Changing Spark Plugs (Felicia 1.3 GLi)
This is a discussion on Changing Spark Plugs (Felicia 1.3 GLi) within the Favorit, Felicia, Fun and Forman forums, part of the Skoda Model Discussion Area category; This is going to seem a daft question how does one change the spark plugs on a Felicia 1.3 GLi ...
Go Back   BRISKODA - The Skoda Forums > Skoda Model Discussion Area > Favorit, Felicia, Fun and Forman
Old 13-07-2008, 17:15   #1
Default Changing Spark Plugs (Felicia 1.3 GLi)
This is going to seem a daft question how does one change the spark plugs on a Felicia 1.3 GLi Estate (MPI Engine)?
To be more specific as I am not 'mechanically minded' there is instead of the usual individual HT leads leading to to each spark plug a metal 'bridge' across the spark plugs.
Logically speaking I would have thought this would be easy to remove by simply pulling away from the plugs; however this seems easier said than done.
The 'bridge' seems well and truly fixed to the tops of the plugs.
Can a bit of pressure be exerted to remove this part from the plugs?
Any solutions?
Many thanks
IFA W50
IFA W50 is offline
Old 13-07-2008, 18:24   #2
Hairy Yeti
Lummox's Avatar
Default Re: Changing Spark Plugs (Felicia 1.3 GLi)
You have to unbolt it first, usually two 5mm allen key bolts.
MK2 Golf GTi - APX 225bhp 1.8T - Emerald K3 - Quaife ATB - VR6 Widetrack - VR6 brakes front and rear - Neuspeed ARBs - Speedline alloys - H+R coilovers - Powerflex bushes - Helix clutch G60 flywheel - Adjustable solid top mounts - Custom engine bay - Tornado Motorsport MSA cage - and lots lots more.
Lummox is offline
Old 13-07-2008, 19:15   #3
bobob's Avatar
The metal 'bridge' is the ignition transformer commonly known as a coil pack
as Lummox said, bolted on, the allen bolts are on the bottom face under the two domed lumps.
bobob is offline
Old 24-07-2008, 23:27   #4
Many Thanks Bobbob & Lummox,
I had great fun trying to remove one of the bolts as the head of one of them was badly chewed up.
After spending a good couple of hours trying to free it I decided it was time to call in a mechanic.
Thankfully he managed to free the stubborn bolt and the plugs are now changed.
Once again thanks for your help.
IFA W50
IFA W50 is offline
Old 25-07-2008, 12:58   #5
KenONeill's Avatar
A couple of tips for the next time you hit an issue like that:-
1) PlusGas dismantling lubricant - accept no substitutes. It might get a part-chewed head to move decently.
2) A Gatorgrip socket. Only use this for dismantling though!
KenONeill is offline
