This is a discussion on Favo electronics gone crazy within the Favorit, Felicia, Fun and Forman forums, part of the Skoda Model Discussion Area category; i have a whole lot o electrical problems with my favorit. i intent to fix them myself so if anyone ...
| Briskodian Join Date: Jan 2006 Location: St. Andrew, Jamaica
| i have a whole lot o electrical problems with my favorit. i intent to fix them myself so if anyone has any idea of how to fix them please dont hesitate to provide assistance 1) horn doesn't work 2) the light in the gauge cluster doesnt come on even tho i cleaned the bulbs and the circuit board 3) the only the left head light comes on when the low beam is activated 4) sometimes i have to hit the fuse box in order for both lights to come on in high beam 5) the hazard light switch doesn't work. 6) the light in the ceiling clock comes on but no numbers are being displayed PLEASE help me with this because i am currently in he process of getting my favo up and running and eventually start a tuning project!! |
| Briskodian Join Date: Jan 2007 Location: Leeds
| Is water getting into the fusebox? If not horn will probably be either the horn switch, or the contacts on the horn itself needing cleaning. Light in instrument panel = dead bulb? Hazard light switch and clock are controlled by the same fuse (number 9 if I remember correctly). Check that the brake lights also work. |
| i'm gone to check the brake light and check the fuses in the fuse box now. i'll be back later to tell u how that works out ... o yeah.. the reverse light ( and the reverse siren that i hooked up ) is not working.. need some help on that too. |
| so ok.. i checked the fuse box and found that three fuses were burnt ou including fuse 9. so that accounts for the hazard light and the clock not workin. i cleaned the horn contactts but it still doesnt work. i'll try to clean it properly again tomorrow. Feel free to give suggestions.. ur help would be much appreciated. |
| A multimeter would help you check whether current is reaching the horn or not, and therefore whether the problem is likely to be with the horn itself, or somewhere with the wiring or horn switch. If the fuses are burning out often it is likely there is a short circuit somewhere (a bare wire touching the car's metal for example). I have had a similar problem and not certain I have sorted it yet as it only happens time to time and I couldn't spot any obvious cause. With it being 3 fuses I would wonder if some wiring has perhaps melted somewhere. |
