This is a discussion on Original xenon? within the Fabia II forums, part of the Skoda Model Discussion Area category; Hi Is it possible, to get a Fabia 2, with original xenon, and curve light? If not, does anyone know ...
| Briskodian Join Date: Apr 2007
| Original xenon? Hi Is it possible, to get a Fabia 2, with original xenon, and curve light? If not, does anyone know how to use the headlights from a Roomster, with xenon and curve light on a fabia 2? Best Regards Morten |
| Briskodian Join Date: Dec 2006 Location: Norway, Sandvika
| Re: Original xenon? The new Fabia is not available with xenon headlights, and neither is the Roomster. Tou can choose between three types of headlamps on both the Roomster and the New Fabia, and these are: conventional headlamps with H4 bulbs, DE "bi-halogen" lamps with one H7 bulb for both the high and low beam, and the "top of the range" lamps which turn as you turn the steeringwheel if the speed is over walking pace which also features one H7 bulb per lamp. Maybe xenon will be an option when/if the vRS version arrives ![]() Enjoy! |
| Briskodian Join Date: Aug 2006 Location: Istanbul ,TR
| Re: Original xenon?
__________________ 2007 Roomster 1.4 16V - after 3 years with 2004 Fabia 1.2 12V http://www.skodaclubturkey.com |
| Re: Original xenon? yeah, but a aftermarket kit, isent good enough here in denmark. You need headlight washers, automatick light height adjusment, and a headlight aproved for xenon. And yes, you will get caught, if you dont have it orignal mounted. It costs about 50 pounds per xenon kit( if you have xenon in both high and low light, it will be 100 pounds, and 50 more if you have in fogligts also), and a trip to MOT, wich is about 40 pounds. Can the Fabia 2, be delivered with the curve headlight system as original item, and curve foglights? |
| Briskodian Join Date: Dec 2007 Location: Elezar, Gush Etzion, Israel
| Re: Original xenon? I'm not aware of such an option on the FabiaII or Roomster. There is a Cornering Fog option though, if you desire AFS try the new Ibiza... |
| | #6 | |
| Re: Original xenon? Quote:
Sure.....
__________________ 2007 Roomster 1.4 16V - after 3 years with 2004 Fabia 1.2 12V http://www.skodaclubturkey.com | |
| Re: Original xenon? Does the Curve headlights also adjust the height of the beam? What is AFS? |
| Re: Original xenon? Not automaticly, ... Only from the inside It is Adaptive Frontlight System in Superb... The system for controlling the front headlights makes use of the possibility of changing the geometry of the front headlights light beam and adapting the lighting in front of the vehicle to suit different driving conditions.
| Same in the Ibiza see: THE NEW SEAT IBIZA -> Sport ?koda Auto - The new ?koda Superb - Homepage skip vid, 2nd category "TECHNOLOGY FINDS INNOVATION" then look at the AFS skit nice visually explained definition! Quote from Skoda-Auto: "Bi-Xenon headlamps with AFS The headlamps of the new model Superb, the unusual shape of which passes all the way to the sides of the wings, lend the front section of the vehicle a dynamic appearance. They form a powerfully dominant feature and a part of the elegant design of the entire vehicle which is impossible to overlook. Bi-Xenon headlamps feature outstanding illumination and, combined with the new AFS (Adaptive Frontlight System), multifunctionality. They automatically adapt the lighting to various travel situations, swivel into turnings, depending on the speed and actual driving conditions change the illuminated surface and offer various lighting regimes, e.g. for city, motorway or driving in rain. The “tourist light” function is used by drivers entering a country with the opposite operating system than that for which the vehicle was manufactured. For instance, a car intended for driving on the right will not dazzle oncoming drivers in a country where they drive on the left." |
| | #10 |
| Re: Original xenon? Can the Fabia be orderet with automatic beam hight adjustment, with curve headligts? Or maybe a kit from kufatec.de, like it can be done on a passat. |
| | #11 |
| Re: Original xenon? I guess not, because there is no automatic beam height adjustment for Fabia or Roomsters yet, even as an option...
| | #12 | |
The Fabia Mk1, had the option(atleast on the RS model), to be fitted with xenon. So is it possible to use the xenon lights beam adjuster parts from the MK1 Fabia on the Mk2? The things i mean is these: Sensor for the suspension arm, front and rear Wiring kit, can make it my self, if i get a schematics Control unit for xenon adjustment Here is a kit for a passat KUFATEC GmbH - aLWR Komplettset Passat 3BG 33354 So if anyone of you have experience on adding original xenon to a Mk1 Fabia, or knows someone who does, please contact me. Best Regards Morten | |
| RS original xenon autoleveling | marcusdefeis | Fabia I | 9 | 10-03-2008 08:12 |
| Original Octavia Xenon headlights | MartinDK | Octavia I | 14 | 15-08-2007 17:47 |
| Questions on original xenon | evil_jew | Fabia I | 12 | 19-06-2007 13:52 |
| Fitting OEM Xenon lights to non Xenon cars | VRStu | Maintenance & Performance | 7 | 12-06-2007 07:12 |
