET TRAINED... |
| | #12 |
| Briskodian | Re: My First Problem i seem to have the same wind problem u think that it has got nothing to do with the windows.. cuz the work shop guys have not been able to find the fault so far and whioch fabia do u have ??( is it the 2007 make ) |
| | #13 |
| Re: My First Problem Chase, I have the 2008 Fabia 2 1.4TDI PD 80 Estate. My drivers side lower 'A' pillar seal was missing from new. The gap it leaves is enough, it seems, to allow the airflow to be disturbed and cause some noise.
| | #14 |
| Briskodian | Re: My First Problem my 57 model has started to lose one, plus now i check them on every fabia i see and lots of 08 models don't seem to have any fitted. |
| CD problem | hanksocty | INTRODUCE YOURSELF! First time visitors, say hello here. | 2 | 22-03-2007 15:36 |
| pc problem | MikeF | The Tech Shed | 25 | 22-11-2006 16:11 |
| Problem shared is a problem... | Poop | Fabia I | 3 | 10-10-2005 12:46 |
| Yet another problem with the RS | delcac | Off Topic and Chit Chat | 36 | 23-03-2005 18:23 |
| problem share a problem halved???? | kenny | Off Topic and Chit Chat | 4 | 01-04-2004 22:15 |
