This is a discussion on tire presure gauge within the Fabia II forums, part of the Skoda Model Discussion Area category; how does it work and what does it do???? got one and noticed that one of the tyres is slightly ...
| Briskodian Join Date: Nov 2007
| tyre presure gauge how does it work and what does it do???? ![]() got one and noticed that one of the tyres is slightly flatter than the others yet i have had no notice of this! i would of thought it would of let me know ![]() Last edited by mole; 09-04-2008 at 16:53. |
| 2.0 FSI Sport. Join Date: May 2007 Location: oxon
| Re: tire presure gauge do you mean TPM? |
| Re: tire presure gauge same thing. kinda |
| Briskodian Join Date: Jan 2008
| Re: tire presure gauge TPM doesn't measure tyre air pressure directly, it measures and compares the rolling radius of the tyres by using pulses from the ABS sensors. How flat a tyre would need to be for it to be detected as flat I don't know. I suspect it would need to be very flat. There is information about the system in the owners handbook supplied with the car even if the car isn't equipped with the option. TMT |
| Briskodian Join Date: Nov 2004 Location: Cornwall
| Re: tire presure gauge You also need to set it so the car knows what is normal. Get the tyres all to the correct pressue and then press the set button.
__________________ Skoda Motorsport WRC news, photos & more! |
| Re: tire presure gauge nice one, cheers. |
| Briskodian Join Date: Mar 2008 Location: Sweden
| Re: tire presure gauge Remember that it is unable to detect low tyre pressures if they are uniform and develop over time. As all tyres leak air, after a sufficient amount of time you'll have four flats without the system alerting you - as mentioned, it uses the ABS sensors to determine the individual rotational speeds of each wheel (wheel radii I expect it couldn't care less about actually). When you get a flat or a quick leak in one tyre, the system will notice that that wheel turns slower and sound the alarm, but if all tyres leak about the same amount, the ratios between their roll speeds will remain unchanged and the system won't react. At least this is what my dealer told me, right after he said they had added this option without my ordering it (production error, but to my advantage for once). I suspect however that there's more to it, if his explanation holds then I don't see the use for the set button. Guess I have to read the manual to find out ![]() |
| Briskodian Join Date: Oct 2005 Location: KENT UK
| Re: tire presure gauge Quick thought: Is this something that can be 'enabled' if not factory fittted using VAG-COM? |
| Tire help! | jasc1988 | Fabia I | 3 | 31-03-2008 22:15 |
| Favorit Tire Size | daz51 | RWD Skodas and others | 6 | 11-09-2007 22:04 |
| Tire Pressures | psycho6149 | Octavia II | 17 | 17-07-2007 11:09 |
| tire/tyre wear | mcbunny | Fabia I | 19 | 13-07-2005 08:18 |
| How much air? (Tire pressures) | Anton_g | Octavia I | 14 | 17-11-2004 14:49 |
