This is a discussion on dipped beam angle switch within the Favorit, Felicia, Fun and Forman forums, part of the Skoda Model Discussion Area category; the one that you turn as opposed to push, to further dip the beams if you got a lot of ...
| Briskodian Join Date: Apr 2008 Location: Northampton
| the one that you turn as opposed to push, to further dip the beams if you got a lot of stuff in the back, apparently i have been told that they dont work on like 90% of felicias, is the fault in the switch os the lamps and is it worth replacing? its just the only thing that doesnt work on the car and its nice to be able to say everything 100% works lol
__________________ ------------------------------------------------ 2000 Felly - Hatch - Green - 43K ------------------------------------------------ |
| Briskodian Join Date: Jan 2007 Location: Leeds
| The fault is that it's controlled hydraulically by a fluid inside the tube and over time this leaks out. You have to replace the unit as a whole, and in my opinion it's not worth going to the effort or cost of sorting out as it will cost about £40-50 and probably fail again in a number of years. |
| oh i see, are they not electric on most cars? ill just have to hope they in the right place. i wont bother fixing them
| Briskodian Join Date: May 2007 Location: Northern Ireland
| Just make sure you get the headlights set each year before MoT and you'll be fine |
